Roden Fokker Dr 1 - 1:32 scale by Popeye the Sailor - finished
I see a lot of new faces here in this forum.......I welcome you :)   I think that at one time or another,  most of us have cut our teeth on a plastic kit.   some have moved on to wood models for more of a challenge.....to pick up one now reminds us of the challenges we left behind {or so we thought}.    so welcome.......did in........perhaps it will bring memories back and make you feel like a kid again.
I have never built one of these kits,  let along heard about the manufacturer.  the Roden company is based in the Ukraine and produces a wide variety of plastic model kits.  I got this one from Oldmodelkits.com this past Christmas.
2118414728_1.jpg.27eda7323f86ef91e3336d8fd9d909f2.jpg  1793883033_9.jpg.2afb27b4071a43c83bb728b34f6ba305.jpg
from the kit,  four different aircraft can be built.....save the box,  since the paint scheme in the instructions are in black and white.
105987163_11.jpg.9b51ddc5e5f9e9e85ca028c24c510f0d.jpg  72307458_12.jpg.2347707031480bbffb6fbb6a26300633.jpg
the decal sheet is quite large enough to hold all of the decals required.
the plastic appears to be of a hard plastic.......the parts have very little sheen,  as in most kits I've worked with.   I had taken some pictures of the sprues earlier,  but they were still in the bag that they came in.  so I ditched that and opened the bag to show you all of the parts involved.  the kit itself is fairly detailed and does give you some room for options.
keen to note here that there are two propellers......depending on where the plane was built,  different manufacturers were used.  Axial,  Wolff,  Wotan,  and Heine were the major manufacturers at the time.  I've yet to ascertain the specifics on what prop was used.......heck,  I haven't even decided on which one I'm going to model yet  :D   I'll let ya know though  ;)   another thing about this kit,  is that there are two stabilizer fins and elevators.....I've yet to figure that out,  although other Fokker D VII and Dr 1 kits I've built had a choice of ailerons and stabilizer / elevators.   I went to Revell {which is now Hobbico} to view instructions of their kits.....I know that some of them had this option.   I found that Hobbico.......nor Revell/Germany,  allows you to view or obtain instruction sheets {sad to see......but that settles that}.  so I went on my own research jaunt for answers.
1746873812_4.jpg.bcc3b767b71355afac5794c33a8cecfb.jpg  981315985_5.jpg.e0360f987d7a07c5626c963920d099f7.jpg
these are the wings.....easy to denote the top wing halves.......the cut outs for the ailerons.......the center wing halves above them,  and the bottom wing halves on the other sprue.  the instructions tells you which stabilizer fin to use......part of my research too.
these are the small parts sprues.......note that there is a choice of ailerons........more research.   the wing parts are of a thicker plastic.....not much of an airspace when assembled.  the fuselage however is of a thinner plastic.......this is prevalent throughout the kit....what needs to have some beef........does.    I think the scale factor is good....I don't see anything out of scale,  as I've seen in other kits .
920236864_7.jpg.e144d032aa00c2a5d4e751f4139ac343.jpg  1758471731_8.jpg.3efbd9df6505ce6eb992b4f83a6d7e19.jpg
the width of the prop blades is the main difference.  one may provide more push and likely had a slightly different pitch.   the Sopwith Triplane was wreaking havoc in the skies during the first half of 1917.   armed with a single Vickers machine gun,  it was out maneuvering the German fighters.  the Germans struggled to maintain,  but they came to the conclusion that they needed to counter this new menace.  they managed to bring one down....how intact is not known.  Anthony Fokker visited Jasta 11 to take a look at it.  it was April 1917,  that the idea for the Dr1 had begun.   one nice feature in the kit,  is that they give you two sets of  "Spandau' machine guns.  one set does not have the cooling cans on them,  in the event one chooses to use PE.
I'm not going to use pe for this model........but the machine guns does give me an idea or two.   more on the story next........
Edited by popeye the sailor
finished
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Share on other sites
Bringing the lounger for this one...
Quote:
Link to comment
Oh Ello   another one Denis  - count me in.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
There’s plenty of AM out there for this kit as well. Guns, engine, carved and laminated wood props, streaky camo decals, cloth seatbelts, and all other kinds of goodys.
