Coca by Rodolfo Bigoni - FINISHED - Amati - Scale 1:60 - XV century Spanish cargo vessel
Link to comment
Share on other sites
Dear friends,
The work continued trying to fix the blocks in a uniform way, but it is not very easy.
Pictures of the time show both blocks fixed close to the bulwark and far away; runners can be short or long as well. So there is a lot of freedom of action:
000_4826.thumb.JPG.ac6f1bdaf8a2d456446967f16b27039e.JPG  000_4828.thumb.JPG.9d9e46d1bb33f4cbfc461f799189853b.JPG
   As a first step, I shaped a steel wire to keep the distance constant. Then I tied the block to the rigging removing the excess rope at the end.100_1908.thumb.JPG.70c1f5186520a92ad6280d14c784a3e5.JPG omicron.thumb.JPG.6153ae3d130711d8b75afce5b80d367c.JPG
At the end, a runner of clear elastic wire temporarily joined the upper and lower blocks so I could get an overview.
If I could go back, I would tie the blocks to the deck via rings attached directly to it or to a rafter; but it's done now. In any case it is an improvement over the three shrouds proposed by AMATI.
After that I will cut away the elastic thread, remove the blocks with the toggles and lower the yard down to try to put the sail on.
See you soon!
Rodolfo
Link to comment
Dear Friends,
AMATI puts the picture of the ship with the sail only on the cover of the box: it is a kind of sausage with six laces that bind it to the yard. The technical drawing does not report anything about the shape and size of the sail, so we have to arrange:
Pictures from the period show that the sails wrapped around the yards show a very slim shape:
000_4826.thumb.JPG.053ed7c14ebff47b8ba911fcd22c93fb.JPG 435001671_000_4827(2).thumb.JPG.a6441de93502fa95d3ef694ddf6455b1.JPG
Obviously, the wrapped sail model cannot be reproduced in perfect scale because it is too thick compared to the original. Different would be the case for the unfurled sail.
For that reason I cut the fabric in a reduced way compared to the theoretical sail (I took as reference the mainsail of the Santa Maria of Adametz' drawings in proportion to the yard of the Cocca). The shape will be an "inverse" trapezium:
alfa.thumb.JPG.fdf1646afaa2ed525d31f3f7845d71f2.JPGbeta.thumb.JPG.713e41777c89f52164cd52fa339e0170.JPGgamma.thumb.JPG.cbb8bef8453873f7db85f062d1de171e.JPG
The sail cloths are simulated on the back of the sail with a pencil.
I glued a 0.5 mm wire along the inside perimeter, cut out the sail leaving a side margin along the perimeter, and then folded the outside overhang gluing it and embedding the inner string. Next, I glued another cord (the luff cord) of about 0.8 mm diameter to the outside, with rings at the lower corners. This is the result of the first attempt (The holes were bored with the tool in the photo):
As for the way to mount the sail on the yard, I chose what is described in: "Los galeones españoles del siglo XVII - Tomo II" authors Cayetano Hormaechea, Isidro Rivera and Manuel Derqui, Ediz. "Associació d'Amics del Museu Marítim de Barcelona" with the addition of a drawing by H.E. Adametz (for his Santa Maria):
b.thumb.JPG.0833474fc378bf17e80d3666bc0b5618.JPG c.thumb.JPG.8ded928d334e29042959b7e9e425f969.JPG
In retrospect, though, I think it's better to put a loop of rope at each corner: it saves the trouble of tying the sail to the ends of the yardarm. Moreover, the work will be easier if the blocks will be fixed after the sail.
See you soon!
Rodolfo
Link to comment
Greetings to everyone!
After the first attempt, I then made two more. In the last one, I drilled the holes through the fabric with a glowing needle and, in my opinion, the result is much better as the burn around the hole simulates stitching. Here is the result of the third attempt; unfortunately I did not take pictures of the sail before putting it on the yard.
