Battle of Waterloo Attack on La Haye Sainte Farm 1/56 28mm
Nice work on that stable floor, mate.👍  Really looks like it should be in one's foyer, instead of the stable. My old barn stalls were mostly bare dirt with straw and other detritus scattered about, needing frequent cleaning. 😉
Ken
Started: MS Bounty Longboat,
Link to comment
Share on other sites
The invention of the "Bobcat" skid steer front end loader was the single greatest tool invention for this old barn cleaner. 😄
Link to comment
Thanks Ken,   me  thinks it will have some more  dirty washes on it.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Some straw clipping strewn about will look good, too. Maybe a bucket of feed or water, too.
Our stable doors were too narrow to run a front end loader into the stall. Best we could do was throw it thru the doorway into the bucket.
Ken
Link to comment
Evening all,   work on the  stables continues  - first thing  I did was  to add a few more dirty washes to the  walk through stones, then I had  some lower paint touch up to do where the base plates met the walls,   next was the roof sections  - these need some adjustment after me adjustment to the one stable (it was shortened)   this will lead to a small amount triming off the one roof.
The roof is dry fitted as I will need to keep it moving to lign both roofs up against each other and also where they meed the farmhouse.
Talking of the farmhouse I decided  to do a dry run to see how they look together  -
OC.
Current builds
Completed works.
Link to comment
4 hours ago, FriedClams said:
The excellent work continues O.C.  Very nice progress!
Gary
Thank you kindly Gary.
OC.
Current builds
Completed works.
Link to comment
The farm will look great, OC. Very nice build. The KGL will keep the grognards at bay.😉
Ken
Link to comment
Thank you kindly Ken,   I am on the look out as I type  for bits and pieces in Fle bay  - like tall  grass/rye  sheets hard to find as they need to be scall  of about  15mm  tall, looking at other stuff I need.
OC.
Current builds
Completed works.
Link to comment
OC.
Hi OC
I expect you already know but there is a guy called Chris Dodson on a miniatures / war gaming forum who builds massive battle dioramas in 28mm I think (currently building Antietam. He has some interesting ideas for ground cover. May be worth a look.
Alan
Link to comment
So your looking at about 3' in scale..... Probably "N" scale wheat or hay.....
Check this out....
https://www.sceneryexpress.com/Grass-Mats/departments/1051/
From that link you get to this....
https://www.sceneryexpress.com/NEW-12MM-MEADOW-GREEN-STATIC-GRASS-40g_14-oz/productinfo/NH07110/
12 mm right in what your looking for and it's colored green or golden, late spring/early summer to late fall harvest time..... close to perfect for June in French fields...
And this, How to build a Grassinator
http://www.pacificcoastairlinerr.com/grassinator/
I hope this helps as I can't find much in the way of tall grass in mats or sheets... Fake Fur is another technique that has gotten good results...
Edited by Egilman
Quote:
Link to comment
14 minutes ago, king derelict said:
Hi OC
Alan
Thanks Alan,  I will check him out.
OC.
Current builds
Completed works.
Link to comment
Check this out....
Thank you brother,   Just opened the link and checking it out  - I think I need an A4 sheet of rye grass  (thats what was being grown on the fields where the battle took place  - accounts said it was over waist hight  so with my figures being 28mm tall I make the rye grass needed to be about  15mm tall.
Its to go on the side  oposite the roadway  where most of the cuirassier charges happened.
OC.
Current builds
Completed works.
Link to comment
2 minutes ago, king derelict said:
He lives in Bennos Figures Forum
Benno's Figures Forum • Antietam 17th September 1862 (bennosfiguresforum.com)
I hope its OK to provide the link
Alan
Can't see it being a problem Alan  - its on topic.
OC.
Current builds
Completed works.
Link to comment
It's not a problem as OC says.  I took a look and just had a "wow" moment.
Link to comment
But your battle took place in June, Rye doesn't harvest until late fall, so a little shorter and green would be the choices upper thigh height about 10 - 12 mm... or that's some awful tall rye...
I'm sure whatever you choose it's going to look spectacular...
PS: I updated that post you quoted with a bit more info and links..
Quote:
Link to comment
OC.
I had a quick look on that site but no good brother - the closest thing that had to rye grasses or weet  was too large, I am after something the right hight and already attached to a sheet/mat   so all I have to do is fit to shape on my board  upto the  farm complex.
Thank you for finding that though.
OC.
Current builds
Completed works.
Link to comment
Thank you for clarifying that Mark, and yes  some of the skill in that site is amazing.
OC.
Current builds
Completed works.
Link to comment
Thank you again  - very much appreciated, I have been finding close - but not quite close enough  - lots of clumps on mats that you take each clump off  and place your self  (that might have to be the route I have to take)  perhaps go with 12mm  that would be the equivelant of Two Feet tall.
OC.
Current builds
Completed works.
Link to comment
Evening all, the roofs  are  adjusted and fitted  and the flashing  was also fitted from paper strips.
OC.
Current builds
Completed works.
Link to comment
I have added a few more things to my shopping list for my build  - ordered them  yesterday from our friend flea bay  -
Trees for the Orchard,
Hedgerow for the kitchen garden side and side of the orchard,
Tall 15mm  grass  (managed to get it in 1:35 scale  to make it taller,
Water gel  for the ducks pond,
And lastly some  paint on dust.
OC.
Current builds
Completed works.
Link to comment
Evening all,  a bit more progress on the stables  starting with one of those OMG:o Moments -  I had painted the roofs yesterday and they had over night to dry,   this evening I set about  putting a wash over the tiles - same as I had done to the farmhouse, so no issues here,   then I decided to run a wash over the stable  walls  - after doing this I managed to knock my jar of  wash all over the table  - it was a case of remove some of the wash on the walls as there was too much  - or clean the table, the table won,   I then knocked over my jar of water on the table that I use to clean my brushes.
By the time I got round to working on the stable walls the wash had dried  - so it was  a case of re working some of the White and try to blend it into where it would meet the  wash/shading from wear and tear  - it was a case of wet and dry brush work - followed by a damp cloth to blend them into to each other.
I have the one wall done  (I think)  the same treatment will be done to the other tomorrow.
Talk about a  palaver.
OC.
Current builds
Completed works.
Link to comment
They look fine my friend, Excellent in fact..... Sometimes accident is a better artist than all the skill in the world...
Sometimes it is best to roll with the flow....
Quote:
Link to comment
Thank you kindly brother,   it will be even more weathered when I get my  dust paint.
OC.
Current builds
Completed works.
Link to comment
The wall looks great!  The weathering is phenomenal!
As Bob Ross says, “There are only happy little accidents.”
Edited by GrandpaPhil
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Thank you kindly Phil  - much appreciated.
OC.
Current builds
Completed works.
Link to comment
Definitely a happy accident, OC. I like the brownish staining. It looks very good for the stable area.
Ken
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
