So  another spit on the go  - this time I am rescuing the ICM Spit IX  kit  and turning it into a Seafire Mk.111  as I believe they were basically the same  apart from a few mods that I should be able to create  - seam on the wing that would have been for the  wing fold, and scribing under the bottom rear to simulate the cut out for the arester hook,  I will also fashion a hook and fit it  semi recessed,    the rest is basically  built  as  the kit  IX.
Reason I have chose to do this  is  during the war my father cut his teeth on Seafires  before moving on to RAF types.
So here it begins with the already fitted out cockpit wall - I  added the paintwork (cockpit green)  and picked out the details then my normal  pencil for shading and white highlight,   I then closed both sides together  as the cockpit floor/seat/insrument consol  are made as a unit  and popped in from underneath.
Here are the first pics.
OC.
Share this post
Link to post
Share on other sites
Evening all,   I did a bit more work  this evening  - firstly I removed the tape and checked the seams, these needed just a bit of sanding  (but no filler I dont think)  this was a supprise to find two companies who manage to build kits with quite high build standards  - it  also makes my first observations  what I first started to build this kist  (in my  earlier build log - Not Eduard one)   as being incorect.
Anyway  next off was to fit the prop cone bulkhead, then when set  I  had to fix one of the exhausts stcks that had broken in two, this was fixed then glued in place in the recess - same the other side,   then I got the engine cover  and test fitted it,  quite a bit of scraping and sanding was needed to get a good fit  - then this was glued down.
It needs sanding and cleaning up whne its set.
So here are a couple of pics including one of my Supermarine  prod line.
OC.
Share this post
Link to post
Evening all  - hope everyone is ok,     so it continues  -  next stage is the cockpit seat assembly,   same build really as my other spit,  rear bulkhead/armour plate/seat/base/pedals  and columb,   these were glued together  then I did a bit of magic  - dry fitted the assembly inside the fuselage.
No secret  it pops in from underneath.
OC.
Share this post
Link to post
That's good engineering when the cockpit goes in from underneath like that. Accurate Miniatures kits do that and they are some of the most well thought out kits I've ever built.
Share this post
Link to post
Indeed Joe,   it helps having the fuselage buttoned up,   glad the dry fit was ok  after closing the halves together,
OC.
Share this post
Link to post
Brother the pantone color code for Sky color is #d6e4e5 that give you the range of colors and manufacturers that make it....
RAF Sky is a pale green color... The closest I can come to it is RAL 170 90 05.....
RAL 170 90 05
On your side of the pond you can get it from here....
Yourspraypaints.com
They will make you up a spraycan....
EG
Share this post
Link to post
Thank you for  looking into that for me EG,   I was thinking   - I  have hand painted the bottom wings on my Mossie and hasn't turned out too bad,  so I should be able to hand paint the Bottom of the Seafire  to the same standard  - cheaper as well   just a few quid (UK pounds).
I have the Dark Grey rattke can I need  I brought that months ago as I wasn't sure about the color on my mossie.
So I will order a tin of XF21  off flea bay.
OC.
Share this post
Link to post
OC.
My pleasure, BTW...
The FS number for RAF Sky is FS34504.....
Share this post
Link to post
Here's  the plan -  My farther used to tell me things about his service  one of those was about a Special version they were testing  of a Seafire, basically  it was a modiefied mk.III   - the FAA  where he was based  had a small outfit there called the  SSCU   Special Seafire Conversin Unit,   the idea was to see how far they could push a mk.III  by improving the already established airframe and engine.
They thought if they could make it breath better by putting the Two Rads under the wings same as the Spit IX  this should increase the airflow, also  they put on the pointed tail/rudder  to  give it more control,   there was a few other mods done also.
It was a sucess  but a Griffen engine upgrade was coming online soon  and this did a way with a few  proto's that my dad worked on.
OC.
Share this post
Link to post
Another kit I have my eyes on doing  when funds allow and after I have sorted out a few important financial things  that are waying heavy on my mind,  is to do another kit that falls quite close to this one as they were both FAA  service  and both  based at the same Naval base  were my late father  worked  - the unique  one of a kind  F4U-1A/-D   Corsair,
My farther used to chat to me about "the bent wing bird"   and how they were like nothing else he had worked on,  and how they had initial  teething troubles  with them  that needed quite a bit of sorting out before they could go onto the British carriers.
This type  -  (Off the Net)
Will keep you posted.
OC.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