1525363620_000_4877(2).thumb.JPG.47a6f266b460ab4aa517c6bca0856e54.JPG225973400_000_4879(2).thumb.JPG.f9be4370c9154ef0c16056eb86550688.JPG670236377_000_4880(2).thumb.JPG.c4e0efc864caa18b3ac34aaf13737d5d.JPG1579906243_000_4864(2).thumb.JPG.fbecb8c8ccaaf3518ca90d142151a7fa.JPG
Next step will be: the cathead.
See you soon!
Rodolfo
Link to comment
Looking very good, Rodolfo. The naus had enormous mainsails and the yards were very wide indeed. You've captured that "look" very well. Having done  furled sails on my dromon, I know how difficult that is, but again, you've done a brilliant job of yours.
Steven
Link to comment
Dear modeler friends,
at this point it is useful to think about how to put the catheads.
The Nao of Mataro has a couple well detailed (and the accuracy of the work makes me think that the builder was skilled):606545651_992516755_mat2.jpg.0eae4856b74f17428e99b9721c491697(2).jpg.9e222259f1d7fd47691b64fe99ec5b82.jpg    1977499688_2073774675_mat5.jpg.2f01f460ea5cc422c6922f6bccda2d5b(2).jpg.eb0ca7442aec5db92c47e52c912c746b.jpg
As we can see, the problem arises that Nao of Matarò has one cathead in a more advanced position and the other more backward.
The doubt is if it had four catheads and two were lost or if someone made a wrong repair (not very likely, also because dimensions are different). Yet I haven't come across any drawings or paintings with four (there are few even with two...among them a Botticelli's painting ).
Sandro-Botticelli-The-Punishment-of-Korah-and-the-Stoning-of-Moses.jpg.b04730a86a8a0062497ccd7ed9ca0580.jpg.23110a7d663d89e7f954ceca80e9905e.jpg  fd524bbcf6bd000554d09bc5b917405e.jpg.b4af8186f7924e2a064e93a23610ffe1.jpg
Someone has built a ship with four catheads:   1039106649_34052(2).jpg.0536ccd22e8ad210946c55cd81d955e1.jpg
but, in conclusion, I thought that for such a small ship, one cathead per side was adequate. I preferred a simple solution, shaping with file and sandpaper slightly curved strips of walnut 6x6 mm. The pulley is only outlined by carving the wood a bit between the holes.
b.thumb.JPG.05fd7fafd0177f20b7ad676754c264ad.JPG c.JPG.11b825bf6fd60126c55cf9e84543a82b.JPG d.JPG.96ac701dfe6c4dd826e26bc437077c84.JPGe.JPG.6c456ce61608cdeee36e0587676dcfdd.JPG     f.JPG.5f123f39856419fd8638d2722da58ea1.JPG        g.JPG.b2dd3afde9a545b41daf1654905d9b4b.JPG
To glue the catheads, it is necessary to lightly sand the clinker area, and this is the result after painting with oak color impregnating agent:
569260645_100_2017(2).thumb.JPG.93e8faee693b66b10b13555e9facfda0.JPG 410234898_100_2022(2).thumb.JPG.8392ab541721ea96d4922739fa71ee3e.JPG
See you soon!
Rodolfo
Link to comment
Warm Greetings to all friends of the forum!
Finally starting to get the first rigging in place: the main mast lifts. The ropes have been tensioned and then smeared with diluted vinyl glue  using a brush.
2125023049_100_2032(2).thumb.JPG.41ea50ed2c7688f6f8b36be807183d2f.JPG 505759083_100_2041(2).thumb.JPG.255e828b519279f3cb4f536519e102c7.JPG
100_2037.thumb.JPG.f96ec6c11c17a0ee76b9a35ffb531309.JPG100_2039.thumb.JPG.2ccafcb14abb8bf456aabd85784d18be.JPG
The next step will be the three rails at bow, which look quite laborious.
Good work everyone!
Rodolfo
Link to comment
A warm greeting to the friends of the forum; I am very grateful for the attention you give to this model.
