HMS EURYALUS by Matiz - scale 1:56
It never dawned on me to make so many things off the ship then install a complete unit.   It has to be much easier to assemble ahead of time but getting an exact fit into the hull must be exasperating at times. Templates, templates, templates.      Beautiful work!!!
Allan
Link to comment
Share on other sites
Fabulous as always!
I have never seen the lanyards to help open the shutters by the lights, but it makes a lot of sense.  Is this something you have seen before?
Thanks
Allan
Link to comment
Tiziano
Are the two colors of wood used on the foremast partners different types of wood or was one stained?  I really like the contrast as it shows the individual pieces very clearly.
Looking forward to the next post!!
Allan
Link to comment
I ran out of complimentary words for your workmanship.  Beautiful as always.
Allan
Link to comment
Over the top!!  You are leading us on a ride that is more fun than anything at Disneyland!!!
Regarding the hinges, did you make the hollow tube in which the pins go or were you able to find hollow tube stock from which to work?
Are the plate and tubes and plate and pins soft soldered or silver soldered?
THANKS
Allan
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
