Batavia by drobinson02199 - FINISHED - Kolderstok - Scale 1:72
Here's the first section of the main mast.  The supplied wood is basswood, so I had to stain it.
Regards,
David
David Robinson
Boston, MA area
Completed:  Constructo J.S. Elcano, Artesinia Latina Sanson, Dumas Mt. Washington, Bluejacket Nantucket, Amati Revenge, Artesania Latina  King of the Mississippi,
Amati Grand Banks Heritage 46, Amati HMS Fly, Amati Titanic, Dumas Chris Craft Commuter, Mantua Cutty Sark, Mantua Bruma, Kolderstok Batavia, Vanguard Models HM Cutter Alert, Caldercraft HMS Victory, Dumas USCG Fast Response Cutter
Currently Building:  Amati Bismarck
Link to comment
Share on other sites
1 hour ago, *Hans* said:
David, I'd like to make a small comment: the wood for the masts is beech wood 🙂
Hope you don't mind me saying this.
Hans, I don't mind at all -- want it to be right when I describe it.
For the benefit of other readers:  the quality of wood in this model is excellent -- as good as any I have seen in the best of other models I've built.
James, I'm not sure I understand your comment.  Other than the resin decorations, this is a fully wooden model.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Here's the completed main mast.  Many of the parts, such as the mast top shown in closeup, need to be hand-made following the plans.
I think my next step will be do to the shrouds on the lower part of this mast before moving on to the next mast.  That will put some variety in the build, and also help to forestall "repetitive shroud fatigue" later on.  😛
In previous ships I have attached the yards before doing the shrouds and stays, but I think I'll do it after the shrouds are up on this one and see how that goes.  Some concern about access, but we'll see.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Main mast shrouds up -- ratlines still to come.  I spent a lot of time getting my deadeyes to line up.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Finally finished the ratlines on the lower main mast shrouds.  Took a lot of time, which is why I haven't posted in a while.
Now for the foremast.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Futtock shrouds at the top of the lower main shrouds.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Foremast built and mounted.  The construction is identical to the main mast.
Regards,
David
David Robinson
Boston, MA area
Link to comment
I have found it difficult and frustrating to get the second deadeye in a shroud "loop" installed on the shroud at the right height to be aligned and yet create some tension on the shroud.  I've been getting it done, but lots of fiddling and trying.
This morning I tried a new approach, shown in the pictures below (because this site sometimes puts the pictures in a different order than I upload them, I have put a red sequence number in the lower right corner of each one).
First, after rigging the first deadeye on the shroud loop, rig the second one by itself before attaching it to the shroud, but don't tighten (Picture 1).
Then attach the shroud, test the height, and clamp it.  (Picture 2).  The hard part here is that you can't just pull up on the shroud end, because the deadeye will rotate.  So I had to hold the deadeye in place while testing the length of the shroud -- then clamp it and re-test by pulling the deadeye lines tight.  This was still much easier than trying to test the height while juggling the deadeye, before rigging it.  [Hope that's clear]
Then tie off the deadeye (Picture 3), and pull down the deadeye rigging until it's at the right height according to my jig (Picture 4),
Picture 5 shows them lined up.
There is probably an even better way to do this, but this works a bit better for me than trying to align the deadeye height and then clamping and attaching it, and then rigging it.
On earlier models, I was so concerned about the alignment that I did the shrouds individually rather than using a two-shroud loop (which is much better).
Regards,
David
David Robinson
Boston, MA area
Link to comment
Finally finished the foremast shrouds and ratlines.  Goes slower than I recall from other ships -- possibly because I'm tying the knots correctly on this ship!  :piratetongueor4:
Regards,
David
David Robinson
Boston, MA area
Link to comment
Finished the bowsprit (see pics), which is really interesting with the small mast & shrouds at the end.
I was looking at this and thinking about the spritsail, which on the real ship must have put a lot of torque on the sprit in high winds.  Looking at the rigging plans, I don't see a lot of side bracing, but I may not be looking closely enough.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Built the mizzen mast and completed the lower shrouds and ratlines.
Now I have 5 more double sets of shrouds and ratlines to do before moving on to the stays.  :o
Regards,
David
David Robinson
Boston, MA area
Link to comment
Started working on the upper main mast shrouds and ratlines.
One issue with these is that the lower deadeye in each pair is mounted with thread, which leads to a lot of swivel.  That in turn leads to upper deadeyes that are aligned vertically, but that don't face forward uniformly.  That is shown in the "before" closeup pictures.
The way I solved this was to carefully install the first ratline by aligning each shroud and then gluing the ratline knot before going to the next shroud.  That got the upper deadeyes to face mostly forward as you can see in the "after" closeup pictures.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Main mast upper shrouds and ratlines done.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Midmast shrouds and ratlines completed.  Now just need to get two tops.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Finally, all shrouds and ratlines done.  I looked back at my log, and I've been working on shrouds and ratlines for 3 months!  That's not so much a reflection of kit difficulty as it is my slower work pace (I've been reading more during the pandemic).
One tip for others:  the deadeye holes are very small, and a thinner line is needed for those than what's shown on the plans.  I used some leftover thin white that I had from a previous kit (Revenge).
One thing about that white line is that it leaves a sloppier tie-off than I would like (someone with better skills would have done it better).  So I decided to dress those tie-offs with black paint, and the result is shown in before and after pics below.
Now on to the stays!
Regards,
David
David Robinson
Boston, MA area
Link to comment
Installed the mizzen mast forestay.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Now all 3 of the large forestays are done.  Work goes faster now that the shrouds and ratlines are done.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Installed crow's foot rigging at the top of each stay.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Completed all of the stays.  Now on to the yards, anchor, and stern light.
Regards,
David
David Robinson
Boston, MA area
Link to comment
David; you’ve created a beautiful ship. Thank you for the photos and explanations...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
Link to comment
Anchors on.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
