US Constellation 1798 by Jack12477 - Artesania Latina - 1:85
For my next ship build I decided to finally drag the Artesania Latina US Constellation kit out of my stash and start building it. It was given to me by a good friend as a birthday present 9 years ago and has languished on the shelf since then; partly because it was intimidating, but mostly because I did not have the work space big enough to set it up and build it and lastly I did not know where I would display it once built - still don't but that will be dealt with later on.
Even the box it comes in is huge and intimidating.
I first constructed a build board that will hold it. Unfortunately I routed a groove along the centerline of the board to hold the keel but when the keel sits down in the groove the bulkheads don't seat fully, so I set it flush on the board and screen small cleats alongside the keel to keep it upright and straight.   Some startup photos are below:  So far I have dry fit all the bulkheads, sanded them as needed and am now slowly gluing them in place use small pieces of aluminum angle to keep everything perpendicular to the false keel.
IMG_8435.JPG.e5e0e75eacc6ece1ea1df4010f74cbe3.JPGIMG_8436.JPG.f3aedf40c923cecaf276f9ac795d3fe2.JPGIMG_8437.JPG.468f04ef3054738123fe5878953c4bf9.JPGIMG_8438.JPG.95a4aca49e91e32f4b07c27f540b5192.JPGIMG_8439.JPG.f1a13e9ede8b887698dded51782d1db2.JPG
At this point everything is just dry fit
Edited by Jack12477
Link to comment
Share on other sites
Found you!!😉 promising start Jack, that hull must be about 2ft long!
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
2 minutes ago, CDW said:
Looks like the box says it's 40 3/4 inches, but maybe I'm reading it wrong. It's a big one.
WOW!! That's huge, that must include the bowsprit and the boom. No wonder Jack has got to rearrange to display it.
Did you have a good trip Craig?
Current builds;
Completed:
Link to comment
I'm here Jack...  I'll have you know that I seldom come in from shore leave, so If I start bumping into things or asking dumb questions it's cause I'm seldom at work in the shipyard......
I"ll try not to make a fool of myself.. I promise.... {chuckle}
Sorry for derailing the other. (it wasn't intentional)
EG
Where's the popcorn....
Quote:
Link to comment
You have a pretty good eye. It is 25 1/2 inches  as it sits on build board. Build board is 3 ft long
Correct! Finished size. It is just over 6 inches wide before planking.
 No problem! Just didn't want that discussion to get lost over there. It is worth knowing.  I did visit this ship in Baltimore a few years ago with the Admiral and our youngest granddaughter who had to explore every inch right down to keel.  It is a really beautiful ship regardless of the history of its rebuild/restoration.
Link to comment
It was super. Weather was beautiful, warm days and cool nights. We got our youngest daughter all settled into her new living arrangement with her oldest sister then we came back home this past weekend. Feels strange with just the two of us at home now.
Link to comment
Yep ! Now you know why it sat on shelf for 9 years ;)
Link to comment
Finished dimensions are
Length  40 3/4 inches  or 1035 mm
Width  6 1/32 inches  or 153 mm
Height   27 15/16  or 710 mm
The odd values are because the original measurements are given in metric
Link to comment
7 inches shy of 4ft, I think you need to find her a room of her own!😏 I thought Winchelsea was big at 38 inches and she's not going to be rigged.
Current builds;
Completed:
Link to comment
Or I could build a backyard pond, waterproof the hull, and float her out there. But then winter ice would be a problem. :(
Link to comment
A room of her own with a pond! Won't  freeze over in winter🤪
Current builds;
Completed:
Link to comment
Putting bubblers around her would be cheaper.  That's how they protect the Clearwater sloop here. And the Coast Guard boats.
Of course maybe I could sail my scale model ice yacht Rocket on the pond with the Connie in background :D
Link to comment
The Connie can handle it...
Quote:
Link to comment
I bet they had bubblers in the water around the for protection.  For those who don't know what an ice bubbler is or looks like see photo below. This is one type, basically it churns the water up to such a degree that ice cannot form.
power-house-p500-ice-eater-for-individual-boats-slips-eaters-garage-department_731_1024x1024.jpg.9c6a53d8425cd7fe2842941e34c63d9a.jpg
Link to comment
Okay, back to the build. I finished gluing all the bulkheads in place makin sure they are perpendicular to the false keel. Right now I am dry fitting the decks to see how they fit. I notice that 3 will need some type of blocks at the outer ends to keep them from sagging and rocking since the only support is the false keel in the middle of the deck. Photos will follow later once I finish testing.
Link to comment
My bad for discussing this on your other log.  I promise to try and play nice.  :)   I have popcorn!  Does that forgive my sins?  :rolleyes:
As for putting it in water, Jerry Todd has a scratch built one in the "extremely dark side" area.
Link to comment
That's okay. Can you as a MOD move those last few posts over here. Would add to the discussion.
I think I recall seeing that one way back
Link to comment
Well looks like the whole gang is here plus a few new viewers, just missing OC and "Spinach man" I guess.
@toms10  good to see you again. I will be using your logs as reference. Yours also Mark.
Link to comment
They are probably stuck in traffic or the sat nav is playing up.😏
Current builds;
Completed:
Link to comment
3 hours ago, Jack12477 said:.
I hope they are of some use to you
Tom
Link to comment
Tom
I have two bundles of very thin veneer - one is a yellow/white which I think is ramin  other is a reddish brown is this mukali ? It  seems to be the only one that matches the dimensions in the parts list 0.6 mm x 5 mm x yyy  mm
Link to comment
Sadly, I can't.  Just no way to move a post by itself.
Link to comment
Jack,
I'm putting this here in your build, as well as Treesqueak's for benefit of anyone else building this model.  I know we've talked about but I really hate to a couple hundred dollars worth of kit get tossed....
 I do suggest that you read well ahead in the instructions.   The reason is that after they tell you to glue the main deck down, they then tell you assemble and install the guns which is impossible.  We've had way too many abandoned builds happen when they realize that they can't install the guns.
Link to comment
You don't use them anyway, so why bother :P
Carl
Link to comment
Well I know you were hoping that I would be MIA but I found you anyway. Looks like you are well on your way Jack. Just think of me as your Albatross.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
I thought you were in the rigging on the mainyard😉
Current builds;
Completed:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
