Spitfire IX (Late Mark) by Old Collingwood - FINISHED - Eduard - 1/48
nice progress so far OC........not understanding the significance of tilting the stabilizer ailerons downward for the rudder,  as they are shaped to allow for it.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Share on other sites
Just a bit of builder artistic license  denis  - think it looks better  that way.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
They were cable operated with a spring on the control stick to keep the stick basically centered, with serious usage the spring would relax a bit and allow the elevator, (horizontal stabilizer control surfaces) to droop a bit... The rudder would lie whichever way the rudder pedals were last touched as they were a push pull configuration and the ailerons on the wings would twist on the same basis depending on the side the stick leaned towards.... I'm not remembering exactly when they went to hydraulics on the Spit, but that was the case with the early built birds. But when they did go to hydraulics, the elevator droop would become much more pronounced as the hydraulic pressure bled off.....
Separate control surfaces in the kit allows this mechanical habit to be modeled accurately
Edited by Egilman
Quote:
Link to comment
I am doing mine drooped stabs  slight rudder turn  and  level ailerons   with the  flaps in there locked up position (these are molded in with the lower wings)
OC.
Current builds
Completed works.
Link to comment
16 minutes ago, cog said:
You're building a late Mk IX, chances are it has hydrolics for those functions
I  thought about  building it with everything flush  but thought it would be more interesting with  things drooped.
This pic off the net shows a powerd down spit with stabs drooped and some movement of the rudder.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Link to comment
If they were tied down at night or for any period time, the ailerons, rudder and elevator would also be tied down.  If not, they'd flop about when the wind blew.
Link to comment
Yep  I  relate to that mark, I have even seen then use  small wooded chock blocks  on aircraft moving surfaces in museums  for the same reason I guess.
OC.
Current builds
Completed works.
Link to comment
Sometimes they'd put control locks in the cockpit to prevent the surfaces from flopping around. Big old red painted locks, so the tyro pilot couldn't miss that part. ;)
Ken
Started: MS Bounty Longboat,
Link to comment
Good evening all   hope your all in good health,      right then  I did  another hour on the spit,  firstly  I fitted the two ailerons  straight forward  procedure, then I fitted the wing tips  - again glued straight on with no fuss,  what amazes me is the scale cord  thiness  of the wings  just like the real thing.
OC.
Current builds
Completed works.
Link to comment
Looking good my friend.....
Quote:
Link to comment
Thank you kindly EG.
OC.
Current builds
Completed works.
Link to comment
5 minutes ago, James H said:
Nowt wrong with that! 👍
Thank you James,   she is a Beautiful  kit   very accurate and goes together so well.
By the way  Thank you for creating this section  - it is becoming so popular with so many  lovely builds.:cheers:   I mean - you should pass on to Chris.
OC.
Current builds
Completed works.
Link to comment
24 minutes ago, jwvolz said:
Looking good!
Thank you  Joe,   keep up the good work on yours.
OC.
Current builds
Completed works.
Link to comment
I must do a bit more later today,  I decided to have a lazy day infront of the box  watching some chill out tv shows last night,    I will have a general check  over the bits I last fitted  than will probably work on the exhaust systems, these even have hollowed out pipes  so they will be blacked inside then after fitting I will paint the outsides in a rusty bronze colour I will make up from mixing flat alum  and some red ocre  (same as I did on the Mossie  exhausts)   then I will be able to glue down the engine cover I made up the other day.
OC.
Current builds
Completed works.
Link to comment
Good day everyone  hope all are well,     I decided to do a bit more this afternoon  as the weather was pants  with light rain  so no sitting in the back patio,  so  I decided to work on one of the exhaust manifolds  - this is built up using four sections,   after assembly  I painted the insides of the exhausts flat black  then I made up a bronzy type colour by mixing flat black/flat alum  and red ocre,   then after drying  with my friend  "Harold hairdryer"  I glued it in place iniside the forward bulkhead, then I dry fitted the engine comp cover.
OC.
Current builds
Completed works.
Link to comment
Those are nicer than the ones in the Hasegawa kit, which are solid, and they'd be a real pain to hollow out evenly. I'd have to go resin to get that look.
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
Link to comment
Yep  its a good move by Eduard to make them hollowed out  -  I can imagine the effort to try to hollow them out by hand  (enter cross eyed emoji)
OC.
Current builds
Completed works.
Link to comment
10 minutes ago, BLACK VIKING said:
Lovely work OC love the exhaust.
Martyn
Thank you Martyn,   very kind of you to say.
OC.
Current builds
Completed works.
Link to comment
Just putting the exhaust on makes it unmistakably a Spit!😃
Edited by Edwardkenway
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Just now, Edwardkenway said:
Just putting the exhaust on makes unmistakable as a Spit!
Thanks mate.
OC.
Current builds
Completed works.
Link to comment
Bit more progress  -  the other exhaust was built and painted  then glued in place, then I glued down the top cover.
OC.
Current builds
Completed works.
Link to comment
1 hour ago, CDW said:
Coming along beautifully OC. I just found your build thread, by the way.
I wonder if the exhausts are from Moskit. The company used to make hollowed metal exhausts just like those, for a number of different aircraft.
Hiya mate,   thank you for the compliment,   I'm not sure about the exhausts  - guess  it is quite unusaul for them to be this detailed with in a kit, in the box there is a choice of two different sets of exhausts I guess for early or late - if not a different  model of Spit.
OC.
Current builds
Completed works.
Link to comment
Evening all  home inmates,    I did  a bit more on the spit this eve  as I was in the back yard enjoying some nice but cold sunshine  from that strange thing in the sky,    so first thing  I ran some putty into that gap where the top engine cowl meets the forward fuselage,  then it was time to construct the bottom cowl at the front, this also has a pe vent filter  fitted inside  (fiddly with limited acsess)  after cleaning the join seams (slightly)  I then glued it in place.
No pics as I will wait till I have cleaned up the join seams where it meets the fuselage.
OC.
Current builds
Completed works.
Link to comment
No progress or pics folks  (sorry)   I was in the back yard all day  getting some vit D off the sun,   then after supper I fell asleep  in the chair  and was too late when I woke up,  think the fresh air and sun made me tired.
OC.
Current builds
Completed works.
Link to comment
Good for you! The wife has been suffering from cabin fever the last few days but she is getting ready for some sun also..... (except the pollen is driving her nuts)
Quote:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