The bow handrails of the AMATI project are very simple and linear; on the opposite the Nao of Matarò has them much more complex:
888327009_100_1974(3).JPG.256457eb0f014fd9e97d4796f64cea9b.JPG 378054809_1001205884_Mataroship.jpg.d2098a0bc0856e739b5be1d9ab938e6e(2).jpg.df95e8df3b32e59059065c9c31748008.jpg
An attempt will be made to reproduce the effect of the Spanish model.
First of all it is necessary to cut to size and shape the supports; the corner ones are 4x4 or 5x5 mm and the others 3x3.1928480155_100_1726(2).thumb.JPG.7724a2f30ced1cd4aa34762fb5d0d255.JPG628346691_100_1727(2).thumb.JPG.167b5b8267d61e767f77a8dab24dbd76.JPG1219784057_100_1729(2).thumb.JPG.19476b2a5bf8847975e94b53bdcaa90c.JPG
Then select the ones that look the most like each other and glue them to the battens. After that, we glue the three sections together, after shaping the ones that end in a point at the bow extremity. Shape the laths with a round and half round file:
Varnish with walnut impregnation, let it dry and finally glue the rails to the fore deck:
100_2071.thumb.JPG.42fd81029a4bdf96239305db35f1d5d7.JPG 940250443_100_2072(2).thumb.JPG.fa7cb274e9591ab6371a640b5276fc03.JPG
The next works will be the laying of the main stay and the positioning of the shrouds.
See you later and have a wonderful Sunday!
Rodolfo
Link to comment
As always
Very nice work Rodolfo
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
Thank you very much, Steven!
Dear friends, I finally finished the shrouds; it was quite difficult for me to attempt to present them neat, parallel and coplanar:
It is useful to twist the cable that connects the block with the toggle until they are more or less perpendicular. But then, all things considered, perhaps not even a great deal of precision is required, which might even seem forced.  In the Nao of Mataro they are not very tidy....
The rope between the blocks was held taut while the shroud was smeared with diluted vinyl glue, to keep it straight:
It seems to me that four shrouds on each side makes a better visual effect, compared to the AMATI instructions:
1818355646_100_2100(2).thumb.JPG.c44c329e29c0317d3f909ba048e14fb8.JPG1922025370_100_2088(2).thumb.JPG.b148f9a571104e619a200cf707bcfc18.JPG
1679915431_100_2104(2).thumb.JPG.f10174181671df1e1e1d89e83bb12d65.JPG 1192851854_100_1974(2).thumb.JPG.2215dd2226ef0fecb8a881ac921454c1.JPG
Next step: the stern castle.
Good work to all the modelers!
Rodolfo
Link to comment
A warm welcome to all modeling friends!
The sterncastle was already prepared previously (see posts #67).
The AMATI instructions recommend making four square incisions in the main rail, within which to insert the bases of the castle supports themselves:
000_3986.thumb.JPG.0edd4cec26fcda96a47f786536114f4a.JPGBecause I doubt I have the talent to carve the main rail perfectly to accommodate the bases of the castle, I then drilled four holes in the bases of the castle itself, into which I injected two-component epoxy glue, so it wouldn't dribble out at the end of the gluing.
Then I laid the castle down trying to make the bases look like they were resting on the bulwark stanchions:
100_2166.thumb.JPG.18b6459544ea5215d8d599af6f662edc.JPG100_2167.thumb.JPG.cb955febc87d3929e1f4942f6abf4630.JPG
100_2160.thumb.JPG.caff9cd834566c0f67377920ed7bd74d.JPG  100_2162.thumb.JPG.53bd32c4ab711ed950cfe70d54adbdd3.JPG  100_2163.thumb.JPG.b0e2e9d3dbab9f073f7c6f95f3a9f174.JPG
The solution I adopted does not correspond to that of Nao of Matarò; in the next post the suggestions for a better job, I hope.
See you soon!
