Medway Longboat 1742 by Diver - 1:24 Scale
I have been working on the boat lately. Definition of insanity, doing the same task over and over, expecting a different result. Six attempts at the forward platform and finally changed my approach.  Am happy with the fit so far although I must get it to good a little lower. The rear platform is a little easier but still has to go a little lower.
Link to comment
Share on other sites
Link to comment
Your longboat is really coming along nicely, Bob. Nice job!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
On 2/15/2023 at 7:33 AM, Freebird said:
Diver,
You can use isopropyl alcohol. Just dab alcohol around the joint and let it soak in for a few minutes. It’ll soften the glue. It may take several tries.
Best Regards …. Rick
Thanks for the advise.  I purchased a small bottle of lock de-icer (isopropyl) and it worked fine.  I have removed the piece and have a new one installed.  The very small bottle of lock de-icer worked well due its very small nozzle. It was easy to control.  Thanks again
Link to comment
The rear cockpit is complete and glued in place.  The thwarts are all glued in except the one fore the mast.  The grapples and sheave for the stem are complete.  I started on the knees and realized the front thwart was not installed correctly. It was removed and reinstalled. I am apprehensive on starting the capstain, do not want to mess it up. I ordered some v blocks to hold it when I start to shape it.
Link to comment
5 hours ago, Gus M said:
What is the scale on your boat? I found on Anazon one in s 1:48 scal, but I don't see any compilación in this scale
the scale of my Medway  is 1/48.  The kit was purchased from Syren Ship models, designed and manufactured by Chuck Pessaro.  A challenging but rewarding plank on frame build.
Link to comment
4 hours ago, Diver said:
Now I am confused.  In the header for the Medway group project it says 1/48.
The header does seem to have the wrong scale there, but if you look below at all the build log titles, nearly all of them include the scale in the title - either 1:24 or 1/2” (same thing). And Chuck (the kit designer and manufacturer) has given you the definitive answer as well.
Link to comment
5 hours ago, Chuck said:
Its 1:24 actually.
Well, I confusión with this
Is 1/24 or 1/48 this one?
Model Expo - Model Shipways 18th Century Longboat 1/48 scale https://amzn.eu/d/iPH2Rk3
This other one is 1/24, but the price is 183.82 €
Model Shipways 18th Century Barco Largo Armado Escala 1:24 – Cortado con láser Madera, Metal y fotograbado latón Kit https://amzn.eu/d/aGGM6EU
Right now I'm confused and don't know which one to buy.
 PS I also found the SYREN...a beauty
Edited by Gus M
Greetings
Gus
Current build log:
San Francisco Cross Section
Link to comment
This Medway longboat is 1:24
The Model Shipways version is 1:48….a tiny little thing.
Two different models.
Link to comment
Thank you @Chuck in this case,  i buy the 1:48 scale
Greetings
Gus
Current build log:
Link to comment
We have finished our move to what we hope is our final home.  I have set up my work space in the spare bedroom an have got back into the build.  The capstan and mast thwarts are not glued in yet.  I am going to make the mast first, and can use the thwart as a reference for the diameter.
Link to comment
Your Medway is coming along nicely, Bob, and your workspace looks good too. I have a very similar workspace in the spare bedroom with a small desk in front of a window that looks out onto the backyard. I envy those folks who have large work areas and room for all their tools and machines.
Bob Garcia
Current Builds:
Link to comment
  • 3 months later...
Had an accident in the shop.  I recently got the rudder and tiller done, only to drop something and brake parts of it off. I have managed a fix, and only on close inspection can you see it. Have ordered a draw plate from Byrnes and will use it for the  thole  pins.  The mast thwart is still not glued in, I will finish shaping the mast first.  That will pretty much finish chapter four other than the oars
Edited by Diver
spelling mistake
Link to comment
Ever since I purchased this build I have been apprehensive about doing the mast.  Over the last few evenings the square stock was shaped and sanded as per Chucks instructions and this is the final result. In my opinion it has turned out well.  Just have to do some touch-up sanding and painting.  The one thing I would do differently is I would not have done the metal work for the mast thwart until the mast was made to size.  It would have been easier to size the metal to the mast.
Edited by Diver
just an added line
Link to comment
