US Constellation 1798 by Jack12477 - Artesania Latina - 1:85
Hi "Albatros" ! Oh yea, you were MIA ! Sorry I missed mentioning you.  Have fun in the rigging, be careful of those bos'un chairs, don't fall out.
Link to comment
Share on other sites
8 hours ago, mtaylor said:
Jack,
I'm putting this here in your build, as well as Treesqueak's for benefit of anyone else building this model.  I know we've talked about but I really hate to a couple hundred dollars worth of kit get tossed....
 I do suggest that you read well ahead in the instructions.   The reason is that after they tell you to glue the main deck down, they then tell you assemble and install the guns which is impossible.  We've had way too many abandoned builds happen when they realize that they can't install the guns.
Yea, I've been watching for that step, for now I am dry fitting the decks till I can read ahead a bit. Trying to read the parts list, font is really small and hard to read, seems blurred.
BTW  Tower Hobbies now lists the kit for $385 USD. Quite an increase.
Link to comment
20 hours ago, cog said:
You don't use them anyway, so why bother :P
True... though actually I do use them.. as trashcan liner.  :rolleyes:
17 hours ago, Edwardkenway said:
I thought you were in the rigging on the mainyard😉
'So that's where Lou went?   I was looking for him down by the spirits locker.
Link to comment
Small progress update:  After gluing and squaring all the bulkheads to the false keel. I started on the lower decks.  Totally misread the instructions on the Mukali wood and started using the darker "walnut" veneer instead, after doing the two most aft decks I caught the mistake and switched to the pale yellowish Mukali wood.  Which they had printed photos in this kit like they've done in some of their other kits I've built.  After installing some cleats to support the outer most edges of the decks so they don't become a "teeter-totter", I installed the lowest decks first. Tried applying some stain directly to the wood but it looked to dark even tho I wiped it off immediately. So for the other decks I put some Wipe-On Poly on a cloth and went over the planks with that first then applied the stain over that, wiping off the stain almost immediately. Finish came out looking a bit weathered to my eye.  After this I glued all the lowest decks in place, added the reinforcing blocks for the masts, but left the middle deck just dry fit for now, until I double check all drawing for anything that needs to be added to the lowest decks before I paint myself into a corner - so to speak.
Photos follow
Dry fitting all decks first
IMG_8441.JPG.696d3e4c566b9ae3d97b8ebd1d590e56.JPGIMG_8443.JPG.baa827ecc7b7beeaa607fabdaa28498a.JPGIMG_8444.JPG.af9cd0c94bfb885698db236caa846b68.JPGIMG_8445.JPG.d9834cc673820ba6267f62019ce04290.JPGIMG_8446.JPG.546847dce3901a96be1ae90f67657844.JPGIMG_8447.JPG.7f8122a443c005cd505823f0af3717d9.JPGIMG_8448.JPG.509a7b49e72099bea0d6eb67abcc921d.JPG
Then adding the planking, staining  and gluing in place
IMG_8449.JPG.e8b242fdca5e91e74270a14a40b3fc09.JPGIMG_8453.JPG.64c1997a2bdf8a1d4a1a0036cdf033af.JPGIMG_8457.JPG.ae729f42b41360ccb4031220bd70277e.JPG
Reinforcing blocks for masts
IMG_8455.JPG.32d83d6143aefb60b6e59c2009947bd3.JPGIMG_8456.JPG.1fe4dc1ca74f857c004163ccbabe8ce8.JPG
Link to comment
Nice work, movin right along.... {chuckle}
Quote:
Link to comment
How can I be in the rigging???? You don't have any yet! Now the grog locker! That could be another matter. Is there a shore facility close where I can sit in the window and watch while tipping a few? B)
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Is yew one o' them seafaring gennelmen cos if yew is, there's a welcome at the Saucy Shrimp!
Good ale and hot pies.:cheers:
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Oh yea ! That's right ! Well, maybe you rigged a left-handed sky hook to anchor the bos'un chair. :D;)  At any rate, welcome to the party.
Link to comment
You are making good progress on your Constellation.  I will be following your build log.
Ryland
               - Nautical Research Guild
Link to comment
I was thinking that I might have to do somethings like that but I now have a better offer. I am told that the ale is good and the pies are warm over at the Saucy Shrimp and that it has the same view as the cold shipyard. Winter is coming and this IS a ship you are building not some overnight armored beast! :)
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
But at the rate he's building, he will be done before we are served, then where will be be?
Quote:
Link to comment
14 minutes ago, Jack12477 said:
Are they serving that saucy shrimp with grits or scallops ?
Both if you really want them...