Rodolfo
Link to comment
In truth, the stern castle of the Nao of Matarò is more displaced towards the stern, it is also narrower and has three supports per side, instead of two:
135762062_mat9.jpg.c789e51647566b604b4a2539561288ba.jpg.1486193eab388cac7ee102343564498e.jpg 562849916_mat6.jpg.963b06d51e13870ca53bfb48e547454f.jpg.e2b7554661e3e8f94790f117649c28ec.jpg
We can see it is clearly close and inside the stern handrail. Because the Nao does not have visible stanchions, since the sides have been inside and outside planked, it can be deduced that the supports of the castle are in the interspace between the inner and outer planking:
Unfortunately, in my model, I was forced to the solution previously illustrated by the initial setting of wanting to lengthen the deck aft (see post # 5), combined with the insertion of false stanchions halfway between those protruding from the frames.
At this point the alternative was to move the castle aft, making it lean on the mainrail (unrealistic) or put it where it is now, giving the impression of bearing on the stanchions. I preferred the smaller evil:
which after all, is not very different from what the instructions suggest:
One solution might have been to add additional stanchions under the mainrail, but space isn't too much and perhaps the vision would have left something to be desired....Obviously, with hindsight, I would make from scratch a stand-alone structure for the castle, with the mainrail prepared with the appropriate slots for the supports; now for me it's too late ...
See you soon!
Rodolfo
Link to comment
  • 5 weeks later...
A sincere welcome back to all ship modelers!
The anchors were assembled in the early days, while I was assembling the structure. I did some changes but now I don't like them anymore:
100_0829.thumb.JPG.77b1085425416c93a34aa90374e04c31.JPG 100_0825.thumb.JPG.482be2bb00f11ce50529f4ff4e886b55.JPG
The stock is a single piece, instead of two laths side by side, the veining of the side doesn't seem realistic, the top and bottom are unnatural, for the bindings I used a too large rope and the palms have an unreal relief due to the joint of the molding. First I filed away the relief of the palms, then I painted the metal with matte black and a layer of rust:949044940_100_2113(2).thumb.JPG.3e6d3af4b4b985918acd6f9cc7796157.JPG
Since I didn't have two 2.5 mm thick laths to couple, I used a 5.1 x 5.2 lath, drilled it in the center, engraved in the middle and shaped it:
100_2186.thumb.JPG.f3fd11144b73ea31abdf08d8b07d72aa.JPG100_2187.thumb.JPG.d7742668f9bff6880b3c4b32df2a3308.JPG100_2188.thumb.JPG.0c7aab6f404aedd195d5948d0a61591e.JPG100_2193.thumb.JPG.38de6cdb5835c85508fc72682916bb34.JPG100_2195.thumb.JPG.47514749dbf95e31a6c1e32b287f5471.JPG100_2204.thumb.JPG.0a18acaabefff94c39717aa439e56e6b.JPG
The bindings on the stock are made with a smaller diameter rope than on the previous anchors:
a.jpg.18e50b74ec84e761d1d5cb7d173066d9.jpg b.jpg.7de74acf6cee331c6831faefbd0af185.jpgc.jpg.f105210970aadecf777b59da4f98984b.jpg
The original anchor ring seemed too narrow for the large cable supplied by AMATI, so I made a new one with a 1 mm brass rod, bent over a 4.85 mm screw shank:
However, it is difficult to cover the closed ring with rope. In the next post we will complete the anchor.
See you soon!
Rodolfo
Link to comment
Since it is difficult to cover the closed ring with rope, I preferred to wrap some 0.3 mm grey wire around the straight rod, put a very small veil of cyanoacrylate adhesive, let it dry and then fold it:
f.jpg.e2cbe7cb0f1cdbfb944bf8c5f057f6a7.jpg g.jpg.c035e2f6b67edbd5096077460642ede8.jpg
It's best to wrap plenty of wire to make several rings, as they can also come out wrong, especially the first ones:
This is the final aspect of this rather important component:
x.jpg.5ef1dd17a85f3c9173b620cb93c92ce2.jpg y.jpg.ad9e14cc9f6c2ba334ab8d18f32d7888.jpg
Connected the tow rope to the anchor using the system shown:
Next Step: the anchor buoy.
