USS Cairo 1862 by MPB521 – FINISHED - Scale 1:48 - American Civil War Ironclad - First Scratch Build
1 hour ago, FriedClams said:
Great progress Brian.  The paint job looks terrific and a good choice on the cut-away color.
Gary
Thank you Gary. I’m liking the way it’s coming along and the paint definitely makes look more complete, even though I have a long ways to go.
-Brian
Current Builds:        Completed Builds:
Mississippi River Towboat Caroline N.                                                    HMB Endeavor: Artesania Latina
        USS Constitution - Cross Section: Mamoli
Non-Ship Builds:        HMS Victory - Cross Section: Corel
New Shipyard        King of the Mississippi - Steamboat: Artesania Latina
        Battle Station Section: Panart (Gallery)
In Dry-dock        Chaperon - 1884 Steamer: Model Shipways
USS Constellation: Aretesania Latina                                                       USS Cairo - 1862 Ironclad: Scratch Build
Flying Fish: Model Shipways
Link to comment
Share on other sites
Your build is progressing nicely. The cutout color works well.
Ken
Started: MS Bounty Longboat,
Link to comment
Hello again everyone,
Back with another update, this time with more to report.
Before I start though, I wanted to show a couple of acquisitions I recently purchased. First is a little reading material I found "What Finer Tradition: The Memoirs of Thomas O. Selfridge, Jr., Rear Admiral U.S.N". Thomas Selfridge Jr. was Captain of the Cairo at the time of her sinking. Along with the book I have an autograph of Rear Admiral Thomas O. Selfridge Jr. himself.
A big thank you Keith Black for sending me the info for the autograph, this will make a nice addition to incorporate into the display when I am finished.
Now on to my accomplishments since the last update.
First up was work on more of the steam plumbing. Before I was able to complete the plumbing, there were a couple of things that needed to be done first. Since the some of the steam exhaust plumbing is attached to the smokestacks I was going to have to install the boiler. But before I could do that I had to verify all the wiring was good and the lights worked since the wiring was all under the boiler assembly.
Testing out the lighting.
...and everything seems to work. And yes the pictures are a little out of order, since I forgot to take the pictures of the lighting before the plumbing was done.
So starting the plumbing, I needed the four exhaust pipes, two of which ran from each of the pre-heaters to the smokestacks and out into the wheel house.
This part was one of those projects where I felt like I painted myself into a corner, since there were several walls that needed to be in place before running the pipes, and also needed to be in place to line up the holes. For the piping, I again used styrene rods. This material is so easy to work with and coupled with the heat shrink rings, gives the perfect illusion of pipefittings.
Rearward exhaust pipes.
Forward running pipes going in. I worked out a solution to be able to run the plumbing through the bulkheads without having to build all of the interior walls. I used a couple of short pieces of brass tubing to form a coupling between the boiler room bulkhead and the engine room bulkhead. This allowed me to insert one short piece from the pre-heaters to the couplers and the longer piece can go the length of the boilers to the smokestacks. The coupler also functions as a heat shield against the timber walls.
Since none of this plumbing survived the recovery, this was another build that I used my best judgment on and some builders liberties. I used the drawings that the guys building the St. Louis used as my design (I didn't post that picture here since the picture belongs to their build log but if you would like to take look at it it, the drawing can be found at the following link, post #21).
Before the couplers were added. I wasn't able to make the multiple bends in the styrene rods and get everything lined up properly.
Couplers added.
All painted and in place.
Next up was finishing up on the bollards. These have been in place for a while, but it was time to get them finished up and painted. I used some of the aluminum foil tape to make caps for the timbers to prevent them from prematurely rotting from water penetrating the exposed end grain.
First cap in place.
All timbers capped.449681958_Bollards1.JPG.d68cfe8250d466ecd3674156e3982130.JPG
Painted up.
As of this posting, I realized that I didn't take a picture of the finished bollards in place. I'll see if I can remember to take some and post them in the next update.
Next up was the placement of the inside gunwales (I'm guessing that is the proper term for them on this type of boat) along with the eyebolts for the cannon rigging.