On the bench:  Vanguard Models 1/64 HMS Speedy
On Deck:
Vanguard Models 1/64 Zulu,
Vanguard Models 1/64 Fifie,
Victory Models 1/72 HMS Bellerophon
Link to comment
on Sept 1st the first prototype was rolled out to test fly.  Anthony Fokker instructed Reinhold Platz to build a triplane........what he came up was the V4.   test flights were poor,  citing poor handling and couldn't control the forces of climbs and turns.   they came back with the F5 prototype which featured balanced ailerons and elevators........and they made the wings longer.   they also added interplane struts to aide with the extra wing load.
    the retest proved to be much better,  and Idflieg ordered 20 of them to be built.  meanwhile,  they took 101/17 and literally tested it to destruction,  to see if it could take a beating.
1654887168_1.jpg.ed6da542a6ae5029775c26cf7d1a12fe.jpg  447714952_2.jpg.5be5d5da7816b3dc4612fcadccea6360.jpg
ailerons and elevators.....hmmmmmm,  so where does these changes occur.  I don't see any difference in the elevators {these parts are about 1mm thick}.....but the ailerons show a difference.   my guess,  with what I've found, the bottom one is the V4 protype,  and the top one is the V5 prototype.   first I began to assemble the wings.  there aren't pronounce tabs or pins to guide you in the assembly...not that they are really needed.  it's plain to see how they go together.
414676712_3.jpg.2ce9c2886dff7d5a8942c83f509be870.jpg  117306008_4.jpg.e203739cc684b307f2acb7b2ad91005c.jpg
there is some flash to contend with......sanding will be needed to smooth out the leading edges of the three wings.
I found that it wasn't the elevators that were in question,  in the initial tests,  it was the stabilizer fin itself.  if you look real close,  there is a slight curvature to the leading edge to the one on the left.  that is the stabilizer fin that's designated not to be used in the instructions.  I have never seen a model of a V4.....could be interesting to build one.   as mentioned......I've seen this in past kits,  but never understood or read anything pointing to these changes.  for all I know......I could have been building them wrong all along.  I looked at my other Fokkers....they are all correct with my findings :)   thinking of past kits made me thing about the D VII's I've built,  so I did some reading on them as well.  the D VII went through the same changes,  including adding length {1 bay cell} to the rear section of the fuselage.  this tells me that the fuselage of the D VII was about the same length as the Dr 1 prototype.   by mid August,  two V5's were delivered to Idflieg {bureau for German Military Aviation}.  these two planes {102/17 & 103/17}  were the only two plane to be renamed F1.   one  {102/17} was sent to Jasta 10,  and the other {103/17} was sent to Jasta 11.   Manfred Von Richthofen flew 102/17 and shot down two planes the next day.   pleased with the planes flyability,  he reported to the commander his assessment of the plane,  suggesting that more should be built.   he made that assessment on the 1st of Sept.........it was dampened when Oberluetnant Kurt Wolff,  flying 102/17,  was shot down and killed on Sept 15,  and Luetnant Werner Voss,  flying 103/17,  was also shot down and killed on Sept 23 {a very interesting bio of him I read}.
   I digress.........there's so much to tell.   after the leading edges were sanded,  the wing tips were added.   here there is a mistake in the instructions.   starting with the top wing,  they tell you to use parts 11D.  I cemented them in place,  and found them to protrude past the aileron cut outs.  thinking that this was correct {or they wouldn't have printed it},  I did the other wings...the center wing took a pair of 11D's too.....that was OK.   it wasn't till I added part 7A {8A is for the other side},  that I noticed the problem.....it fell short of the trailing edge.   seeing the solution right away,  I removed the tips off of the top wing.   they came off without too much damage,  and I swapped them.  there's a little sanding to do,  but there was really no harm done.
the fuselage is another story......I need to remove some flash.  there is some to deal with....this is probably the worst of it.
