CSS Virginia by cgiacoppo - BlueJacket Shipcrafters - Scale 1:192 - My son Michael's first wooden ship build
Nice to see some youth in this hobby.  You are off to a good start.  One of my favorite ships.
Any more progress on this model?
Ryland
               - Nautical Research Guild
Link to comment
Share on other sites
Notches were cut into the hull allowing insertion of the section line templates.
Wood strip applied temporarily in the position of the keel to act as a guide.
Shaping the bow one section at a time.  We carved down to the edge of the template and then smoothed out to the previous section line.
Shaping the stern.
Port side shaping complete and rough sanded.  Wood filler will be used to fill in the remaining trace of the notches prior to fine sanding.
On to the starboard side.  Shaping the stern.
Link to comment
  • 9 months later...
  • 2 months later...
  • 1 year later...
After another long break Michael is returning to this model.  During the break, he built the frame of the Chuck Passaro English Pinnace that he was given as a gift, and completed a model of USS Laffey DD-459, which took 1st place in the Junior division at the 40th annual NE Joint Clubs Ship Model Conference on April 29th in New London, CT.  New pictures to this build log coming soon.
Edited by cgiacoppo
Link to comment
Pintles & gudgeons are not part of the kit.  At 1/16 scale, we'll keep it simple.  Hat tip to jre8655 and his post from 2013 - we will use a similar technique.  Michael drilled holes with a #74 drill and glued in 4 pieces of brass wire.  These will be used to connect the rudder to the post and should be concealed when complete.
Link to comment
  • 8 months later...
Notice the copper plating along the keel in the previous 2 images.  This is difficult at this scale, requiring a 1/16" strip of copper foil.  The smallest we could find was 3/16" so I am slicing them in half (not easy!).  At this scale, we decided to leave out the nail pattern.  This was a test strip and we were pleased with the result.  We will continue this once further progress on the model is made.
Link to comment
We cut out a thin piece of wood to serve as the top of the ship, in the hope of getting a sharp edge between the top and the sides.  It has been glued and clamped in place.
Once the glue dries, we'll remove the clamps and see if any patch work is needed to create a clean, sharp transition from the sides to the top.
Link to comment
I just finished a complete read through of this log. Nice job on the model.
Glad to see you have continued to work on this model.
I find the battle between the Virginia and Monitor too be a great study in the evolution of warships. An interesting book (IMHO) is The Monitor Chronicles published by the Mariner's Museum which houses artifacts of the Monitor.  The book uses source material of letters from crew members, newspapers articles, and letters from some of the principle players.
Another on the ships and battle is by John V Quarstein: The Battle of the Ironclads
Keep up  the nice work on the model.
Robert Chenoweth
In the research department:
Nothing at this time.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