Waterways added to the bottom.
Port and Starboard sides in place, painted and varnished.
Next on the list was the construction of the Pittman arms. Very little of these will be seen, but I wanted to put some detail in them without going overboard.
Finally for this update, was the rigging of the first cannon. I started with the aft cannons, the 30 pound Parrot Rifle and 32 pound Smooth Bore due to their placement and accessibility. These need to be installed before I can complete the Captains quarters due to the confined space available. As it is, these were a royal pain to get the outboard rigging in place. The first cannon I completed was the 30 pound Parrot Rifle.
I started the rigging in my casemate mockup to get the correct lengths on the ropes.
Breech ropes in place.
Ends seized.
Photoetched hooks for the blocks and running rigging.
Forward assist ropes in place.
Now the fun part, placing them in their ports.
Rear assist rigging in place.
One final picture, I am not sure what happened here, but I can promise you  the cannon is not bent. I guess it is all in the lighting, but I just wanted to get a view of the cannon in it's port.
If I may, I have to give plug to Chuck over at Syren Ship Model Company for the outstanding quality ropes, hooks and blocks I used for the cannon rigging. He doesn't fool around on getting them shipped to you either. From ordering to my mailbox was about three days. Thanks Chuck!
That is all I have for now. I am going to finish up on the 32 pound smooth bore, more of the internal walls, and the crank arms for the next update.
Thank you all for stopping by and the kind comments and likes.
Until next time, please stay safe and well.
-Brian
Edited by mbp521
Link to comment
Wow - impressive work Brian! Some extraordinary work there, and I love the attention you are giving to the plumbing - that adds some lovely detail to the model.
cheers
Pat
Edited by BANYAN
Link to comment
Terrific work Brian - every bit of it.  I particularly like your process in constructing the pitman arms.  Adding the curved profile to each side by layering on extra material is a clever solution to maintaining perfect symmetry across both arms.  I must remember that.  Great update!
Gary
Completed Scratch Builds
Link to comment
Beautiful.   I hate to ask this but are the breech ropes correct?  It appears that they might be too short for the gun to recoil.   Since this on is pretty much buried it may not really be seen or noticed when finished.
Link to comment
Don, Pat, Steven, Gary & Eric, Thank you so much for the kind comments. I appreciate your continued support.
Mark,
Thanks for the kind comment and not to worry about asking about the breech ropes, this is an interesting question which could possibly use some  more discussion. While they do look like they are somewhat short, I based my rig on some of the research pictures that I found on how the 19th century naval guns were rigged. Most of the ones that I found show breech ropes that look like they barely allow for clearance to reload after recoil, most of these navy ships had almost vertical gun ports. Since the gun ports on these Iron Clads were sloped at 35° angles (port and starboard sides) & 45° angles (fore and aft sides), I would guess that this drastically reduced the amount of clearance for reloading. I'm wondering if the breach ropes were just used to keep the guns from recoiling too far back given the limited space on the gun deck and were only used to keep most of the strain off the smaller ropes and blocks of the running rigging and the running rig was used to run the guns in and out for reloading. Many of the examples I used show fairly short breech ropes.
One of the examples that I used can be found here at this link. This was a drawing that I had found a while back and Eric posted the link in a previous post. It is a beautiful break down of the Cairo showing the artists interpretation of what she may have looked like on the interior as well as a breakdown of her guns.
Now I do have to admit that I did reverse the eyebolts for the running rig and the breech ropes since with the sloped sides it made it impossible for me to install the keeper pins for the breech rope anchors, so they had to be placed through the gun ports. A minor deviation that hopefully will not be noticed too terribly much. I am also not 100% sure that I did get the lengths right due to my interpretation, this was just my best guess. However you have got me to thinking more and more about it and I may need to go back and revisit some of my research. 😁
-Brian
Link to comment
Interesting to say the least.  You might be right about the shorter breaching rope. It wouldn't need to come back too far and the "training tackle" would be used to adjust the azimuth.  A 30 to 32 pound shot wouldn't be a problem doing it that way although the gunners would be more exposed to small arms fire.
