Spitfire IX (Late Mark) by Old Collingwood - FINISHED - Eduard - 1/48
Hi all,
Right  I finished off the masking  and  checked it over a few times  -  then I took it outside and gave it a few coats of RAF Green,   its currently in the cupboard  with the Seafire  de-gasing.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Evening all,    I got round to de-masking the IX  today   - it didn't turn out too bad, the green areas are now ok,   as I want to shown a well used version with ware patches  and paint fading  - I decided to add these areas now,   the Grey also needed touching up  but first I had to mix up a shade as close to the rattle can Grey as possible   (this isn't easy as we know)   I reached a shade as close as possible,  when this has fully hardened I will buff the finish to get a satin scheen.
OC.
Current builds
Completed works.
Link to comment
That came our really well OC.  Excellent job!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Thank you mike.
OC.
Current builds
Completed works.
Link to comment
Another really nice bit of painting OC .
I like the blue tac idea for masking
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Thank you Edward.
OC.
Current builds
Completed works.
Link to comment
Hi all,   some more progress on this tonight   - not a lot of content  but time consuming,  I have been panel marking using my  adjustable  draftsmans pencil  (the type with the led you push out when the end breaks)  anyway  the system was to run the pencil then using a wet finger and a cloth clean as I go   - seems to work quite well and is a tidy way of doing it.
OC.
Current builds
Completed works.
Link to comment
Evening all,  in between  working on the Seafire  I decided to have a go at decaling the Spit,   the decals are a case of  "Rob bill to pay Ben"   some have a few marks  but hopefully  they will all settle down when a top coat is  sprayed over.
I also masked and painted the Yellow wing leading edge bands  and Red  gun bands.
A group pic also  showing the difference between the Two.
OC.
Current builds
Completed works.
Link to comment
24 minutes ago, jwvolz said:
Very nice OC!
Thanks Joe,     they are a labour of love those Two   - trial and error  to get them  right,   and like the admiral said to me  yesterday     "No cursing today"
OC.
Current builds
Completed works.
Link to comment
Hi all,
Another  step forward  - the squadron code and serial are on.
OC.
Current builds
Completed works.
Link to comment
Looks fantastic, really nice job!
Mike
Link to comment
Thank you kindly mike.
OC.
Current builds
Completed works.
Link to comment
It's coming on great OC, the decals make a big difference in the look.
Current builds;
Completed:
Link to comment
Thank you Edward,  I was thinking the exact same thing  - kind of  empty without the decals.
OC.
Current builds
Completed works.
Link to comment
here in the states,  we rob Peter to pay Paul ;) ....all means the same though.   the spit is looking great........the camo and decaling really makes the difference  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Evening all,   I decided to make a pilot for the Spit  out of my other figure/parts set, he is assembled in a pose where he is climbing into the cockpit.
OC.
Current builds
Completed works.
Link to comment
Evening all,   I did a bit more on this today  - firstly  I took a few bits outside and sprayed them and  put them in my tub to dry,  next job was to attach a small bit of pe onto the cockpit door, this was then painted/highlighted  and fitted,  after  I carried on doing some decaling work  from the  tail flash  to the lower roundals  and a few smaller ones.
OC.
Current builds
Completed works.
Link to comment
Nice, it's gonna be beautiful brother when your done....
Quote:
Link to comment
Thank you kindly,  like I said to my admiral  earlier  - they certainly have thier own identities  all Three planes.
OC.
Current builds
Completed works.
Link to comment
Evening all,   a bit more progress  - I have masked the  rear quarter and front cockpit glass  (ready for top coat - later)   then I  worked on the main u/c units, very nice jobbies by Eduard  - lots of detail  and nice construction,   the wheels are sepaerate from the hubs  and sepaerate  oleo's / covers,  after  assembling and painting  then fitting together,   I then fitted Two pe  outer covers  and painted these.
No pics  (I foregot  till I started writting this)
OC.
Current builds
Completed works.
Link to comment
I think we’ve all “been there, done that!” OC.  We’ll just have to look forward to seeing updated pics next time.
Link to comment
Thank you Grant.
OC.
Current builds
Completed works.
Link to comment
gett'in pretty good with painting the figures  ;)     look'in sweet!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you Denis,   good practice for my other project when I start it.
OC.
Current builds
Completed works.
Link to comment
Evening all,   hows the popcorn going?     today was a milestone as she now sits on her wheels,   I also worked on the prop/spinner assembly  - it needed zero clean up  just painted then when each part was dry I put it together,  after I applied a few decals  tipped the ends  with yellow after masking, then glued it in place.
Just noticed in the pics a couple of writting decals  have come away on the props - must sort that.
OC.
Current builds
Completed works.
Link to comment
Smart looking spit OC. The French at Le Haye Sainte won't know what's hit them!!!😉
Current builds;
Completed:
Link to comment
Thank you Edward.
OC.
Current builds
Completed works.
Link to comment
Looks OC.   Unless this bird is factory fresh, I wouldn't worry about the prop decals that came off.   In real life, they didn't last long.
Link to comment
Thanks Mark.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