See you soon!
Rodolfo
Link to comment
Link to comment
Indeed, very nice work on the anchors (and the whole model of course)
Regards, Patrick
Link to comment
Thank you Steven and Patrick, and a warm welcome to our ship modelers friends!
Regarding the presence or absence of anchor buoys on medieval ships, there is a certain discordance of opinions. Many say that since there are no images of these objects before 1700, they were not used in the fifteenth century.
Regarding the historical fidelity of the buoys on medieval ships, it is true that there does not seem to exist figurative documentation at that time, but it is also true that they were probably considered of little interest, so much so that not even in a French book of 1677 they don't appear in the alphabetical list:
1987354913_architecturenavale1.jpg.fd59c6a58ad77f8d9708676cd8b2c58d.jpg    681755296_architecturenavaledictionn..jpg.40054d0d15ba202ea89dafbb2b68273c.jpg
They are not listed among Bordage, Bouge, Boulines, Brevils and so on. However, in the same volume "L'architecture Navale" by Dassié in 1677 there is a reference to the buoys, called "bouyes" (only one reference in more than three hundred pages, demonstrating the little interest of contemporaries). It is found in the inventory of a first-rate vessel, to which four buoys (quatre bouyes) compete for seven anchors in total:
327058535_architecturenavale2.jpg.a7d11d5f9d49b87f0ed1728cfdcaa245.jpg   971857678_architecturenavale3.jpg.71d6ce3f800b2ee41fbce276c8cfb7d6.jpg
But in another volume, "Sailing Ship" - by E. K. Chatterton of 1909, there are some very interesting indications. On page 147 is written that anchor buoys were used to "prevent ship fouling each other anchors" at the time of Richard I and his crusade:
The buoys are still mentioned on page 178, revealing the material from which they were made:
To conclude, on page 185, buoys are listed as normal shipboard equipment, along with lanterns, etc.:
I am not a historical, so I am unable to assess Mr. Chatterton's expertise and thoroughness, however, I am glad to have found something that supports my choice.
And now we're going to build our anchor buoys.
Rodolfo
Link to comment
To make the anchor buoys I used the remainder of the 10 mm rod used for the mast. Not having a lathe, I had to use a pencil sharpener to make the two cones and a small hacksaw to make the center disk.
371557232_100_2079(2).thumb.JPG.4f686886e8b7a84752add7240f1a97e8.JPG   2025883325_100_2117(2).thumb.JPG.55b511dd0a7c8c73ca2a6ad04923bbef.JPG
775731521_100_2118(2).thumb.JPG.8622cf43130e6234ceaa7d36134b14fe.JPG1943805164_100_2121(2).thumb.JPG.af0166daf45e1501f48863b40b3fd19f.JPG
With a blade you can make vertical and horizontal incisions. Then they need to be drilled at the ends to accommodate the rings.
1636998006_100_2123(2).thumb.JPG.09f37d70728769c96ddc8668f0e243b2.JPG  100_2137.thumb.JPG.660a498261c707a3e042fa0146e9b20b.JPG
The dimensions seemed excessive to me and I proceeded to reduce and shape with sandpaper and drill until I got a result that seemed satisfactory.
Next step we'll finish this object.
See you soon!
Rodolfo
Edited by Rodolfo Bigoni
too many pictures
Link to comment
These are some kinds of anchor buoy, I suppose not all suitable for the Cocca:
Since it's an object that needs to be visible to mark the position of the anchor, I thought I'd color it matte red. Then proceed to build the rings, which can be made of metal (to be blackened) or rope, as I preferred to do.283113842_100_2138(2).thumb.JPG.3e9c1a615dee0211becdbdb783a815dd.JPG  1490139492_100_2139(2).thumb.JPG.35610f36fea25fcca6c6e3333b69deb1.JPG
After that you build around it that envelope of interlaced strings; it's a job that requires a lot of patience:
1426769691_100_2145(2).thumb.JPG.bcf9bc3adb53171bd2fb35c6175eb9f2.JPG  1333325691_100_2146(2).thumb.JPG.71403f3cdfb9028b66b04c54ab87d7f7.JPG
And this is the result...now it has to be connected to the anchor.