If it were one of the 75 (?) or 100 pounders that probably would be a problem.   I'm trying to remember where I saw it but some of those vessels had "armored" hatches which were closed for loading.   Could have been one of the builds here or maybe out at the Warfare History Network.   It might have even been at Fort Donaldson (which I visited many times a few decades ago) as plunging fire did a lot of damage to the ironclads as they were armored on top.
Link to comment
Mark,
I believe that the USS Tennessee and the USS Atlanta both had the armored gun ports. Ironically, both of these ships were captured CSS ships, which poses the question, did the Southern shipbuilders come up with the idea for the armored ports or did the Northern shipbuilders? I do know that the City Class gunboats port doors did little more than shed some of the rain water out of the gun deck. The timbers they were constructed from were only about 2" thick and would provide minimal protection from musket fire and zero defense against a cannon ball.
You also have a good point on maneuvering the guns around. The smaller ones wouldn't be as much of an issue as the larger ones. However, Cairo's guns ranged from 3550 lbs. on the Parrots to 8465 lbs. on the 42 pounders. That still a lot of iron and wood to be moving around in such tight quarters, especially with only six men per gun.
Also, thank you for clarifying the "Training Tackle" term for the running rig on the cannons. My nautical terminology glossary is a tad bit limited.
-Brian
Link to comment
1 hour ago, Lewes 5 said:
Beautiful job !! Question . What kind of cord are you using for your breeching ropes ?
Lewes 5,
Thank you for the question. I used .045 (1.14mm) rope from Syren Ship Model Company. Chuck has some fantastic and great quality products for model shipbuilder on his site.
-Brian
Link to comment
Wow. Just wow. That is amazing...
George K
Link to comment
Brian,
Wonderful work and research!
The Monitors also had armored gunports.  Unlike the external swinging leaves used on CSS vessels, these were internal and pivoted on vertical shafts.  I seem to remember that one of the CSS ironclads was partially disabled when a shot struck one of the leaves and jammed it in front of the gunport.
BTW guys, having spent my working career building piping systems, “Plumbing” refers to very low pressure domestic service drains.  The stuff carrying water and steam to generate power is just called piping.  😏
Link to comment
Roger,
Interesting story about the Monitors. I love these little known tidbits of history.
I appreciate the clarification on the “piping” definition. Out of curiosity, we’re you a pipe fitter by trade?
In my younger days I worked as a loss prevention officer at a department store that underwent major renovation while I was there. During that time I was assigned to escort the pipe fitters who were replacing the buildings cooling system (towers and chillers). That’s a job that that requires some great skills in measuring and welding. Being in my late teens then I was in awe of the preciseness of their work.
-Brian
Link to comment
Brian,
No I was not a pipefitter, but like you I have great respect for their abilities. IMHO, they are the aristocrats of the building trades.  Few people probably realize that they are graduates of a demanding four year work study apprentice program.  Much of what they do requires an advanced knowledge of trigonometry.
I came into the piping industry via the back door.  I am an engineer with a degree in Naval Architecture and Marine Engineering, and a commission as an Ensign in the naval reserve.  Upon graduation I was ordered by the Navy to report to Admiral Rickover’s Nuclear Engineering organization where for the next four years I worked on nuclear submarine piping systems.
When I left the Navy, I was hired by a large engineering company, that was building piping systems for civilian nuclear power plants, as their quality assurance manager.  I went on to other engineering and management roles, all involving high pressure piping.  It is a small but fascinating industry with its own technology.
Roger
Edited by Roger Pellett
Link to comment
Roger,
Quite the career you had there. Thank you for sharing and thank you for your service in the Navy. I am prior Air Force, but for some odd reason I have always had more interest in ships than planes. Never been able to figure that one out. 🤷‍♂️
-Brian
Link to comment
On 9/2/2021 at 11:57 AM, wefalck said:
Nuclear submarines are steamboats (with a low carbon footprint) after all
Though I have to say I'm glad there aren't hundreds of nuclear submarines sunk along US river systems...
