Finished - 1931 Cadillac by CDW - JoHan - 1:25 Scale
CDW
36 minutes ago, Landlubber Mike said:
Craig, sorry to clutter your log, but here is another discussion on wire wheels - this time used in the context of the old Hubley metal kits (I have a few kits in the stash and was browsing the web in them this morning).
Having wire wheels true to scale seems well worth the effort to make a beautiful car model as the plastic wheels are way out of scale:
http://www.modelcarsmag.com/forums/topic/86613-118-duesenberg-wire-wheels/
Don't feel bad at all...I love this kind of discussion. I learn a lot from it. I wish these guys didn't put their photos in photo bucket. It demands we turn off our ad blocker to view them and I don't like to do that.
Link to comment
Share on other sites
The engine parts were cut off the sprues, then the chrome parts were soaked in Super Clean to remove the chrome plating and clear lacquer.
The engine block and transmission were painted with Tamiya flat black before dry brushing with Mr Color aluminum.
The literature on the Cadillac V-16 indicates the intake and exhaust manifolds were ceramic coated, black. The cylinder heads were black. I've painted the cylinder heads with Tamiya semi-gloss black. The intake and exhaust manifolds were first painted with acrylic flat black, then a treatment of AK gun metal was applied. The AK metal colors in the tube come in various metal colors. They are in a wax base, applied with a brush. After application, they are buffed to achieve a glossy finish. This was the best way I knew of to try and capture the glossy, shiny, look of the manifolds as well as provide some contrast with the black cylinder heads.
Link to comment
OUTSTANDING!....
Quote:
Link to comment
off to a great start Craig! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Craig, does AK metal do a burnt metal of titanium? Thinking jet exhausts.
Ken
Started: MS Bounty Longboat,
Link to comment
No, unfortunately they do not. Here is their line of wax based metals:
https://www.scalehobbyist.com/catagories/browse.php?kw=ak,true,metal
But they do have a pale burnt metal in their enamel line of metal:
https://www.scalehobbyist.com/catagories/browse.php?kw=ak,xtreme,metal
Link to comment
nice! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
That looks fantastic!
Just out of curiosity, do you need to put a clear coat over it, or does the wax-based application help protect it?  I'm working on a car model now, and I noticed that they recommend using flat colors for some engine parts and gloss colors for other parts.  If i put a gloss coat on to weather, it seems like everything would become gloss.  Seems like this AK stuff would allow one to keep some parts flat and some parts more glossy.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
That engine looks super.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Most of the metal treatments need a clear coat to protect them over time. It's better to wear a latex glove when handling the metal treated parts before the clear coat. On small items, I paint on the dull coat with a brush after the gloss coat and weathering has been done. Larger areas can be airbrushed. Even smaller areas can be airbrushed if you have gained that level of control with your airbrush.
Link to comment
Considering the molds for this model were tooled in the sixties, the detail was great for that day and time. Even the way JoHan engineered the plastic sprues to fit inside the box was remarkable. If you took the part sprues out and couldn't remember how they were oriented, you could not possibly get everything back inside the box. It wouldn't fit.
Link to comment
For this model finish, I will be using Mr Surfacer 1500, reduced at a ratio of 1 part paint to 8 parts reducer (Mr Color leveling thinner), applied in light coats and lightly wet sanded between coats until I am satisfied it is ready for finish paint. Createx Pearl Green for the main color on body, frame, and wheels. Createx Black for the running boards and fenders. Createx is an acrylic paint that must be applied in very light coats. It dries in a flat finish. It's reduced to a ratio of 10 parts paint to 1 part reducer. No Name Gloss Coat will be used to seal everything and give it a deep deep clear glossy shine. The clear coat is mixed 2 parts clear to 1 part hardener and 1 part reducer.
DSCN3641.thumb.JPG.d9f943bf64477eabeb20e9391689edb0.JPGDSCN3642.thumb.JPG.d5d7bcdd98185612f2999d706879a21c.JPGDSCN3643.thumb.JPG.931d3996cfbe047ac8ff6f066c6db256.JPGDSCN3644.thumb.JPG.f316fc9744151410f26bf92c79651b94.JPG
Link to comment
engine looks superb ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Looking good Craig 👍😉
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
nice looking chassis and drive train  ;)     looks very good!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
That looks spot on brother, what paint are you using for the semi-gloss on the frame, it couldn't be any closer to real..... the exhaust looks like it came from the shop down the street.... I'm gonna have to go ask if they really do miniature cars....
I've got a packard boattail speedster build in my near future, something the wife really likes and to replace the one she lost when we moved into our current home.....  that paint would be perfect.....
Quote:
Link to comment
Great job with the paint. Like EG says, looks real.
Ken
Link to comment
Really nice work craig,   it reaslly does look the business.
OC.
Current builds
Completed works.
Link to comment
Link to comment
2 hours ago, CDW said:
Thanks Edward. Hope you and your family are doing well during this time of chaos.
We're all ok though not seen my daughters or grandkids for over a week (apart from video calls).
Hope everyone is doing well with you also.
Stay safe and keep modelling 👍😊
Current builds;
Completed:
Link to comment
3 hours ago, CDW said:
Thanks OC. I seem to be having more difficulty concentrating on model building for all the news that's going on right now. Hard to do both things at once.
I hear you mate,   the media doesn't help  - if anything its making things  feel  worse, I try not to watch any of it,   try to stay focused on  coming on here keep your mind off  the madness   that  the  world has created.
OC.
Current builds
Completed works.
Link to comment
As everyone has said already, things are looking right on Craig. Are you going to go for showroom fresh?
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Sounds like you are panting the one in the garage :P Looking very Nice CD ;) Kevin
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
