Model Airways Sopwith Build Log
I am building the Model Airways 1/16th Sopwith Camel. So far I have built the engine and shaped and installed the Propeller. I did a "black wash" of the cast metal pieces after the completion prior to installing the prop. I did shape the Prop by only sanding with a palm sander. Whittling was not necessary.
Link to comment
Share on other sites
30 minutes ago, rayschilke@comcast.net said:
The wings are next and look to pose a challenge due to being time consuming.
Pullin up a chair here.....
Nice work Ray.... Engine/prop looks like the real deal.... will be following the rest of the build....
EG
Quote:
Link to comment
Prop looks nice, Ray. I'll tag along, too.
Ken
Started: MS Bounty Longboat,
Link to comment
12 minutes ago, rayschilke@comcast.net said:
Wing spars are gonna be a slow go.
Not slow brother, tedious is the word, we understand.....  multiple repetitive tasks..... Been there, done that, used to doing that...... {chuckle} Take your time my friend we will still be here...
Quote:
Link to comment
Take your time. This is a hobby, not work. :D
Ken
Link to comment
I’m pulling up a chair too. I’ve had this kit in my stash for a few years now - one day.....
You’ve made a nice start Ray.
Link to comment
Switched up to a ceiling tile for a background for pins. Much better than wood. Spars are coming along. It is nice to have this hobby as a back up for cloudy days when I can't do star photography. Spar progress is going nice but it does get hindered by an occasional beer break. I have begun to use kids stick glue to just hold the spars to the plans to just to hold their place on the plans. It is nice because they just pop right off when it will be time to put in the wing spars and metal parts.
Link to comment
I am enjoying your build log.  That was a good tip on using a glue stick to hold your parts.  Astrophotography must be an amazing hobby.  You must have quite a setup to see deep into outer space.
Ryland
               - Nautical Research Guild
Link to comment
Superb Asto work,   I too used to have a dabble  at DSO  objects  managed a few years back to get these Two  -  Seven Sisters  and  Jupiter and moons.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Thanks sir. I have a bit of change into my telescope gear. I have a wife that forgives my hobby costs because I ignore her sewing costs lol
Link to comment
Greats shots. Thanks for the compliment. It is a hobby that really is all about what equipment you have. Tough to learn everything as every aspect from tracking, capture, and processing seems like it's own college course. Keeps the brain young though. This plane is about to be a challenge with cable rigging. No do overs like throwing out a bad picture file. But I do have another sopwith build log in this group to reference. It is a good source for me and a blessing to have😀
Link to comment
Its great having you showing us all your work Ray, please continue to its an inspiration  and a pleasure to watch.
OC.
Current builds
Completed works.
Link to comment
I just took a seat for this build. Great astrophotography too!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
Getting ready to insert the spars and wing leading edges and wasn't happy with my ceiling tile as a pin base. I repurposed 2 of my wife's cloth fabric bolt cardboard inserts. They are a perfect length and accept pins readily and hold tight. Also used green painters tape to hold the plans to them as the green tape holds but comes off the plans without ripping them. Wax paper laid out and ready to put ribs on and do 400 grit final sanding of each part. At least I am done with almost all of the wing ribs. They were tedious.
Link to comment
looks good :)   when I build balsa planes,   I use a pine board to pin the plans to.   it's pretty soft wood and I cover it with clear plastic wrap to protect the plans.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