1471830844_7.jpg.67ae6b43ba2a46c1e2fcf9f89bf7e76b.jpg  752136848_8.jpg.9d9cdbf1707253d19c5dafd14be426b3.jpg
it looks like all that needs to be removed,  but looking at the instructions,  that shelf may be needed for the cockpit floor.   the bottom wing root will cover it,  so if I cut too much,  it won't hurt.  I'll do some test fitting to see the impact,  and what I can get away with.   matching up the top wing and stabilizer configuration,  this is what they look like:
1170324315_9.jpg.4e6b6e7cb663827d87e419e61fcccce3.jpgthe V4 prototype
1863356775_10.jpg.47a1dfff1fc665adee8fcd5512a837e3.jpgthe V5 / F1 prototype
all future planes that were delivered, 104/17 onward,  was renamed the Dr 1.  there were three other variants built......the V6 prototype,  given a longer fuselage {like the D VII} and equipped with a Mercedes D II engine,  the V7 prototype,  equipped with a Siemans Halske SH.III engine.........and the Vogel Grip Sp.5 Grief,  a two seat observation plane built after the war.  one last note......all Dr 1's were fitted with wing skids to help prevent ground looping.  in landing the plane,  the force of the engine rotation would cause one wing to pitch and touch the ground.  this resulted in a bad outcome.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
As I recall, the rotary motor did some things that if the pilot wasn't ready it could kill him.  If they revved the motor to fast, it just about flip a plane on the ground which once airborne gave them an advantage in combat as it could roll and turn faster in one direction than the other.  Dives were apparently a problem with tearing the skin on the upper wing off which they never did solve.   There was some research done after the war by the Brits and moving the seam on the upper wing forward stopped the shedding of skin.
I've seen this bird fly in airshows and models and just love it.
Link to comment
welcome to the fray EG,  OC, and Ernie.   Carl's squadron knocked me over the edge.........the D VII's and Dr 1's are among my favorite aircraft.  glad to have ya aboard :)
no PE Ernie......the detail in this kit is pretty good.  hopefully I can be just as creative with the paint  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
yup.....as I've read,  the plane had very good response banking to the right.   duct tape wasn't invented at that time :D .....could have saved a lot of lives!  welcome Mark :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
well.......if this don't beat all.  I guess I have another problem......  I was mess'in with the fuselage,  cleaning it up and fitting the halves together......I found that the starboard side is warped.  port side is OK.
but the starboard side is kicked in quite a bit where the cowling fits.
likely cause would be at the factory......it's appears pushed in to the left of the slot.  I tried to press the parts together,  but I stopped when I saw the appearance of the white stress line of death.
the epicenter is where the left side of the circle is.  I'm gonna try heat to bring it back out.......it should alleviate the problem.  if not........I'll still try to build it,  but I'll have to take another direction.  tell ya more tomorrow.  I'm gonna go sleep on it.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
So here you are hiding, spinach man! Yes the kit's sprues look exactly like the 1/72's version ... You'll have some post adjustments to do before you can go on. On the other hand it is (model)building, so what's the fun just trhowing it all together?
Decided on a colour scheme yet? The black I found a bit simple, and hardly satisfying to make. Ready before you know it and hardly a challenge. Enough talking, get on with it mate
Carl
Link to comment
Looks like a heated bath and a gentle massage...
Boy you sure do treat your models nice.... :-)
Quote:
Link to comment
Another Popeye build. I'm in.
Kind of like the Baron's scheme, but Udet's is good, too.
Ken
Started: MS Bounty Longboat,
Link to comment
I've brought my chair, I'm in!
Looks like you've had a good start😉
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
thanks for all the kind comments :)  I'll show you where I'm at in a bit.........I think it'll be alright :)
I'm kinda look'in towards Kempf's plane Ken.........I will do one of Udet's planes soon.  tried to smooth talk the admiral.........put out the suggestion that I could do one for her M&M collection.  can you imagine it???.....I can! :D
hello ED!  welcome......
no EG.....it was torture........by FIRE!!!
yes....here I am Carl :)   already found one mistake in the kit,  and now beating down another one.  this problem though had to come from the molds.  the ejection time must have been off.....too early.  my days of injection molding......waxing the molds {wipe as needed},  material injection......the stuff is at it's melt point,  the cool cycle.....depending on the material,  time matters,  molds open and parts {sprues} are pushed off.  might have stuck due to lack of wax.  I think I have it in hand........build'in it come hell or high water ;)   Ltn. Jacobs plane is a bit bland,  but would be essential if your doing a collection.  I do like the artwork.  I will likely do Ltn.  Kempf's plane......more decals  ;)   I need to get the right masking tape to do Ltn. Udet's plane.  I've been work'in on it.......see............🔩 🔧
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
fiddled with the fuselage this morning,  while looking through logs........which reminds me.   you know......I went through every log I watch last night......cleaned them all up.  I come in this morning,  and it's all clogged up again!  you guys gotta slow down.....or I gotta speed up........you darn folks are soooooooo prolific! ;)   keep it that way!
anyway........I knew heat would be needed.......and I was going to get the admiral's hair dryer.......   but it's like going to get a screw driver,  and com'in back with a hammer.......I used my lighter!  it was like a flame thrower!......I moved it around quick enough,  I thought.....till I saw the bottom panel of the fuselage half starting to curl :o.....oh ph........  I got most of it to conform,  but the damage was done..........I'll just have to see how bad.  so I cemented the halves together,  except for the area at the cowl.......got to let it dry
while I was waiting,  I figured I'd assemble the engine.  the Dr 1 was powered by a Le Rhone 9J engine.  later planes were equipped with Oberursel Ur.II engines....both of these engines were fairly equal to one another,  putting out around 110 Hp.
