Alfa Romeo Spider Gran Touring by gjdale - FINISHED - Pocher - Scale 1:8
8 hours ago, gjdale said:
This is the stuff:
Many thanks, Grant. I just found some on eBay and ordered it.
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
Share on other sites
Ric - no primer/base is required at all. This was sprayed on bare plastic. Tests I’ve watched on YouTube show basically no difference if a black base is used first. I know that with the Vallejo Metal Colours, they call for a gloss black base primer, but this stuff just doesn’t seem to need it.
Link to comment
A Minor Update
I have decided not to install the body work until the steering wheel is in place, and I can’t do that until the centre hub arrives. This was ordered on Sep 08 and made it as far as Miami FL by Sep 09. There has been no tracking movement since, so I’m kinda stuck until the postal system works itself out.
In the meantime, I’ve finished off all the remaining small bits of work that I could.
First up, I decided to temporarily connect the Headlight wiring to test that to see if it works. As you can see in the picture below, it does!
The headlights are turned on by inserting the key in the dash as seen in the next photo.
The front horn assembly was next. This actually required the temporary installation of the main body panels and fender panels so that the cross brace could be fitted, and the ends angled to match the fenders. In the photo below, you can see the mixture of plastic and metal parts. It is nigh on impossible to discern a colour difference between the two materials.
The rear licence plate was then assembled, using an aftermarket decal from Model Motorcars for the rego number. It is held onto the fender with only two screws – the other two are dummies.
The front of the fenders are also fitted with small lights. While these parts look simple, there is once again a fit issue that requires some delicate work to rectify. Here they are installed:
The front nose was then assembled. Three additional decals from Model Motorcars were used here – one for the Alfa Romeo emblem and two for the radiator cap.
This close up shows that there has been some damage to the Alfa Romeo emblem. Fortunately, two were provided on the decal sheet from Model Motorcars, so I should be able to replace this one. The front side of the radiator cap has a St Christopher medal – a bit hard to see in the photo, but it’s there:
The back of the radiator cap has a temperature gauge, again in the form of a decal from Model Motorcars:
And that is as far as I can go until the Steering Wheel hub arrives…
Link to comment
Fantastic detailing, Grant! The Model Motor Cars "upgrades" are very expensive but the fine details they add seem to be worth it to me. I have no idea when I will attempt to build my model, but I have an idea that it will be the most expensive model I ever build after looking at all the model enhancements offered by them.
Bob Garcia
Current Builds:
Link to comment
Amazing work  - eye watering detail  - hat off to you sir.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Boy, that is just soooooooooo good. Amazing work!
Tom (MadDog) McQuiggan.
Member of Nautical Research Guild
Current Build : VAPORETTO MOTOBATTELLO VENEZIANO           Finished Build : AIRFIX 1930 BENTLEY
And Later On : PANART VICTORY BOW SECTION                           Finished Build : BILLING BOATS, ST ROCH
And Later On : EBBRO CITROEN DS21
HOBBIES : Amateur Radio : Motorcycling : Model Making : Painting/Sketching : FlightSims : Photography : Slave to none!
Link to comment
Lovely work, Grant.  If one didn't know it, they'd be hard pressed from the photos to tell model from the real thing.
Link to comment
Thanks guys,
Bob - yes, the Model Motorcars stuff is very expensive and one could easily spend waaay to much on “upgrades”. I think there are a few that are really worthwhile (like the steering wheel) and then there are a lot that one might question whether they are really necessary. And there will be differences between the various kits as to which fall into which category. Paul Koo advises making these decisions at the start of the build. Good advice - but if you have no previous experience, it can be difficult to know where to draw the line. It’s compounded for me because of the additional cost of postage each time I decide I want that extra $5 part, or you do as I did - buy the steering wheel and only realise later that you really need the hub to go with it! I might do a summary of “lessons learned” at the end of this build, including a summary of the “upgrades” I’ve done.
I look forward to seeing the start of your build Bob. If your other work so far is anything to go by, it will be an outstanding build to follow.
