Spitfire IX (Late Mark) by Old Collingwood - FINISHED - Eduard - 1/48
29 minutes ago, jwvolz said:
Nice work so far OC. I have been back on a plastic kick a bit of late and there is a Mark IX creeping close to the top of my "to do" pile in my stash.
Join the club Joe  - would love to follow your build.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
7 minutes ago, Edwardkenway said:
Go for it OC 😁
I will have a look in the box later 🧐
OC.
Current builds
Completed works.
Link to comment
OC.
I shall for sure.
Just have two jets on the bench to finish before then. One should be done today.
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
Link to comment
Evening all,
Right as I said earlier - I dragged the other Spit kit out (That I had stashed in the cupboard  as I messed it up)   I had a look over it  and think with the confidence from building this, I should be able to salvage it  into a Seafire  Mk3.
OC.
Current builds
Completed works.
Link to comment
9 hours ago, cog said:
You should add one of these ...
That looks sweat mate.
OC.
Current builds
Completed works.
Link to comment
Evening all,
A bit more work on the Spit this eve,  I painted the insides of the wheel wells then weathered  them,  then I dry fitted the wings to the fuselage  to check the fit  - Impressive.
The wings are not joined together yet (top and bottoms)
OC.
Current builds
Completed works.
Link to comment
13 minutes ago, cog said:
Looks rather good, OC. No detail up whatsoever?
Yep the join lines are really tight with regards to the tollerances, I thought the join where the wings meet the fuselage might needs some work - but straight  on even with a dry fit  - they fit fine  no filling  I dont think.
OC.
Current builds
Completed works.
Link to comment
More progress  this evening  -  I glued the two wing sections  to the main lower wing,  then I glued the  whole wing assembly to the fuselage,  when set  it needed just the smallest amount of filling with  plastic putty  and a bit of clean up.
OC.
Current builds
Completed works.
Link to comment
It's taking shape! OC.👍😊
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Thank you Edward,   I'm very happy how its coming a long  - it even feels solid  (in a plastic kind of solid way)
OC.
Current builds
Completed works.
Link to comment
I'll have to look this one up....how much modification will you need to do?  your progress is looking super :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
When I do the Seafire  conversion out of the other kit?
OC.
Current builds
Completed works.
Link to comment
31 minutes ago, Canute said:
Is this an E wing, OC?  Clipped or normal Spitfire wingtips.
Its got to have its  normal wing tips on it yet Ken, it comes like that giving you the option as they are in the box  - three types of wing tips I think.
OC.
Current builds
Completed works.
Link to comment
A bit more progress   - no work done in the day time as we were sat out  enjoying that weird bright ornage thing in the sky,    so  I decided to  work on the cockpit glazing,  this is in three sections due to me having the cockpit  open,  first I cut away the front  section and after tyding up the edge I fitted some masks  that came in the kit, this was a three part mask - I then glued it in place and  set it down using the dryer,  next was the rear section  - again tydy up and masked  using two masks, this was then glued down/heated, last was the sliding section  - this had the same prodecure, but it stays off till the last stages of the build.
Thank you all for the interest people are showing in my build.
OC.
Current builds
Completed works.
Link to comment
Nice work.... Usually I just close mine up cause I'm not that good at cockpits. Impressive work....
Quote:
Link to comment
Thank you EG,   credit to the kit as its Superb   best I have ever built.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Link to comment
Plan for today  (later)   there is still a hairline gap where the wings meet the fuselage  so I will work some plastic putty into it,    then I will either attach the rudder stabs and Rudder  or  the wing tips  (depends what I fancy doing first).
I know I keep saying it  - but I really recommend thses Eduard kits  they are simply first rate  in every way.
OC.
Current builds
Completed works.
Link to comment
Outstanding work on what appears to be an outstanding kit. They even have an arrow embossed inside the fuselage so we know which way to fly🛩️
Seriously, very well done, enjoying your progress.
Cheers
Cheers, Harley<p
Under Construction:       USS Curtis Wilbur DDG-54 1/200 by ILoveKit
Completed:                     F-35A 1/48 by Tamiya
                                        USS Atlanta CL-51 1/350 by Very Fire
                                    Liberty Ship John W. Brown 1/350 by Trumpeter
                                    HMS Spiraea K-08 1/350
                                    USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                  USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                  USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                  USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                  USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                          Brig Syren 1/64 Model Shipways, Wood
Started,On Hold:     Frigate Confederacy 1/64 Model Shipways, Wood
Link to comment
I'd second OC's recommendation, based on reviews I've read over the years. And their PE instructions.
Ken
Started: MS Bounty Longboat,
Link to comment
One must remember that Eduard does not make any of their own kits. In this case the plastic part of the model is the old Airfix kit that has been updated and refined over the years and PE added by Eduard.
I have their JRS-1 seaplane in my stash and it also looks like it is a very nice model. But again it is a carry over from another manufacturer, in this case Sword.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
8 hours ago, cog said:
You are positive, you do not get commision on UK sales???
Yep  - but deffo a brll kit.
OC.
Current builds
Completed works.
Link to comment
Cheers
No thats where the Bow  goes  with the Arrows 😉   But thank you for the compliment.
OC.
Current builds
Completed works.
Link to comment
Evening all   hope all are well  and not going too nuts yet,
I spent another hour or so on the Spit, I decided to make the stab frames / stabs and rudder,  quite straight forward with minumum fuss,  I decided to droop the stabs and give the ruidder a bit of angle.
OC.
Current builds
Completed works.
Link to comment
Your work looks good, OC.  And working on the prettiest fighter of WW II doesn't hurt either. 😁
Ken
Link to comment
Thank you Ken.
OC.
Current builds
Completed works.
Link to comment
Later today  (yep I know where does the time go)   I will check the join where the Stabs meet the fuselage  and fill if needed,  then I think it will be wing tip and Aileron  fitting time, I will  probably keep the Ailerons level  as I dont think they are  gravity  enduced  so wont droop  on power down.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