142609992_2.jpg.e25bb94eb87d46a6e83e9cae29b357e4.jpgstarted by assembling the two halves together
I also thought about the machine guns.  thinking of what to do with the naked guns,  I though of that piece of grating came in the Agillis kit  {the Clotilda}.
873681502_3.jpg.b0403d0ed59f72ee66cdec504aab472a.jpgI thought this would be perfect!
measuring and cutting the strip needed for the guns........
finding a suitable dowel,  it was cut and wrapped....made round by press rolling it on the table
and what you have is this........
happy about how it came out,  I cemented the 9 heads and tail shaft on the engine.
2084000963_7.jpg.d4d2b0f360150b36cea8454dfc78956f.jpg  1023080890_8.jpg.b330a9373fb2b35586e71ee67e827920.jpg
the other machine gun was finished........
now dry....the body joints were sanded with two different grits.  the melted part of the slot was cut out.  the short section by the cowl was cemented and taped........the admiral and I took Gibbs for a good walk.  when we got back,  that area was cleaned up some and sanded.
858300649_10.jpg.0cc3224dca7ee08865359ea0851c637c.jpg  440874028_11.jpg.6c470e385d3383b009026eec4e142125.jpg
at this point,  it's down to fitting the bottom wing root and seeing how much more I'll need to do.  I thought I still had that old tube of filler,  but I must have thrown it away.   that stuff was plenty old......it had begun to separate.  I thought of auto body filler....but that's a tiny bit......not worth dealing with.   saying the heck with it,  the other side of that slot was trimmed out.  the lip wasn't flush at the edge of the slot.....it wasn't cemented either.  so,  I added cement to the joint there,  and created weighted 'prying' situation for it,  to bring the joint flush with one another.  the  extra tot of cement should fill in the void
now I guess I'll write this log,  and then go shopping {make the admiral happy}.  I'll check this out when  I get back.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Smokin hot build there Denis, Nice work....
(good recovery too)
Quote:
Link to comment
It's a bit of a melting pot that build spinach man ... :) the admiral must be laughin' 'er 'ead off ... that's w'at 'appens w'en you start a build you shouldn't 'ave started ... at least not yet. Very nice recovery ... you remember to put the seat, floorboard and steering gear in before you close up :huh: Guns are great mate
Edited by cog
Carl
Link to comment
thanks all :)    happy to report that the fuselage is together and the blemish on the bottom is almost undetectable.  I should add another layer of CA on it and then sand.......probably would make it look even better.  no Carl.......I have no furniture in there yet......gonna have to build her a different way.   this was the best way for me to get the fuselage together......got it matched up really good.  I figure I can build the cockpit and then slide the whole she-bang in there,  with the way the front area is so open.  {just added more CA on the blemish}.   nawww,  admiral doesn't even flinch.......only holds her breath when I lose something.  she even helps me look every now and again.   just for fun,  I tell her that I'd need to get another kit,  so I can get the part I need.   she knows me too well though.......she tells me to scratch build it!  :D
thanks Ken & EG.......the cooling cans are just a tiny bit on the larger side......they slid onto the end of the gun breech {round area where the barrel comes out}  I started to do some meager painting.  I'll have something tomorrow :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
hello Craig...welcome and I hope I can do somewhere near your incredible work.
