USS Hannah by GrandpaPhil - FINISHED - 1/72 - Card - from Hahn Plans
Coming along nicely Phil!
Thank You all...
Mario
:piratetongueor4:  :piratetongueor4:
"Each of us is a mixture of some good and some not so good qualities. In considering one's fellow man it's important to remember the good things ... We should refrain from making judgments just because a fella happens to be a dirty, rotten SOB(biscuit) ;) "
My Builds....
BETTEAU WAR OF 1812     BOUNTY LAUNCH(bashed)    CHESAPEAKE BAY FLATTIE
THE SEA of GALILEE BOAT   VICTORIAN STEAM LAUNCH(bashed)    HOWARD CHAPELLE's CRABBING SKIFF
LADY KATHRINE 1812 SCHOONER
Link to comment
Share on other sites
Thank you all for the comments and the likes!
The taffrail is made and installed:
EA11CCC1-5E94-4C69-9958-5F50EBF22A3F.thumb.jpeg.d7435939014225895258461d924cf5cf.jpeg426D5136-A4AE-4030-84EA-3F0CA70EC73F.thumb.jpeg.f72c1c86ab2a99415ab5bdb555c973e1.jpeg
I used CA on the edges, over the PVA, so I could have something to carve smooth and blend the railings.
I have a few minor spots to fill and then it will be time to paint!
Speaking of which, I am going to treat Hannah like a wargaming miniature and basecoat/prime black.  All vinyl is already coated in sealant.
Basecoating in black gives depth to the model and will help give the ship a well-used/gritty look.
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
The painting begins:
E0FABB27-509A-4E8D-B918-89E76200932C.thumb.jpeg.6d2ef6fb259a7b2cbb9b10117d0f53d6.jpegThe base will be a medium brown that will be final coated with gloss mod podge, just like the base for the Prince de Neufchatel.8253ED9C-AB07-4718-BDEC-1EB2D4C63CEC.thumb.jpeg.8c18582ef91cfb94e345f95ba401f0a4.jpeg
When I paint models or miniatures, I like to work from the inside out.
In this case I will paint the deck and lower hull first.  Then I will paint the yellow stripe and then all bulwarks, which will be a barn red or burgundy color.
Link to comment
The lower hull is in the process of being painted and the base is done:C08C44DF-D960-4451-81CC-CE2BF2CF1CAF.thumb.jpeg.49c1d297ffec4adc51ab39de10c605e9.jpegBA5BB2BA-2E88-4CAD-AD10-3A53487FC5D0.thumb.jpeg.a3ac8ef25a48feb3d80b418a7998811c.jpeg
Link to comment
The lower hull is now a dingy white color.
Working on basecoating the deck.387959B4-9C00-4628-B0B6-4E0B45A636DF.thumb.jpeg.deec166378a6fdf6707acb9b27bab74e.jpeg
Progress has been slow, but life is busy, lol.
Link to comment
The journey from sloppy wet cardboard to this is amazing. Great job, Phil.
Link to comment
Hannah sits well on her stand:
The next layer on the hull, working from the inside out, is the yellow band.
The next layer for the deck will be the inner bulwarks.
Link to comment
I added all burgundy and the black striping.  I also taped off the yellow stripe and brought the burgundy down to it.
F9679786-5CB6-4E94-BF42-0586CD331D5C.thumb.jpeg.6f0c8e46910ff9101b8db7e90a03b812.jpeg5ED60439-0B05-4BE2-AF09-7057D35A33E4.thumb.jpeg.da7f5940bcd65ff28e9287e8d93951c6.jpeg91929FAD-CCD2-4FDF-B198-351FE3FBCB2A.thumb.jpeg.50138d1658b1902afb6dfaa6c3e894db.jpeg
The stern is conjecture.
Link to comment
A quick diversion:
Castorland, from Poland, makes some really nice nautical puzzles.  I like them a lot.
I like to glue them and frame them and then the Admiral likes to hang them in her house.
Link to comment
The base coating is done:E1BFA7FD-51A3-45D5-B4B4-5DC0C59B511B.thumb.jpeg.08e15fdee9f2d2a6d05aef82d9e848ce.jpegCCC8C5B5-8B38-45A6-96D5-866A5A62E548.thumb.jpeg.b7bcef07319eb8bd4dcad9851499fc6b.jpeg
Link to comment
One test fitted rudder:
It sits low on the deck, but that’s how it is on the plans too.
It’ll work!
Link to comment
Phil, the hull is really amazing considering that bit of nonsense you started with. Hats off!
Link to comment
I suppose if I sealed it well enough, it would be waterproof enough.
I have seen card ship models built for RC before, so I know it can be done.  Personally, I would never put a ship model in the water.  I’d be too afraid of something going wrong.
As it is, I do seal the card models periodically during construction, otherwise they won’t age well.  Environmental humidity will wreak havoc on a card model.