Link to comment
What a stunning build, i had never heard of them until this year then i read the build log by @kpnuts Ducati 1299 Panigale, a lot of work to achieve a wonderful result, i presume the Rolls will be the same
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Thanks Kevin,
Yes they do take a lot of work - but that’s half the fun! 😊
Link to comment
super progress Grant :)   where did you get the stand for the chassis?  did it come with the kit?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks Denis,
The chassis stands are an after market part from Model Motorcars. Quite expensive for what they are and I’m sure they could be made quite easily by most builders. I wasn’t sure how useful they would be but they are proving to be worthwhile. For my next one, I’ll probably make my own (if these don’t fit the other chassis).
Link to comment
i just had a look at the model motorcars, some nice expensive goodies in there, but just asking myself if the kit could have made better components in the first place
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
That’s possibly true Kevin, but keep in mind when these kits were made in the first place - about 50 years ago...
Link to comment
OOOOOOOOOOPS, i thought they were fairly recent kits
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Thanks Tony.
I just received notification from Australia Post that the parts I ordered from Model Motor Cars back on 08 Sep are due to be delivered today. I should be able to finally finish off this build on the weekend. 😃
Link to comment
The long-awaited steering hub has finally arrived, almost two months after ordering! All that was required for completion was to install the steering wheel, and then re-install the coachwork and complete the headlight wiring. I also replaced the damaged Alfa decal on the front nose. That took me no more than a few hours yesterday afternoon.  Today I did a final glam photo shoot. I would have taken the model outside for this, but it’s been raining here for the last two weeks and showing no sign of easing up. Had to settle for an indoor shoot instead. Here are the final results.
One final comment. This build would not have been possible without the guidance of the wonderful supplementary instructions and photos from Paul Koo. Here is a couple of photos to show the difference. The Pocher instruction manual is on the left: 26 pages, mainly of exploded diagrams. On the right, the 16 booklets of instructions and photo essays from Paul Koo, and that’s not counting the hundreds more photos of inventory parts, completed models, and reference photos.
Thanks to all who have followed along and provided encouragement and support. I hope you have enjoyed following the build as much as I have in doing it. Now I can focus on completing my Medway Longboat for a while.
Edited by gjdale
Link to comment
Wow, wow, wow! That is a stunningly beautiful model, Grant. Museum quality! Congratulations!
Your build log is a good as it gets also. Thanks, I've enjoyed the ride!
Bob Garcia
Current Builds:
Link to comment
Absolutely Beautiful!  I feel like I am looking at pictures of a full scale Alfa Romeo.  Your work is going to be a inspiration for future Pocher modelers.
Ryland
               - Nautical Research Guild
Link to comment
That’s a wonderful model.  You can be very round of it, as clearly it’s very much a work of craftsmanship.  And how wonderful that Paul Koo has shared the wisdom he has learned.
I know what you mean about the rain.  If this pitiless “drought” Continues I will have to seek bulk supplies of gopher wood and break out my cubit-stick.  (NOT taking two wasps though)
on second thoughts I may not need the cubit stick as I have two forearms anyway.  I know it’s confusing numerically, but I know how many arms I have.
Andrew
"Pas d’elle yeux Rhone que nous”
Kits under the bench: Le Hussard (Started in the 1980s)
Scratch builds:               Volante, Brig (R/C): Footy Drakkar "Rodolm" (R/C).  Longship Osberg (R/C)
Link to comment
Gorgeous work  - well done.
OC.
Current builds
Completed works.
Link to comment
Another classic, finished to work of art standard.......
Impressive execution of an impressive model....
Very well done......
Quote:
Link to comment
Wow! Great job! Looking at all the details for 15 minutes now.
Link to comment
Amazing work Grant!!  Very beautifully done!  Congratulations on a wonderful build!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Absolutely gorgeous work, Grant. Beautiful car and outstanding execution of all the details.
Ken
Started: MS Bounty Longboat,
Link to comment
What a beautiful motor!!
Excellent and exquisite workmanship!
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Grant, just out of curiosity, did you paint the body and fenders?  I wasn't sure if you went with the kit parts as is, or painted them.
Mike
Link to comment
Fantastic work Grant
Makes me want to hop in and take a tour of the fall countryside, rain and all.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
