Macton locomotive works III
Michael, Look up "Fast Tracks" They sell all types and scales of templates for hand building track and turnouts (switches to some). You don't have to buy one but the picture of one of the dual gauge templates would answer your questions.
https://www.handlaidtrack.com/
Link to comment
Share on other sites
Thanks Ron, I ended up finishing the points or switch as some call them. I am progressing on the wagon ironwork.
All the axleguards are now cut.
next was to get the strapbolts made .
Then the next piece of metalwork is the headstock and sole Knees
These plates are part of the whole buffer and strengthening of the frame Now that I have a prototype I can set up to make the four needed. The strapbolts are turned from 1/8th brass rod with the bolt part being .060" and threaded 0x80 and the section that gets flattened is turned to .095" this eventually becomes .140" wide by approx .040".  and the knees are  .040" copper they have been blackened in some Jax Blackener.
Michael
Link to comment
Michael, looking at the strap bolts, I take it you pressed the strap end? cause the eight bolts lined up against the vise jaw don't look like the strap end is big enough to cut it...
Nice work btw, I wish I could machine that small...
Quote:
Link to comment
Hi Egilman, yes the strap bolts were flattened in the vice they needed 4 annealings to get to the correct width. I created a small jig using some tool steel blanks as in the next picture.
The bottom piece if steel has a piece of shimstock to create a slide fit for the top piece of tool steel that gets hit with a hammer using a piece of brass between the steel and hammer.
The edge next to the bolt section has a small radius on the top anvil (tool steel)
Michael
Link to comment
Yeah I get it now, I figured it might be something like that... Cold forming after softening the brass...
The mill vise and tool steel setup hinted at it also.... Ingenius old school foundry practice in miniature.....
It's been so long since I've been in a machine shop I forget sometimes.....
It reminds me that all we are doing is practicing our trades in miniature..... the skills and knowledge remain the same.....
Thank you for the looking in at your wonderful work....
Quote:
Link to comment
It's good to see you back at the modeling bench Michael.  This is a great project and I hope you don't mind another head looking over your shoulder.  I've always enjoyed watching your problem solving and approach to part creation.  Looking forward to more updates.  You're off to a great start - sweet joinery on the wagon by the way.
Gary
Completed Scratch Builds
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
