IJN Yamato by glennard2523 - FINISHED - DeAgostini & Model Space - 1/250 Scale
I have continued on with steady progress. I have assembled 12 small machine guns, which was quite time consuming given how small the parts were and that I also had to manufacture 24 gun barrels, each 5mm long.
I also fitted the bow and stern photo etched plates.
1838374166_0052Bow.thumb.jpg.09e43221e89393e54d6156a30dd31c14.jpg467569284_0053Stern.thumb.jpg.296491ba8c3bd3d6c89df2c823e1ad60.jpg
Following on from that I added the rolling chocks, propellers and rudders to the hull assembly. Again there was quoite a bit of work involved with these tasks.
986770201_0050RollingChocks.thumb.jpg.1a873bf30f989b5bf9da6fd0f1c6fc39.jpg967863995_0055PropandRudder.thumb.jpg.75b8a0e16e4fc7a94a5c36689b425bad.jpg1550568323_0054PropandRudder.thumb.jpg.a1e37aa769d936b8e420449b1b94567d.jpg786153764_0051RollingChocks.thumb.jpg.45441c7d95e4988ca825fa5b21b4f5a4.jpg
Glenn (UK)
Link to comment
Share on other sites
Very cool kit Glenn - looking great!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Today I worked on installing the hanger deck and associated supports. The task turned out to be much simpler than I was expecting.
I printed out a picture of the hanger support arrangement and positioned it under the deck and used that as a guide to add the various hanger deck support pieces.
The hanger deck will require some additional filler / glue as can be seen below.
The hanger deck grills have been dry fitted at this stage as then need to be removed and painted Iron Grey before they are glued in place.
Glenn (UK)
Link to comment
The three main guns require a handrail, but you need to drill a 0.5mm diameter hole approx. 0.5 mm deep to secure the handrail posts. I soon found out that I was unable to drill these holes in the die case metal case. I solved this by adding a 0.5mm thick wooden top. This will not be noticed once the gun as been primed and painted.
I have now completed adding the features to the port side of the hull, namely the load lines, portholes, hanger cranes and exhaust pipes. I opted to use some Amati potholes for the open hatches. I also used 1mm plastic strip for the load lines.
0061.thumb.jpg.677bbf327b366da635ccdd95ca946f94.jpg0062.thumb.jpg.1d28d34b25f8ce90825dfb6a936171fc.jpg0063.thumb.jpg.fefbf252ea83e59800cb26f0a8678805.jpg
Glenn (UK)
Link to comment
I have made more progress, the hull has been painted but I'm leaving the covers on hull for the time being while I add some deck detail.
I have added all the parts to the bow section and I'm currently adding some parts to the stern section.
Pictures of the bow section added.
0065.thumb.jpg.4d2e83e50c6a131041ded4df68252718.jpg0064.thumb.jpg.f64176f8ca60dcd9108ea9c37f38397a.jpg
Glenn (UK)
Link to comment
Today I fitted the turntables and tracks to the stern section. It was a tricky task to straighten the copper wire provided  for the tracks (it was  supplied coiled). I painted the track and turntables metalwork black. I think it looks very nice. I will continue to add the remaining parts to the stern section before I start the deck planking.
I thought this picture would show the actual size of the model.
Glenn (UK)
Link to comment
If you are not satisfied with the coiled brass wire that they gave you, you could use N-Scale tracks (1/160) or perhaps better Z-Scale tracks (1/220) made by Marklin. You can easily remove the rails from the plastic ties or even buy the rails from Micro-Mark which sells them individually. Use code 55 rails or even smaller if you can find them. I believe real rails will look better than round wires.
https://www.micromark.com/N-Scale-Code-55-Flex-Track-Bundle-of-6-Pieces
https://www.ebay.com/itm/Marklin-Z-Mini-Club-Straight-Section-9-Length-8505-LN/174408520737?hash=item289b8ed421:g:m-MAAOSwu0BfRSm2
Yves
Link to comment
I have made a start to the deck planking, this is much more in my comfort zone and this is going to be a quick and easy task.
I started with doing the outline and then I added the central line. I am now filling on the gaps using 100mm and 50mm length planks.
0071.thumb.jpg.066e251008aea863973e577d353a6c7a.jpg0072.thumb.jpg.8ab3ea56fe0ddfddbfb3217e3a6d2e27.jpg
Glenn (UK)
Link to comment
It sure is, but still has many very small parts.
