HM Cutter Alert by VTHokiEE - FINISHED - Vanguard Models - 1:64
Your method produce great results so go with what works for you. I use the drill only for the corners and slice my way there with a #11 blade, finishing with the files. I also do it with each layer of planking both inside and out so the final bulwarks layeyer is just following the previous two. But again, it’s whatever works and yours did.
I’m with you on the paint. Some acrylics come in a tube and have to be thinned. I use Admiralty paints exclusively, one coat generally does it Except for my white hull, to get that look takes about 10 coats). I may try the thinned method on Cheerful, but for now...  Your paint work looks great as well.
Maybe paint the gun ports before removing your tape.
Edited by glbarlow
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Share on other sites
There is a lot of wisdom to this and I don’t plan on removing the tape until after the ports are painted. I have finished up making the ports, then I installed and painted the wales.
Of course once I removed the tape from the wales I did notice a spot that I will have to touch up when I get the black paint back out.
BCB94756-F504-4FFE-BEF5-C7F466FB0B76.thumb.jpeg.4840fb5d33c8b88cc423f54c22a9cc01.jpegC9A33DC0-787A-4D11-AA62-3B49C428D896.thumb.jpeg.d4c4763663d8fdfc93cc23229fab180c.jpeg0503296C-1F2F-4A74-A782-7272670FBAE4.thumb.jpeg.b150ee08373ff0b11ddb396cf93ad709.jpeg2F4E7619-3912-4D12-A967-8297555F6B5B.thumb.jpeg.d78ba54706b102537dbd1649766b1551.jpeg
Link to comment
Looking good, great progress. Your cutting of the gunports worked just perfectly 😊
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Just as Edward said  your gun ports came out spot on,   also  I love the shaping of the hull  and  the smooth work on  her,  nothing wrong with that in any shape or form, really coming on my friend.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Finished painting the blue between the gun ports and placed one of the rails. I unfortunately got some glue on one of the blue strips. I’m hoping that I can repaint it and it will be fine.
I wanted to get the rails attached before putting the caps on as I thought it would be easier to clamp the rails to dry (I couldn’t see a way to apply CA without causing a mess on a 1mm strip) without the caps in the way.
I also noticed that the cutouts in my cap rail are a little wavy, I need to check to see if it will effect placing parts later. I’d rather file them smooth before I attach them.
Link to comment
Can you lightly sand the blue a bit to smooth out the dried on glue, then re paint it?
OC.
Current builds
Completed works.
Link to comment
I’m going to go sit in the corner and contemplate why I didn’t think of that. Thanks for the suggestion!
Link to comment
Nice problem solving here. I looked closely at your planking and believe I took some of your pitfalls to heart. I picked up my Speedy and prepped the prow just a wee bit more.
On the bench:  Vanguard Models 1/64 HMS Speedy
On Deck:
Vanguard Models 1/64 Zulu,
Vanguard Models 1/64 Fifie,
Victory Models 1/72 HMS Bellerophon
Link to comment
Slow and steady continuing on. After I attached the rails I noticed they were too high in a spot or two so I loosened then in those spots and reattached them (fingers crossed the photo etch fits). Then I marked off the waterline and painted the area below white. I’m currently painting and attaching the cap rails (...slowly).
Link to comment
Liking the colours mate  really attractive.
OC.
Current builds
Completed works.
Link to comment
OC.
Thank you! It’s amazing what a little bit of paint can do. Of course when I had it all taped up to paint my kids told me they thought that it looked better without the tape. 🙂
Link to comment
I’ve never used wipe on poly, but I decided to give it a try on this build. I’m not certain the picture really does it justice but I am very pleased with the first coat.
I finished attaching half of the cap rail as well so on to the other side.
Link to comment
Looks great Jim, paintwork looks really sharp 😁👍
Current builds;
Completed:
Link to comment
The difference compared to post #108 is obvious..  looks great!
Luck is just another word for good preparation.
—MICHAEL ROSE
Current builds:    Rattlesnake (Scratch From MS Plans
On Hold:  HMS Resolution ( AKA Ferrett )
Link to comment
As Edward and Gregory said  - she is looking really nice   well on track mate.
OC.
Current builds
Completed works.
Link to comment
Both cap rails have been attached. In the process I learned that I made the gun ports wider than they should be. The included patterns are fine but I should have been more careful with where I cut compared to where I marked, something for me to watch out for and be more careful with in the future.
I’ve completed the stern transom piece, but I haven’t attached it yet. There is a gap underneath that I need to plank. I’m trying to get a plank fitted before attaching the stern piece. The kit leaves the interior timbers (?) natural, but I decided to paint them so that they blended in.
