I thought I’d post a WIP thread of my 1/1500 scratch build project of HMS Ramillies. Typically I build the base and the ship separately but this time do the some issues I had with securing USS South Carolina to her base, I’ve completed Ramillies up to the main deck and joined the sea base and the ship together. This should be okay as the superstructure will mostly be built as a sub-assembly.
The model is a little less than 5” long and made from boxwood. The camouflage scheme was used by Ramillies in the winter of 1917 into the spring of 1918. The sea base is carved wood as well and painted.
4-D936114-4-C99-47-D5-A41-A-C027-DAF5-BA
4-DCA25-BC-270-F-42-DA-BC2-C-E092-AB6-B8
Link to post
Share on other sites
A little update.
The gun turrets are finished. I’ve chosen to depict the guns in exercise, perhaps a dumb show drill since the railings are still up.
I had to make an executive decision about the interior of the splinter shields and turret roofs in as far as the paint goes. I chose a medium grey since no references I can find describe what Wilkinson intended and what the paint crew actually did. So medium grey it is.
The parts count stands at 236 individual pieces.
Link to post
After 36 days of work, 672 individual scratch-built pieces, my 1/1500 scale model of the British super-dreadnought HMS Ramillies is finished. The model depicts the ship as she appeared working up in late 1917 with her Wilkinson Admiralty Disruptive Dazzle camouflage scheme.
The model is made from boxwood and brass, with four grades of tungsten wire for the rigging. The sea base was made from carved basswood and painted. The ship was built entirely from scratch using scale drawings and photographs. If you’d like more information about how I build these ships, I have a website www.josephlavender.com. None of the models are for sale and I do not take commissions.
The 1943 Shilling is just under 1” or 24mm in diameter for scale.
HMS Ramillies was a difficult subject since she’s probably the least-documented of the five Revenge class battleships. Only a handful of photographs exist of her from late 1917, the period I chose for the model. However, the originally Admiralty color plates used to paint the dazzle camouflage still exist. Ramillies wore this camouflage from late 1917 through March 1918.
The colors did pose a bit of a challenge since the forward section of the ship was essentially painted pink or mauve as the RN referred to it, and that color doesn’t scale well. I chose a pinkish peach color cut with a bit of medium grey. Had I used the color right from the plate, without scaling it, I think it would have appeared too garish. The same was done with the other colors as well, cutting them with grey to soften them a bit.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
