US Brig Syren by WalrusGuy - FINISHED - Model Shipways - Scale 1:64 - Second wooden ship build
17 minutes ago, Overworked724 said:
What are you using for the ribs???
I'm using the supplied 1/32"x1/32" basswood strips. They definitely need some care when bending them to avoid creases or snapping them
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
Link to comment
Share on other sites
Thank you Thomas and Steven for the compliments!
Today I finished installing the floorboards. These things really transformed the look of the boat. They were a bit tricky to glue because of the curves and bends. I used CA glue on the ends and the wood glue in the middle.
Edited by WalrusGuy
Current:
Complete:
On the shelf:
Link to comment
You are very correct on bending the ribs but the finished job looks great. Very nice spacings and the floorboards look extremely nice. Great job. Just a note I started to work on the longboat as a break and hadn't dry fit the furnished stem, keel and sternpost only to discover that i'd not shaped the bow in the radius of the furnished stem. So to fix the problem I used Sculpey to copy the bottom and used it as a pattern to make my own stem, keel and sternpost. I'll post the results when finished.
Beautiful job.
Stay well and stay safe
Will :pirate41:
Erycina 1882 Fishing Trawler by Vanguard Models 1:64 scale
Syren by pearwill Model Shipways 1:64 scale
On Hold:
HM Cutter Cheerful  Syren Shipmodel Scratch 1:48 scale
1776 Washington Row Galley scratch scratch from NRG plans #121  1:48 scale
Completed Build:
Charles W. Morgan by Artesania Latina circa 1988, Lowell Grand Banks Dory 1:24 scale by Model Shipways, Norwegian.Sailing Pram 1:12 scale by Model Shipways, Muscongus Bay Lobster Smack 1:24 scale by Model Shipways
Link to comment
Beautiful job.
Will :pirate41:
Thanks so much Will! I think others also had the same issue with the laser cut parts. I still have to dry fit mine to see if it fits, otherwise I plan to scratch my own ones
Current:
Complete:
On the shelf:
Link to comment
Some more progress with the longboat, I installed the gratings, thwart supports and thwarts. The supports were again a bit tricky to install, and had to use CA glue in some spots
Edited by WalrusGuy
Current:
Complete:
On the shelf:
Link to comment
Thanks so much for the encouraging words Thomas and Bob!
The windlass has been carved and installed. And I also painted the top section black before I stick the moulding strip
Edited by WalrusGuy
Current:
Complete:
On the shelf:
Link to comment
20 minutes ago, Overworked724 said:
Beautiful work!  I’m amazed you were able to sand the shell so thin. I was terrified of going through!
There was one spot where I sanded it too much and could sense it would flake if I put a bit pressure. But now after painting and adding all the details it should be ok! 😁
Current:
Complete:
On the shelf:
Link to comment
I finished with the cap rail. The laser cut one did not fit well, so had to scratch it from a sheet of basswood:
Next I'll be cutting out the keel, stem, and stern posts since the laser cut ones also don't fit nice
EDIT: I realize I may have to thin down the cap rail a bit more. I'll try and will post additional photos
Edited by WalrusGuy
Current:
Complete:
On the shelf:
Link to comment
I sanded the cap rail a bit. I don't think I can go any more thinner than this
20201218_222753.thumb.jpg.7e15063acb627888a51d0d20778eb2d0.jpg20201218_223037.thumb.jpg.f04fb8fe3ff1ad89cc39ec0e52467cea.jpg
Edited by WalrusGuy
Current:
Complete:
On the shelf:
Link to comment
9 hours ago, captain_hook said:
A very.beautiful add-on to your already nice Syren!
9 hours ago, clearway said:
niceeeeeee😉
Keith
9 hours ago, NovaStorm said:
Awesome job!!!
Thanks guys!!! 😊
Current:
Complete:
On the shelf:
Link to comment
Longboat is almost done. I finished cutting out the keel, stem and sternpost from a basswood sheet. I also painted the rudder:
I pre-bent the molding strip prior to installation. It was still very tricky to glue it and used CA glue in many parts for a quick set. I just hope it doesn't break apart after some time 😅.... It needed some intense bends especially at the bow...
Some shots of where the boat is at now:
Edited by WalrusGuy
Current:
Complete:
On the shelf:
Link to comment
Th longboat is amazing, great work!
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Well done.  The ship’s boats are a bigger challenge building than the ship, you’ve done a really nice job with it.
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
That beautiful longboat could be a stand alone model all by itself!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
Thank you so much for the nice comments!! It's very much appreciated. Also, thanks all for leaving the likes and looking in! It really motivates me to do better! 😄
Slowly approaching the finish line for the longboat... The knees, bowsprit step, and splash guard have been installed. For the knees I cut out triangular pieces which were then shaped with a round needle file..
Only thing next are the gudgeons and pintles, oarlocks, shaping the tiller, and the oars themselves (which I am hoping to complete for my next post). So yes, lots left to do 😅
Edited by WalrusGuy
Current:
Complete:
On the shelf:
Link to comment
On 12/21/2020 at 2:32 PM, abelson said:
Really fine detail.
23 hours ago, NovaStorm said:
Great set of pics. Looking good ~
16 hours ago, KHauptfuehrer said:
Super clean craftsmanship.  Congrats!
16 hours ago, Eugenio Treviño said:
WalrusGuy:
The boat is amazing!!! I love all the detail you put in it.
I wish you all the best for Christmas and the New Year !
Keep up the great work !!!
Thank you for the compliments! Also wishing you all Happy Holidays and a Merry Christmas!
Current:
Complete:
On the shelf:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