Quote:
Link to comment
I'll pass on the grits. 😝   I'll have them with scallops, pan seared in butter, garlic and a bit of wine. 😁
Link to comment
Progress has been slow for many reasons. One of which is the very poor English translation in the instruction manual and difficulty reading and interpreting the picture book instructions.  As advised by a couple of modelers who've built this kit before me I have not glued the main decks or catwalks down - for now I drilled small holes and set some nails in to clamp them down until I figure out where the cannon go and get them installed, then I will come back and glue the decks and catwalks in place permanently. Some photos
IMG_8459.JPG.3753a2eb914ff164f206c401fb625af9.JPGIMG_8460.JPG.7425c47531669befa3c7aab25203ddb4.JPGIMG_8461.JPG.6b9ce4442a7aeab8d71a54d625cd8ba4.JPGIMG_8462.JPG.deaf30d3d0ad75b7a4e73b742dcb30de.JPGIMG_8463.JPG.f4976d0c6c513af2195e4606d2147bba.JPG
The other reason the shipyard slowed down is because we had to euthanize our 14 year old Corgi last Monday June 29th due to rapidly deteriorating health issues. She has been with us since she was a 6 month old puppy. Her other photo is my avatar photo.
Link to comment
The model is coming along beautifully, Jack. My 2nd wood ship build was an Aeropiccola HMS Swift and the language/plans gave me fits. Otherwise, it was a beautiful model.
So sorry to hear about your Corgi. My little buddy is also 14, and I can see him moving a little more slowly each day. So far, his health has been good but I know that can change at any time due to his age.
Link to comment
Good to see you back again Jack. So sorry to learn why you were gone. I too have been there, more than once unfortunately. They do become a major part of our life over the years and their passing is painful.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
I'd say go ahead and put the fore and aft decks on after you get the blocks in for mounting those guns.    Hang off a bit on the walkways until you'put one gun together and decide how much detailing you'll do on them.
Breaks my heart to hear about the pupper, Jack.
Link to comment
Constellation moving along well!
Sorry to hear about your helper Jack, it is hard.
Current builds;
Completed:
Link to comment
I am sorry to hear of the loss of your Corgi.  Pets become part of your family and their passing leaves a void in your life.  I know it is hard, but glad you are back in your workshop making sawdust.
Ryland
Link to comment
Sorry to read about Sunny's demise. Pups become a part of our family and the loss of one hurts. The shipyard should get your mind off this, Jack.
Ken
Started: MS Bounty Longboat,
Link to comment
Just caught up with this one brother, my condolences on losing your life friend/helper buddy....
Quote:
Link to comment
Thanks Lou, Mark, Edward, Ryland, Ken, EG, for your condolences.
Now that we have been granted a parole (maybe only temporary) from the Covid Prison, I decided to get back outside and join two of my fellow ice boaters at our friend and fellow ice boater, Jim's,  workshop and continue the restoration work on the Manhassett ice yacht.  We were almost ready for varnishing when the lock down occurred so this past Saturday three of us met at Jim's workshop to assess where we were and what needed to be done going forward. We did get a single coat of varnish on the backbone (seen in photo below - sorry for the blurriness, camera didn't focus right).  In the meantime work on the Constellation is suspended for a bit while I get a change of scenery other than my basement workshop.  It would be nice if we can complete the restoration in time to launch the Manhassett on the ice this winter (assuming global climate change allows us to get some ice on the river this year - last time was 2014).
Link to comment
Hi-- I was glad to see this log, but sorry to hear about your pup. That's never easy.
We live about 45 minutes from Baltimore in Frederick MD so I'm planning on visiting the real thing once the COVID thing is over, or at least a lot more under control. You can't currently visit the ship, but they have a virtual tour which I just discovered;
https://historicships.org/virtual-tours
We moved here from the NY Capital District 4 years ago, and the area's nautical history spurred me to ship building. Next on my workbench is the Pride Of Baltimore II
Link to comment
Hi and welcome to the log. Thanks for the condolences.
 I know your area well,  My grandfather lived in Towson, had an uncle in Catonsville and now a daughter in Pasadena.  Got to tour the ship several years ago and took numerous photos.
Link to comment
Just to let everyone know that I have not given up on this kit.
I decided to take a break from model building and finish restoring the Manhassett ice yacht that we have been sporadically working on the past 2 years.
This past Saturday we got a 3rd coat of marine varnish on the backbone, runner plank and main mast. Next weekend we will flip the backbone and coat the underside, the boom, gaff and jib club foot and reinstall all the hardware. We hope by the end of August we can be finished with the restoration and move the boat out of our host's workshop.  Some photos follow
Backbone (aka keel) with basket
IMG_8519.JPG.263ad11fb3dc5d1e136c2d37c8a0c141.JPG.jpg.870a666f3351d556136a4eb44eb2e9ad.jpgIMG_8520.JPG.d0619964590b51b313b664780d704d15.JPG.jpg.a6f427e06c25768714bb301a6657cbdf.jpgIMG_8521.JPG.5b1830471a3a2ef8551027d3c38ce353.JPG.jpg.5c195f30ac3afe77c1ca0ad65f74047c.jpg
Runner plank and main mast
IMG_8517.JPG.6e9556c53609506fa280765d978b4753.JPG.jpg.3e2a53db362aa8807633dd3b2061b506.jpg
At least this gets me outside in the fresh air for awhile instead of cooped up inside in my basement. I will get back to the model soon.
Link to comment
I see you're from Woodstock. Where do you plan on sailing your ice yacht? I lived for many years in the NY Capital District, and I'm familiar with the Hudson. I don't recall it freezing as far south as Woodstock for many years.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