Link to comment
Wefalk,
I assume that you are referring to the job of scrapping obsolescent Russian Submarines.
Here in Duluth, we have several companies that manufacture heavy shears for cutting scrap metal.  These shears are boom mounted on the same tracked units used as excavators.  The businesses grew out of boom mounted equipment built for the logging industry.
In 1990, my wife and I were involved in helping to settle a family that had immigrated from Russia.  The husband had had an excellent position in a Russian tractor plant, but jobs in Duluth were scarce.  One day he was offered a job by one of the companies that manufactured these shears.  They had just received a large contract to supply these for use cutting up Russian Submarines.  The job involved supervising final assembly of the machines in Russia.
Having just “escaped” with his family he had no interest in returning to Russia. Fortunately, he made a good decision.  He went on to have a successful career with another company.
Roger
Link to comment
OK, this has all nothing to do with USS CAIRO in 1862 and we shouldn't dilute the building log with small talk ... at the end of the Cold War and after the Sovient Union disintegrated, Russia didn't need much of its Pacific and Northern nuclear fleets anymore and the submarines were laid up around Wladivostok and Murmansk. After some time, many of the surplus submarines were cut up and scrapped, keeping just the central reactor sections afloat. The reason was that Russia didn't have the necessary defuelling and decommissioning capacities and capabilities then. In the late 1990s the IAEA in Vienna organised a funding programme with international donors to ensure the proper defuelling and decommissioning of these reactor sections, as they were deteriorating and threatening to leak radioactive contamination from the primary reactor circuit. A colleague and friend of mine at the IAEA ran this programme in the 2000s. I myself have been involved with programmes to help the Russians sorting out the environmental contamination aspects of this.
Link to comment
You guys are good. I love and welcome the small talk. I find all these stories interesting and fascinating. Good to hear personal histories of fellow builders.
-Brian
Link to comment
Hello everyone,
Time again for another update.
This time around I finished getting the aft 32-pound smoothbore in place and rigged. Here are a few shots of it going in
Breech rope being seized..
Completed breech rope.
Training rigging going in.
And this cannon completed. I haven't been keeping track of the hours that I have spent on this build, but I do know that between the two aft cannons it took more than three hours to complete. These are some seriously tight quarters to get the hooks mounted to the eyebolts and the ropes drawn up tight. This task of the build has definitely swayed me from ever wanting to do a ship in the bottle build. Unfortunately, for all the work put into these, very little of it will be seen
One of the smaller projects on this post was the completion of the paddle wheel crank. This was another instance of where I didn't take very many pictures of it being built. I have a bad habit of getting engrossed in these small pieces that I only think of taking pictures of them when they are done. Anyhow, here is the basic construction of the crank. Just a small piece of wood with two flat washers for the hubs. Once these were built up, they were painted black and installed.
Next up were the exterior ladders. After reviewing all of the pictures of Cairo's sister ships, from what I can tell, she was the only one that just had ladders on the forward and aft casemates. All of the pictures of the other boats in the City Class show ladders mounted on the side casemates as well. Not sure if this was a later addition to the others or what, but since there is only one known picture of the Cairo in existence and there is not a ladder shown on the port side, it makes it very difficult to determine if the starboard side had one either. In studying the HSR drawings, there is also no indication of side ladders either, so I went with my best judgement and did not place any on the sides. And at the risk of sounding lazy, I am somewhat relieved I wasn't able to see any other ladders, because these are one feature of boat building that is not at the top of my fun list. This is only because they are so tedious and fragile, and I know it's just me, but I usually have a hard time getting all of the rungs lined up evenly. These were not as difficult as some of the smaller ones, but they are still ladders.
Ladders glued together.
Painted up
Aft ladders in place.
Forward ladder in place.
and since I forgot to take a picture of the completed bollards in my last post, here is one with the forward ladder as well.
