I can't access 'Planking Techniques' I keep getting "We could not locate the item you are trying to view."
Advice please.
Share this post
Link to post
Share on other sites
I assume that this means you are trying to access one of the files on the NRG resources page? Which one exactly?
Also, free tip: make your post title reflective of what your post is about -- you'll get far more hits that way.
Cheers!
Share this post
Link to post
If you are referring to the articles located here, then I can't identify the problem -- the links are working for me.
Share this post
Link to post
The links are all working for me as well however they have always had an alignment problem. Where the PDF icon on the left does not line up with the description/title of the file on the right. But if you count down to the correct one that you want it seems to be working just fine.
Share this post
Link to post
Curious if perhaps it was because you weren't logged in?  not sure if that would limit access, but whenever I get the page saying "we could not locate the item you are searching" it is usually because I am inadvertently logged out.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