Link to comment
The rudder is painted and the banding has been cut:
I’ll use a pounce wheel on it to make the impression of rivet heads and then paint it a dark gray.
Link to comment
I’ve been busy today as evidenced by my messy work area.
The rudder is pinned in place.  The curly pieces for the rail trim are in place.  The first set of posts for the swivel guns is in place.
0B6926F1-021A-4FB6-B22D-D73F539288FF.thumb.jpeg.10cc5cf44554bc8a2c12e9c7275fc5dd.jpegF8F4C7D4-D46B-4FA9-AB05-D4AB5D610924.thumb.jpeg.ec246c507e3fbc036768dae92877fc9f.jpegC22C35D7-CE55-457E-8168-DA31BED9F425.thumb.jpeg.6f7d9a6ec1fcede6f06556637ba07d75.jpeg
Link to comment
From card and filler to a good looking hull!! Great work Phil 👍😁
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Thank you very much!
The aft swivel gun posts are made:
5F78B3B8-6B41-4447-8366-D45654B761CB.thumb.jpeg.eb1ff5d1811015657c750cce0e66540b.jpeg243CAE32-30D1-4B6D-9189-C978651F7BAB.thumb.jpeg.4935ace91ca4cf216b45cf4c2618f964.jpeg
Next up will be the remaining four post up by the bow and then the timberheads, catheads, hawse holes and all the sheaves that need made, also by the bow.
Link to comment
All swivel gun posts are made:
9C63F6B4-1FE1-4B1F-B713-4DF06DFBB450.thumb.jpeg.53bd54b77181917e41cab47b9b68672f.jpeg5D29919D-8736-4F4E-B807-E57CEB04BCEA.thumb.jpeg.49351165817713a18166252e0a99c1ce.jpeg927988BD-1E1A-4CAE-993E-00C47D50B514.thumb.jpeg.fc2b3a76fb7de92a0126973f5620f25f.jpeg
A bit of my personal history.  Railings, swivel gun posts, timberheads and the like, and I, have never gotten along well.  They are my least favorite parts of a model ship and I don’t know why.
They nearly ended the Sultana, which was my first real ship model.  I did not enjoy them at all.
I did not have a problem with these.  They aren’t perfect, but they will do.
Link to comment
Thank you all very much for the comments and the likes!
All timberheads and knightheads are made:
I punched holes in them so I can pin them in place following recommendations from another member in an earlier project.
I go through a lot of sewing pins, lol:F8E23BE1-804A-40E9-BBC9-C7F8F461DFC3.thumb.jpeg.1a19657e02e7fb98f8e870798bd5aec4.jpeg
Link to comment
Sewing pins are cheaper and easier to source than wire stiff enough for the job required, 😁 necessity is the mother of invention.
Great stuff Phil, this really is fun to watch
Current builds;
Completed:
Link to comment
All knightheads, and timberheads are done and installed:
E8F8AC36-95DF-41F1-A277-A1CF71F13CF1.thumb.jpeg.44975ba884c905168cc09c23388c3701.jpeg0989F6BA-D031-45B8-864A-DF52ECBA7BEA.thumb.jpeg.bb3a48209a07bf484a326b66fadcf487.jpeg
Here are the catheads:
Now, she just needs some hawse holes, a couple of sheaves and some channels, and that’ll be it for the outer hull fittings.
Soon, I’ll have to decide what to do with the stern.
Link to comment
The channels are on.  I still need to make some brackets, but that will happen in the near future.  I did not go crazy with steel pins, like if this were a wood model.  This is card, so there won’t be any crazy tension on the shrouds anyway.
54691360-DF36-4B87-AC8B-606945A8A81E.thumb.jpeg.cd57cd88a8478753d56e74c852ce693f.jpeg30028438-F918-44C2-9381-3F4F2E16914D.thumb.jpeg.450f82607115839e0981c2b52033d933.jpeg
The reinforcing pieces for the hawse holes are on. 2E91868F-A316-4649-9441-500201119E26.thumb.jpeg.7b1920593c766fa039f7e0ab0a8433e8.jpeg
Link to comment
The brackets are made and installed.  All gaps are filled and the Hannah is ready for touch ups.
5746CB74-92FA-4277-B9FA-DC7ED7975102.thumb.jpeg.716da0d3502bab997acff58b634bc1d8.jpeg77314282-EDBD-4C47-A2B4-55D2A92DB821.thumb.jpeg.08e7077064b2878a09f993c1e33c29fd.jpeg50795C10-48B2-4A97-9526-A9A6D38064F8.thumb.jpeg.14a0a00d921fd7016db48ce2bc4eded9.jpeg34AB6CB1-EAD9-4227-B0A0-12632196F92A.thumb.jpeg.beb49ba6283c346ff747ba8d5da56762.jpegD4321CC2-17F6-478C-97F2-44C761D12E34.thumb.jpeg.b7434b7cb9129e1f812031d6a2c6f2a0.jpeg
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