I was looking through the instructions last night,  and I noticed that they specify this model to have the Oberursel Ur II rotary engine.  I read that it was used later in the production....learning that only 320 planes were built,  I wondered when it took place.  I've always know this plane to have used the LE Rhone engine,  so it was interesting to me.  since the first two were produced,  and even the prototype,  the Le Rhone was the power plant for this plane.   the first two planes {102/17 & 103/17}.........all the way to {I would say} serial Number 212/17 { Lt. Kempf flew 213/17 im March 1918} came out with the change over.   probably what led to this change over,  was the fact that back then,  they oil they used wasn't as refined ,  as we have today.  castor oil was the lubricant,  derived from castor beans from the Ricinus plant.  Vegetable based and not very refined,  was somewhat acidic, which may have been a detriment in it's intended use.   it was likely not as thick either,  an extremely light oil,  near impossible to deter leakage,  that was a constant problem.  it's still used today......advancements have improved the quality,  with the idea that it could become a solution for pollution.   additives to it improved the viscosity to be used as the light oil it was intended for.  but back then,  they might have been better to have discovered canola or corn oil ;)   "OK,  we'll just throw some land o lakes in the farm tractor and get mov'in! :)   another thing I noticed,  was there must have been a lull somewhere in the serial numbers.  Ltn. Kempf's beint 213/17,   Rittm. Richthofen's being 477/17 {both in March 1918},  Ltn. Jacob's was 450/17 {summer 1918},  and Ltn.Udet's was 586/17 {june 1918}....given the fact that only 320 were built...... they really jump around.
   the thought here is that this might be the way that they numbered their military aircraft at a given factory.   the Fokker Dr 1 was built at the Fokker - Flugzeugwerke factory........I haven't checked,  but there may have been others.   the D VII for instance,  was built at three different factories.........Albatros Flegzeugwerke {ALB},  Ostdeutsche Albatroswerke {OAW},  and the Fokker factory.   as the planes rolled off the assembly line,  they were given the number of the plane built at the facility.  the second number {17},  may indicate the type of plane built........Dr 1's being conceived in 1917,  the 17 {year} suffix was added to the serial number.  curious,  I checked out the Albatros D III,  but their serial number designation wasn't too clear......if they did,  theirs would look like 000/16.
anyway.......enough with the lecture.......I'm beginning to lose gray matter:wacko:  I did quite a bit last night.......made a few changes,  along with almost making a big mistake {and I'm even gonna show it to ya}.  I started with a little painting.  the machine were painted flat black,  and the lightly gone over with gray.   when I have the silver or aluminum out,  I'll dry brush them along with what I'm doing.
I should add locator pins on them to make adding easier {the other one have them}.   I have some 'crosshairs' in the PE pack for the Hood that I will add as well.   the engine was painted as well in the flat black,  which I will dry brush later.
the exhaust and wiring rings were painted in bronze {exhaust} and gray {wiring}
might add more to them......  I worked with the bottom wing fit to the fuselage,  since I ended up cutting out most of that root tunnel.......removing more of it and cleaning up the slot.
193322366_4.jpg.5e8fc444ec1f87278d93f2662091aa52.jpg   1477358169_5.jpg.0fce893cb1c1c98cd62f817f1dc991e3.jpg
the blemish doesn't look too bad,  but it is still slightly detectable.  I added more Ca to it and sanded it some more.....looks better,  but it can still be seen to a degree.  I may never totally get rid of it.  adding the ailerons to the top wing,  I made sure that the tiny slot would accept the actuation levers.  I set it aside afterwards and removed all the parts not needed from my desk.  coming back to the desk,  I noticed something ws odd with the top wing.............Homer.jpg.910b7225b73aa98787c1c1808bc17566.jpg
7654194_6.jpg.35c10ad0e74ca4529a48509f39b8947a.jpg  45041569_9.jpg.594c7af137f87b9fc1cf715e64c14a70.jpg
thank god that the glue had not set long enough!........it could have been a nightmare!  I quickly changed the port aileron.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
another thing I was curious of,  was the center wing root.  there is only the flat shelf.....no slot for it to fit into.  the top part of the body encases it,  hugging the wing without too bad of a seam.   there is nothing to guide it's location otherwise.......it's simply sandwiched between the body and the upper body cover.
this is fortunate though.......this gives me a wide open bay in which to fit the cockpit.  because of the body issue,  and the insult of the heat fiasco,  the fuselage halves had to be cemented together to correct the combined issues.   I was glad to see that the floor of the cockpit doesn't rely on the bottom wing tunnel to sit on.......it cements to the internal cockpit frame.  even if it didn't do that,  it's nice to find that that an alternative can be done.      the engine mount bracket was cemented to the firewall.   trimming the flash off of it,  one of the bars broke,  reminding me that this plastic is brittle.  it's fixed with little trouble.   this plastic makes me recall of some of the real old car kits in the late 60's/early 70's........it wa a very cloudy plastic,  and very hard too........AMT or MPC perhaps.
