Battle of Waterloo Attack on La Haye Sainte Farm 1/56 28mm
Evening  all,  right  I spent the whole day painting horse number Two  (yep it takes that long)   this one is a dirty white colour  with very muddy feet.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Thinking about how these figures must  look a bit  repetative   but I can tell you  - so much work goes into each one, firstly by attaching the arms/heads  weapons etc,   then they need a bit of a clean up  to remove the mold seams, then after priming with a flat coat  and drying, they then need all the various shades of paint followed by the re touch ups where my fine brush has strayed.
And dont foreget the size of them  - just 28mm  tall  making a strap  for example  needing the finest brush I own  a minus 10 size  with what looks like just a single hair.
Think its going to take a bout a year to make all the figures........
OC.
Current builds
Completed works.
Link to comment
great job so far OC.........they look very good :)    I'm taking notes on the horses........I have a bunch of them to do at a much larger scale  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you Denis,  I think the  key is adding washes in gentle stages, with white  add light grey washes, then a dirty colour wash that  sets into the shadows, followed with a tiny bit of highlighting  say with  white  dry brushing.
OC.
Current builds
Completed works.
Link to comment
I never liked to paint figures (and horses).
But when I see your figures and horses, they look great 👍  (I should also try this sometime ;))
Beautiful work
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
Beautiful work
Thank you kindly Patrick.
OC.
Current builds
Completed works.
Link to comment
A bit more progress today  following a lot of research and internet reading - then more reading,   to find out what actual sections of what units where involved in the attack on La Haye Sainte.
What I have found out is the main (first) attack on the farm by the French  was by 54 and 55 Ligne (line regimant)  these regimants consisted of  Fusiliers (in Four groups  - 1/2/3 and 4  and  the different ranks within,    then there was the Grenadiers  again falling into different ranks,     also there was the Voltigeurs  again in different ranks of coomand.
Following these  up were the Two squadrons of Cuirassiers 1 and 2 company.
So  here is the second  finished  Cuirassier  -
Current builds
Completed works.
Link to comment
Next we have the 55th Ligne  Fusilier  2 nd company.
OC.
Current builds
Completed works.
Link to comment
A 55th Ligne  Grenadier.
OC.
Current builds
Completed works.
Link to comment
And a group shot  of the Four built/painted so far.
OC.
Current builds
Completed works.
Link to comment
Looks great from here, OC.   I have a feeling a diorama's worth of them is going to be a bunch of work just trying too keep the various units separate.  But then, we're model builders and we like challenges and detail work.
Link to comment
Thanks Mark,   also on the small space I have available  ( I measured the  unit it will sit on in a case)  is  36inches  x  18inches, the farm building  after being cut down will be   25  x  14inches,  but  I will have  both sides seperate  by the building.
So - on the inside of the farm and on its roofs will be the  KGL  units  both Light and Line regimants  with a combination of rifles and muskets,  on the front  eadge (about 4inches  wide)  will be the attacking French  including the Four Cuirassiers, and slightly  to the Right will be a handful of 95th  (Sharpes men)  and further to the Left  inside the Orchard will be some more French troops.
There should just be enough  (with a tight sqeeze)  to fit about 100  figures.
This is the amount of trimming I will need to do  - it wont be too bad as I will leave a false wall at the  back  that would represent the  rear cattle sheds.
OC.
Current builds
Completed works.
Link to comment
This is my ground plan showing the  farm complex in the middle  - the road  in the front and the space I have at each end and in front  for my  figures.
OC,
Current builds
Completed works.
Link to comment
OC, you'll be one busy lad, cranking out the players in this scene. Lots of details loaded into one little corner of the battlefield. Great start! :D
Do you already have the farm structures built? The above pictures look like you do.
Ken
Started: MS Bounty Longboat,
Link to comment
No mate,   I have to see what santa brings  - depends if I have been a good boy,    I am  getting cheap sets  (a few at a time)  of  figures  each week  - its a cheap way of doing it that way, for the price of a  coffee  I can get a  sprue  with a couple of figures.
OC.
Current builds
Completed works.
Link to comment
Smart way to do it mate. Doing it on the installment plan.
Ken
Link to comment
I would never have thought of doing it that way, I probably would have tried to buy all the figures in one go and had the Admiral questioning my spending 🙄😋
Are you scratch building the farm or getting resin components?
The two "Gros Frerès" look amazing OC, I'm already feeling for the KLG infantry.
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Thanks Ken.
OC.
Current builds
Completed works.
Link to comment
A company do an excellent MDF  kit of  the farm  - you put it together and paint it yourself  then add what ever scenary  you want.
OC.
Current builds
Completed works.
Link to comment
Evening all,   more progress  this time  the 55th Ligne  Voltigeurs  (the Third section of the 55th Regimant)
It's painted minus the back pack that I need to work on.
OC.
Current builds
Completed works.
Link to comment
Looks good, you could leave his backpack off as he is Voltigeur, he wouldn't want to be slowed down with gear!!!
This book is worth a read,
I know it's not strictly about Waterloo but follows the 95th through the Peninsula war and Waterloo.
Sorry for the hijack OC😉
Current builds;
Completed:
Link to comment
Thank you for that Edward,   I have to put the  back packs on  as there is a huge cut out  in thier backs  for the packs,    also the backs  of them are flatened for the pack  so it would be a lot of work to rectify.
OC.
Current builds
Completed works.
Link to comment
missed the staet, again, appologies
love the topic
i have loads of warhammer horses, collecting dust somewhere lol
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
love the topic
Welcome Kevin, nice having you along,   takes me back to when I was a kid  with those Airfix  Waterloo sets and  box's  of  terrible soft plastic  1/72 soldiers.
OC.
Current builds
Completed works.
Link to comment
OC.
They were fun though 😁, hours and hours to stand them all up then refight Waterloo,  Salamanca and Talavera.
Current builds;
Completed:
Link to comment
And if you was like me  - covering the whole  living room floor  with them  - ok till mum wants to  go into the kitchen and walks over them😭   "mum  I was winning that battle"......
OC.
Current builds
Completed works.
Link to comment
Thease are the colour plates I have been working off  - they are not mine  but off an excellent artist who designed them  (they are accurate I understand)
OC.
Current builds
Completed works.
Link to comment
Great find, OC. The books I have on Waterloo have a number of paintings done just after the battle and these are in total agreement. Excellent resource for you. 👍
Ken
Link to comment
Thanks Ken.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
