Spitfire IX (Late Mark) by Old Collingwood - FINISHED - Eduard - 1/48
Your painting is fantastic OC, this spit's going to great.
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Share on other sites
Seat assembled - painted and weathered, then the belts  from the  enclosed pe  were cut off and glued into place,   then when set  I  did a couple of coats of brushed on flat coat,  then I placed the seat in the tub  and routed the rear harness  through the rear framework  and glued it in place.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Evening all,  hope everyone is ok  - keep up your spirits  we will get through this,     anyway  work continues  starting with the instrument panel,  this is a multi stage thing starting with the frame  - this has three sections of PE  to be attached to it, when  set I painted underneath and around the frame in Green, then I built and painted the compass, this was then glued in place  under the frame,   I then did a bit of shading with a pancil  and finished off by highlighting,    next off was to build the  gun sight  - this is a clear part in two sections, I glued both together  then painted around the frame.
OC.
Current builds
Completed works.
Link to comment
Nice sharp work......
Quote:
Link to comment
Thank you EG.
OC.
Current builds
Completed works.
Link to comment
2 minutes ago, rlb said:
OC,
The monstrous alligator clip in the previous post was a shocking reminder of the scale of this.  Nice work.
Ron
Thank you for looking in and  the compliment.
OC.
Current builds
Completed works.
Link to comment
That is some incredibly nice work OC Truly something to be proud of. Did you have something to use as a reference or did you just do it as you thought it should look?
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
coming along nicely OC.........is that a flat med green your using?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Hi Lou,   thank you for the kind words,    the  instrument panel  is made of  pre painted  PE  sections  -  a backing  piece  with the clocks painted on, then next the frontage with the dials  and last a center section,  after fitting them I dropped some semi gloss top coat onto the dials, superb craftsmanship.
OC.
Current builds
Completed works.
Link to comment
9 hours ago, cog said:
Got the same one somewhere in my stash. Looking good OC. I'll follow along, and see what surprises this kit has in store for the ignorant builder ;)
Thank you carl,  its great  having you onboard.
OC.
Current builds
Completed works.
Link to comment
Thanks denis,   its  RAF  Cockpit Green   straight out the jar  diluted  50/50  then  brush painted on.
OC.
Current builds
Completed works.
Link to comment
Looking good OC do I remember Airfix?was looking at another build on another forum MKXIV something about the seat and rib#11 which I think is behind the seat a fit issue for some builders so check and check again before the fit of the two halves. ;) Kevin
Eduard which I think is Tamy sail on ;)
Edited by Javlin
Link to comment
Thanks mate,    I have dry fitted  and it seams ok.
OC.
Current builds
Completed works.
Link to comment
thanks........ :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
A bit more progress to day  (boy I love the fit of this kit so far  - it  almost falls together)    next was to paint and fit the two pedals, quite straight forward  they pop in below the bottom frame,   next  I glued the other side to close up the cabin bath tub assembly.
After  putting this aside  - I woked on the two fuselage sides adding a few more fittings that were then painted and weathered, I thne did a dry fit  - all seems well  with the fuselage going together well.
OC.
Current builds
Completed works.
Link to comment
Beautiful work, OC.  That appears to be one impressive kit.
Link to comment
Thank you Mark,   very kind of you,    Im really impressed  in the accuracy of it  - very tight tollerances but it just fits well.
OC.
Current builds
Completed works.
Link to comment
Looking good, OC.
Seems if one has a problem with the fit of parts in these newer kits, the builder is the one in error. A far cry from the old kits we cut our teeth with, back in the day.
Ken
Started: MS Bounty Longboat,
Link to comment
55 minutes ago, Canute said:
Looking good, OC.
Thank you kindly Ken,   what stands out about the kit is not just the fit of parts but also the quality of the plastic, its has a more solid feel to it  yet in scale thickness.
OC.
Current builds
Completed works.
Link to comment
More progress  -  I closed up the fuselage  - will need a bit of tidy up on the seams, but it  went really well.
Pictures when I have cleaned up the seams.
OC.
Current builds
Completed works.
Link to comment
Hi all,    right  "Pictures-pictures-pictures"     I  did some light wet and dry sanding along the join seams (not a lot)    then It was time to start on the lower wing section,  this is a one piece unit  except for the wing tips,   fitted to this is a strut  and  weel well walls, these are made up in three sections each side, again very good fit and quality,  to aid strength I ran some glue around the outsides.
I thought I would include a pic to show the excellent fine detail on the bottom of the wing  - this is evedent all over the model.
OC.
Current builds
Completed works.
Link to comment
Coming along nicely, OC.  Nice to have minimal seam filling. Spitfires always look good.
Ken
Link to comment
Thanks Ken,    yep  Im really impressed by this kit.
OC.
Current builds
Completed works.
Link to comment
Just thinking a head  - I think I will mask up and attach the canopies tomorrow  as they will protect the delicate  cockpit parts  - gun sight etc.
OC.
Current builds
Completed works.
Link to comment
I Was thinking  (Steady on I might use my single brain cell) lol,   anyway  I have that other Spit kit  that is stashed in the cupboard  - I might see if its rescue-able to build a  RN Seafire from it  after I have built this  - "What say you shipmates"?
OC.
Edited by Old Collingwood
Current builds
Completed works.
Link to comment
Nice work so far OC. I have been back on a plastic kick a bit of late and there is a Mark IX creeping close to the top of my "to do" pile in my stash.
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
Link to comment
Go for it OC 😁
Current builds;
Completed:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