I may need to cut off these pin marks.  I though they there as locators,  but so far nothing seems to go in either areas.
the seat is assembled,  and here are the side frames for the cockpit.   they are a little bent and twisted........one bar is broken..........likely from the way the sprues were packed.   I'm trying to be real careful with them,  knowing how brittle the plastic is.
I was looking on the site last night......play'in with the plane as I looked and typed.   progress?
269519396_12.jpg.8eb0d2806ff61956f8698c47c96cb2f9.jpg  1271421349_13.jpg.360cd2e3135d210b777e8a193f0c7bc4.jpg
you can see that I've pretty much cut out all of the root tunnel.......that's the wing root bar your seeing in there.   it can be seen how adding the top fuselage part closes the huge opening.  those two 'shelves' can be seen on top of the opening,  on which the center wing root sits on.  kinda weird.........but OK :)
.....got to take gibbs out....I'll be back....
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
WOW!  I was shocked........we only went 1/4 of the block.  he doesn't like to go down to the field anymore,  so we've been going from one street to another...and back again.   he acts like such a 'toughy',  but if he gets leary of his surroundings,  he'll lay down and won't go any further.......we end up going back the way we came.   I got him to the point now,  where we can go the entire city block.  for some reason,  this morning he didn't want to......we'll go later ;)
   I'm still planking that second hull........one strake here.....one strake there.   I'm almost done...so anyone following the Clotilda......please be patient.
so where was I??????  the cockpit.......not much more.   putting the frame together was a little tedious.......I wanted to make sure everything goes where they are supposed to.
461206133_14.jpg.874083593612e56399de6dbe2e30d8bc.jpg  1611113599_15.jpg.f0c1e8fd5d9af92be129b22ff8d834ee.jpg
it's still a little tweaked in spots...if I had any of that thin rod,  I'd try to reinforce the frame to bring the shape back.   I'm not sure how it all fits together,  so this would make it hard to judge.  spreading the sides apart a little bit makes it easy to slide in.
832356039_16.jpg.1561295476555abdf2df76ae6b0486e1.jpg  278327831_17.jpg.c0fb80b70111a28d20ebc708340bd24b.jpg
well.....gibbs is badgering me to go back out........opps.....the admiral just went out with him.   I'm sure this will be the walk he didn't want to do earlier,  so I'd better gt out there.   I hope this isn't going to be what the day is like  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Good progress  Denis   some very delicate work going on there.
OC.
Current builds
Completed works.
Link to comment
Castor oil was  problem and a big one also for the pilots.  Most of them had, instead of what they called it, shall we say, a bad case of diarrhea from it.
I'm glad you caught that aileron.  Looking good....
Link to comment
thanks all.......I should have an update soon.   more painting going on at the moment.....and I've still been plank'in that hull.   I also did a bit more with the Memphis Belle.......kind of a boo boo as well.  I'll see what's in my camera ;)   in painting some of these parts,  I normally do them on the sprue.  this model has a number of sprue connections to the parts......equal injection for lessening the flow marks,  I try to cut them down,  by removing them from the equation in the critical areas,  so that when the part is painted,  these points won't be noticeable.   this plastic is a bit hard to work with.....but it's coming along :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Fortunately at 1/72, you can use the ailleron any which way you want  ... not much difference. I am trying to rig  at that scale ... hard on the eyes, hands too ... will you be doing the rigging on the doctor ?
Carl
Link to comment
 the ailerons with the two rib curvature was present on the first prototype.........the F1's on had the single rib curvature.   it's a big question why they even have them in the kit.  speaking of that........there is a card in the box,  which you fill out,  it goes to a place here in the states......Texas.   in all actuality,  they are a distributor for Squadron models.....just look'in to get feedback from the kit purchase.  I looked through the model listing.....1:32,  and I saw a kit for a Fokker F1.   this is strange,  since there were only two F1's built........I like to build obscure models........but yea,  that would be obscure ;)    {and I thought building a V4 would be cool}.
I rigged the Hobbycraft model.......it's a 1:32 scale model.    I would have to drill all the holes for the cables........the only other bit of rigging is at the landing gear.
got more done today.......have to change the color on the interplane struts and cabane struts....... either that,  or I'd be doing Richthofen's plane {and then I'd have to change the color of the cowl}  I'll try to get the pictures up later.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