Once the ladders were placed it was time to move on to more interesting features that will most likely not be seen, but I wanted to add just because it is a feature that I have never built on a model before. The "Head". I didn't want to devote a whole lot of time on them since they will be mostly hidden anyway, so I kept these structures simple. In reading up on the history of these boats, somehow they were able to channel the water off the paddle wheel to "flush" the heads and provide water for the showers. I did do some digging on this as well and was not able to find anything on it, so I decided to leave those details out.
Next up, I started working on the roof beams. I needed to get some of these in place so that I could start placing the cannon implements.
Once a few of the beams were in place I started on the rack for the implements. These were just made with some 20ga wire bent to shape.
Holes drilled into the beams.
Racks in place.
...and implements installed.
There sure was not a lot of wiggle room to work around these aft cannons, it sometimes makes me wonder how often these aft guns were used. I'm guessing that the only time they would have been fired would have been during training exercises or when the enemy was crossing her stern or if the boat was in retreat and she was just protecting her six.
Once the racks were in place, I continued on with more of the roof beams.
Another small project that I completed were the interior hawse pipes. This was another detail that there is very little info on, and one that I added because I wasn't real sure where the anchor chain was stored. We do know that these boats had anchors because there is part of one that was destroyed when Cairo was torpedoed in the museum and there are hawse pipes mounted in the forward casemates. So I went with logic, and the limited knowledge that I have about anchor stowage and decided that if the capstan was used to haul the anchor, then the chain would have to be stored somewhere. So I figured that once they hauled the anchor in, the chain would be directed to the hold to keep it out of the way of the limited deck space available and free up space for the gun crews to move around without tripping over it. In my mind it all makes sense, and I couldn't find any info that would disprove my theory. So I ran with it.
To continue with my thoughts on this, I figured the operation would work somewhat like this: the anchors would be weighed pretty much like any normal anchor. It would be pushed overboard and the chain let out until it hit bottom. The Western rivers were not known for their massive depths, and this was before they started dredging the river channels, so it most likely didn't require a lot of chain before the anchors settled into the mud. Once the crew was ready to get underway, heavy ropes with hooks were attached to the chain either at the bow, or just inside the forward casemate, the ropes were then wrapped around the capstan and the anchor hauled up. As the chain was coming up, the crew would direct it down the interior hawsers to it's storage locker until it was needed again. I may be way off base on this operation, but it sure sounds good on paper. If anyone has a better thought on this or actually knows how this was done, please share. The curiosity is killing me, and the info on this is very limited.
So here are the holes drilled in the deck for the hawse pipes.
and the hawse pipes installed.
Next was the installation of the hog chain braces. Not a great bit of detail here. More to come on these later.
Then it was on to getting this baby armed. I took a different approach to installing the port and starboard gun carriages since they were a little easier to access. The port carriages were easier due to the viewport opening in the side, which gave me access to the eyebolts through the casemate. I placed all of the carriages in their respective gun ports and then rigged them without the guns attached. Without the guns in the way I was able to get to the eyebolts better. However, it still took about an hour per carriage to rig up.
After the rigging was completed, I went ahead and mounted the lower port doors. I wanted to get an Idea of what they were going to look like and how much the white interior paint was going to contrast with the black outer paint. It does stand out, but I think it looks alright. I studied the old pictures of the other City Class boats, but it is hard to tell in a black and white photo if these doors were painted white on the inside or if it is the sun reflecting off the black paint. In some instances, some of the boats look like the doors were painted black on the inside at one point.
All lower port doors installed. I am going to hold off on installing the cannons and top doors for as long as I can. I don't want to risk snagging them and having to redo them while I work on the other features.
I completed the rigging on all of the port carriages and moved over to the starboard side.
This is where I am currently at so that will do it for this update. I am going to finish up on the rigging for the starboard carriages and get the lower port doors installed then work on installing and rigging the forward guns. Once these are completed I will install some gun deck details like the cannon ball crates, barrels and crew lockers.
Until next time, thank you all for stopping by, liking and the kind comments.
Please stay safe and healthy.
-Brian
Edited by mbp521
Link to comment
Some absolutely wonderful detail Brian, a very nice example of a well detailed model.
cheers
Pat
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