Glenn (UK)
Link to comment
I have completed the planking of the deck and  have coated it with some a flat clear varnish. I might add some weathering details at a later stage.
I have now started to add some of the deck details. I plan to work from bow to stern  when adding the detail.
0073.thumb.jpg.927e2e91a0ac579b6a8a9b965c989883.jpg0074.thumb.jpg.7cbdaf0d72f8cf90440aac2ba3a8545d.jpg
Glenn (UK)
Link to comment
I have now built the 3 main and 2 secondary guns. This completes all the main super structures for the deck. So I thought I would dry fit the items on the deck to get a sense of what the final build will look like. Tomorrow it will be a case of painting the main and secondary gun assemblies and adding the gun deck railings.
0075.thumb.jpg.c4a5126f3ccfa19e13ee6c04ec96673e.jpg0076.thumb.jpg.413965674ec577384872c0636a08a91e.jpg
Glenn (UK)
Link to comment
I have completed all the work on the three main guns and 2 secondary guns. I have completed the manufacture of all the additional ant aircraft guns, some will require painting and then can be fitted to the deck.
I have a few minor items which can now be glued to the superstructure.
After that I have the a couple of antenna's to build and the two aircrafts launch catapults. Finally I will have the deck railings to add and fingers crossed the model will be complete, hopefully by the end of the October.
I have added a couple of pictures of the progress to date, noting than that superstructures and deck items and not secured in place at the moment.
0078.thumb.jpg.f41c15bd9aba0ad32fc377089a937853.jpg0079.thumb.jpg.a0f7b3f3d9705a6653a6ffb7e625b0fe.jpg
Glenn (UK)
Link to comment
1 hour ago, yvesvidal said:
Getting better and better.... Congratulations.
Yves
may I add words of praise. You efforts encourage me to move it up my wish list .
current build- Swan ,scratch
on shelf,Rattlesnake, Alert semi scratch,Le Coureur,, Fubbs scratch
completed: nostrum mare,victory(Corel), san felipe, sovereign of the seas, sicilian  cargo boat ,royal yacht caroline, armed pinnace, charles morgan whaler, galilee boat, wappen von hamburg, la reale (Dusek), amerigo vespucci, oneida (semi scratch) diane, great harry-elizabethan galleon (semi scratch), agammemnon, hanna (scratch).19th cent. shipyard diorama (Constructo), picket boat, victory bow section
Link to comment
I have had a very productive day, adding all the outstanding deck fittings and also adding the final parts to the superstructure, which just needs painting.
The remaining tasks left are
Build the two aircraft
Build the two aircraft launch catapults
Build the main radio mast
Fit all the deck railings.
I have just ordered the Amati Robert E Lee paddle steamer which will be my next build project. After that it will be either Chris Watton' s next model (due later this year) or Amati's Bismark kit, which is due for release in the new year
20201002_184342.thumb.jpg.7566e334a161039275cd40d3049af900.jpg20201002_184259.thumb.jpg.161fa5a8a9619c6c152cfdf1f9e1175e.jpg20201002_184423.thumb.jpg.d274d2933625c12188348df4c5b22365.jpg
Glenn (UK)
Link to comment
I have finally completed my current project which is a 1 / 250 scale model of the IJN Yamato. This is a mix of wooden construction for the hull and die cast metal for the the superstructures, armaments, etc. This is the De Agostini kit.
The die cast parts were not the best quality and I did spend quite a bit of time rectifying manufacturing defects which was quite a chore at times. The build instructions were very basic and the supporting build photos did not really help. That said I am happy with the end result.
0080.thumb.jpg.01dde8b37f426b30bba6ee85bfff504c.jpg0081.thumb.jpg.aff87d6dadd76c6ff18160123fdd1148.jpg0082.thumb.jpg.fe3f4764cb416f3f2cc96516e2f28212.jpg0083.thumb.jpg.6172c7c612d87cfbbae59a57bec92dbc.jpg0084.thumb.jpg.60010668f7b89cdc9c9137e8b44842cc.jpg0085.thumb.jpg.1aac76678aed3edc00fa7fa36c6d2711.jpg
My next project will be a Mississippi Steamboat, the Robert E Lee. I will start a build log once in the next day or two.
Glenn (UK)
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