E083C893-4243-4775-BFB0-3633421964F0.thumb.jpeg.1bdab494121aa14d60fa638f66066720.jpeg3A95E9D8-8540-4B0C-ADFA-C3E83BE3BCC6.thumb.jpeg.26b7dc95e02d66bef029334430d0cf9b.jpeg6CC44201-8474-4D17-88AF-9B47987D60D8.thumb.jpeg.3f81eec2a88242e4f15c52d7cc894bec.jpeg8520BF22-2795-4878-ACEC-A5E20387E7C0.thumb.jpeg.0aa3a38f9418377f1646e72d44de8833.jpeg
Link to comment
She is looking really nice  certainly coming to gether now.
OC.
Current builds
Completed works.
Link to comment
Great job. She's going to be a real beauty!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
Great progress.  I never ceased to be amazed at the transformation in wood created by wipe-on poly.
Your paint lines are very crisp, nice work.
Regards,
Glenn
Link to comment
I added a plank to the stern, I think unfortunately that the lower rail makes it look slightly off level. I’ll have to look and see if I can correct it if it bothers me.
A84CF21E-EA4B-4A47-B026-0D145382E735.thumb.jpeg.9e5e3d9184b2970cc8028979e8ad1cc6.jpegD5EA2708-2D85-4E16-9DC5-6CC64CBF234B.thumb.jpeg.7484b6abba443ff9983ee33703965a2b.jpeg
Then I started adding the posts and rails. I originally thought that I would paint all the posts off the model but quickly realized that there was no real need and it would be easier and quicker to paint them on the model. I did paint the railing off model so that I wouldn’t accidentally mess up the stern.
0DC1756C-66A9-40BE-B580-FA3366E20924.thumb.jpeg.291a59fd2fe95cad87645faad97f3300.jpeg2318442F-EB75-4B28-AAB5-11E36C0594B8.thumb.jpeg.4d357bd70f19b486bd294cd990d2bd48.jpeg41223596-0A55-4679-B6C9-286EC8DCA2A5.thumb.jpeg.2de61ae4fc54ca7ea57de12e6003fb56.jpeg
Link to comment
Looking really good - smart paint work!
I had to look closely at the first picture to see what was bothering you. Noticeable, but only just. However I know what it's like when you've spotted something like that - it niggles you until you do something about it. Unfortunately it looks like it might be the lower yellow rail that is out of line - the gap between the two lower yellow rails is slightly wider on the right than it is on the left. Fix that though, and the gunports might start to look out of whack. I'd be tempted to leave well enough alone. For me it doesn't detract from a fine looking model.
Derek
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
Link to comment
Thanks! I think you're right and I am going to see if I can leave well enough alone. I really wouldn't want to "fix" it and create a ripple effect.
Link to comment
I'm hard pressed to see what the problem is.  It looks really good to me.
—MICHAEL ROSE
Link to comment
You are doing a really nice job mate  - the whole thing looks splendid  - tidy, colourful  and a  very attractive build.
OC.
Current builds
Completed works.
Link to comment
You’re too kind, and I’m not going to highlight it further 😁.
Thanks! I’m really enjoying it; it feels like slow going but every piece adds up (and I’m starting to lose my fear of painting).
Link to comment
Learned about the mizzenmast as I continued to work on the Alert. I blackened the PE elements after shaping and drilled holes for the nails to prevent any issues with breaking the wood. I've been trying to clean up some paint from poor taping and for whatever reason it looks a lot worse in these pictures than previously; I'll probably try to clean it a little more.
DSC_1396_small.JPG.80e503bb624b9a88ce01f6ff879bead4.JPGDSC_1395_small.JPG.4f421cbff5ca61bab7973c0657142327.JPG
I've now started working on the catheads and I'm at a little bit of a quandry. The directions recommend airbrushing the PE that attaches to the catheads, but I don't have an airbrush. Is there recommended PE prep to brush paint it? Of course part of me wants to use this as an excuse to buy an airbrush but I really have a mental block about using them for some reason.
Link to comment
I'm not sure why airbrushing is recommended. Paint is fine if applied carefully (I use Admiralty Paints dull metal black for ironwork), otherwise I use a blackening solution such as Casey's Metal Black. BTW, I think your paintwork looks fine.
Derek
Cheers, Derek
Link to comment
Sorry I failed to describe it well enough, I use Casey's Metal Black for my blackened PE, but for the catheads (and them next for the decorative work), the PE is painted yellow ochre. I'll give it a go and see how it comes out.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
