USS Hannah by GrandpaPhil - FINISHED - 1/72 - Card - from Hahn Plans
Looks great Phil, is the second planking similar to a self adhesive vinyl paper?
Will any multi purpose filler work as spackling in the UK is nearly £30 a tub?
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Share on other sites
Edward,
  Thank you very much!
  The second planking is self adhesive vinyl.  I would think any filler would work.  I have used drywall mud and other fillers on models before, with success.
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
First side has a second planking (read covering):
It’s a little rough, but it’ll look better soon!
Link to comment
Looks good Phil, the "planking " works very well 👍
Current builds;
Completed:
Link to comment
Thank you both!
The port side is now second planked above the wales:
Link to comment
Make sure you seal the vinyl with a good sealant.  I typically use Mod Podge or Delta Ceramcoat Sealer.  Otherwise, there can be issues with the paint adhering well.
Link to comment
The second layer is almost on:C59FB116-7A1C-4F2F-AAAB-88EF14DC7975.thumb.jpeg.0717a56bea503643aef03c8830919a5c.jpeg
The port side went on neater than the starboard.  I think I was a little out of practice, lol.
Link to comment
Thank you all for the comments and the likes!
The second planking is done:
The next step is sealing that and planking the deck!
Link to comment
What did you do to make look better? whatever it was worked,  it is great!!
Current builds;
Completed:
Link to comment
This is great, a fun log to follow. Like the story with the ugly duckling-all will fall into place in the end!
Link to comment
Thank you both!  I just finished the other side and sealed it.  Everything will look much better once I get some painting done.
I finished planking the aft deck.B15CFBBC-79F1-4943-8FC0-5046587FA9BC.thumb.jpeg.92b3ee5cd249b545b7f010a5613f0144.jpeg
I planked the entire Prince de Neufchatel, painted it and coppered the hull over a four day weekend, so I was trying to figure out what the difference was, because this is my second weekend since I finished the first layer of “planking”.  Then I realized that I did the work on the Prince de Neufchatel literally during a blizzard when I was snowed in, and not in the middle of the summer when I have stuff to do, lol.  It’s amazing to consider the effects of the seasons.
Link to comment
The forward deck is done:
Which means the entire deck is now planked:
I added a couple trim pieces:
Next step is to seal the deck and cut out the scuppers.
Then I’ll add the gunport frames and paint the hull.
Link to comment
Thank you all for the likes and for stopping by!
The gunports have frames:
6EA02BD2-A194-49F3-B6D9-152BFC0F4012.thumb.jpeg.0262eeba8c869891ec39eaecb69a2a28.jpeg416B5A06-5D9B-4D76-BD54-D3B0EED8A929.thumb.jpeg.b775a168bc94e50b9e0dd63b56e65721.jpeg
I’m currently working on making scuppers.
Link to comment
The scuppers are now done:
03A48F46-3B6F-4AB7-9D26-B8DFF0B7E7D5.thumb.jpeg.52250a07bc8c6c6f0dce8e3a22b64741.jpeg3FBC5481-F7D0-4B1B-9851-76D94B248A5B.thumb.jpeg.ce6a1e6b5c94577833e1e462a8f06d12.jpeg
Because I used that hought board which fuzzes, I sealed the inside of the scuppers using a dental pick to apply sealant.
In the painting from the US Navy’s History and Heritage Command, there are ribs on the insides of the bulwarks, so I am going to incorporate those prior to attaching the cap rails, which will go on prior to the initial painting.
Link to comment
By inspection, I am going to call these 3/32” wide, spaced 3/8” apart:
Link to comment
Hannah is looking better all the time!  You are doing a fantastic job with her Phil.
Current builds;
Completed:
Link to comment
I have installed the ribbing on the starboard side.  They ended up 1/16” wide, but the 3/8” spacing stayed, for the most part.
The port side is done on the forward deck:
I measured off the framing for the transom/transom rail.
The painting is different from the Hahn plans, but I like the look of the stern better, and since Hahn created his plans of the Hannah based on conjecture...
I do believe that I will make my stern look like this.
Link to comment
I am working on the cap rails:
F5CD3FD5-9E94-43D3-9DBE-3A0BEAB5E4BC.thumb.jpeg.19846615a60e030869c1977dad2e4fc6.jpeg1C271D50-8C8C-4165-8DFC-4D8EFA564D20.thumb.jpeg.554770575d5478c9c3152add129b7e2f.jpeg
For anyone who is new and would like to learn to make cap rails, and I used to hate making them, the trick is to flip the model over and trace the bulwarks.  After you get the profile from the bulwarks, add a little bit on the outside, so it overhangs just a smidge and make the inside line such that it overhangs just a smidge on the inside.  It is very quick and very easy this way.
For me, my bulwarks are approximately 1/8” thick.  I wanted a 1/16” overhang on both sides so I could trim at will.
I traced my bulwarks and added 1/16” to the outside and 3/16” to the inside.  Then I cut it out and made it double thickness.
When I got ready to glue them down, I used the trial and error method to get my exact contours during the dry fit stage.  Once they fit perfectly, I glued them down.
I don’t bother trying to edge bend wood to get a cap rail, even on wooden models.  I trace it from my bulwarks and cut it to shape.  It is much easier and avoids the splitting issues and the resultant profanity that edge bending usually causes for me.
Link to comment
While waiting for my bulwarks to dry,
I started working on the transom (I promise that painting will happen in the near future).
I knocked down the transom about 1/16” to make the gap that can be seen in that painting.
Link to comment
The cap rails are on.
B84AA515-CB27-40C7-A8E2-EE7C24A79412.thumb.jpeg.a6c4d74d4199dbbdf3e58e2fda2cb930.jpeg72406E8F-1170-450E-8109-C726ACA5CA71.thumb.jpeg.26d19897d7128f622c662c20107c3be4.jpegD45110C4-D277-47DD-80F1-22525ACCF8D0.thumb.jpeg.0198eb2334b4de5dc419d687491e17e1.jpeg4DC79976-F1A7-4D4C-A146-A48F6575A84C.thumb.jpeg.e48186cce3c554c16af481d70c91c8d0.jpeg
The only railing remaining is the taffrail.
Link to comment
Hi Phil,
Good tutorial on the capping rails.
Have been using this method on wooden kits ever since a kit instructions told me to edge bend
2 x 12 mm walnut.
I cut and scarf joint extra wide strip of the required thickness to follow the rail plan curve
then mark the bulwark line and width as your instructions.
This approach lets you follow the grain around the bow portions and give a more realistic finish.
This is really starting to look good.
Keep up the good work.
Sam
Link to comment
Thank you both!
Yes, the gun carriages will be made of card.  I’ll use the exact same method I used for the Victory and the Prince de Neufchatel.
Link to comment
Working on the taffrail.213F237C-5B3E-45F7-B043-665EC9743F1A.thumb.jpeg.5a8cb07216d064f280947b995a4ffb6d.jpeg
Link to comment
I've just caught up with this log - very interesting. Well done. I'll keep watching now.
Cheers
Richard
Next build:
Completed builds:
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