See you soon!
Rodolfo
Link to comment
Dear friends, now it's time to go around the top. The manufacturer AMATI gives this solution:
100_1047.JPG.49ae120e54de8573cecf3ebf7462a51b.JPG 100_1041.thumb.JPG.f477bec91c6f7ae35c213105b653c298.JPG
All in all, it can be considered acceptable.
But I really like the way Clark Griswold elaborated on his Coca, so I made 16 symmetrical openings and after I inserted some pieces of walnut lath on the bottom, taking care not to interfere with the ropes:
  000_4913.thumb.JPG.cd92b63b5987129ed29deb60f19d2d20.JPG 000_4914.thumb.JPG.59c0b55b7f0d8ef640a497ce912e6f82.JPG
1616272640_000_4918(2).thumb.JPG.958e84d9dd405b2618f73436a8ed7edb.JPG 86922662_000_4920(2).thumb.JPG.b6a636d2a51a1ed7587a1ee706f27ca7.JPG 1546795502_000_4921(2).thumb.JPG.faf8ad124aff3567dbf38445707f8675.JPG
I colored it white with red dots, because I saw a similar scheme on: "Historic Ship Models" by Wolfram Zu Mondfeld, (although in black and white).  I used opaque acrylic paints, first dark red and then white (after covering the red circle areas with adhesive paper discs). After that, I gave it a very light rubbing down with very fine sandpaper and water to further dull the colors.
Some of our colleagues suggested to give a pass of diluted black/brown/grey satin color to further age the top and I think I'll try that.
Another solution could be to build a new one, like this draw of Xavier Pastor, in his book "The Ships of Christopher Columbus":
An Italian modeller built it so and it seems very nice:
coffa6.jpg.5371b37c241c881f8456b2ec7e65205e.jpg coffa7.jpg.03dd6eacc80ede27784f64f6e36d0035.jpg
See you later; next subject will be the yard braces.
Rodolfo
Link to comment
Thanks a lot Steven, for the support and suggestions, always appreciated.
After a lot of meditation, I realized what I didn't like: the top is " aged " while the ship looks like it just came out of the arsenal. So should I rejuvenate the top or age the ship (the latter option is very challenging...)?
The desperate search for a loophole suggested me this way out: at that time there were not our brilliant synthetic solvent colors, the binder will have been egg white or some oil, probably a year of sun, wind, rain, salt, hot and cold, dry and wet could have ruined the dye, maybe bought cheap and of poor quality. Moreover, it is not a warship always kept shiny, it is an honest boat that must give profit with little expense ... A good wood instead could resist better to the marine climate.
True or false this hypothesis, my conscience is silenced and so I continued with the yardarms:
A.thumb.JPG.dfc7b0c1195c490958ee36f23699663f.JPGL.thumb.JPG.f243374d249e6a56e3b9641b4b5a51ed.JPG  M.thumb.JPG.39b1fe5f8b495c969b5ebca18a425dab.JPG000_4946.thumb.JPG.bc2fa2b7a61ed9a1c8164e3d412940ef.JPG1420793995_000_4948(2).thumb.JPG.5ec1f48775fbac02d600ec00e4bdcfaa.JPG
I hope for you all a much better New Year than the year that is ending now....
Rodolfo
Link to comment
Beautiful work, Rodolfo. Yes, I think your justification for the paintwork on the top is a workable one. The only other alternative would be to re-paint it but as it's already in position at the top of the mast, I think that would be too difficult.
This build is a pleasure to follow.
Steven
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
