HMS EURYALUS by cfn1803 - 36 guns (1803) - 1:48 scale
I started this build in early March of 2012, and like most model shipwrights here, my build log was sacrificed to the computer gods.  I do not have a copy of all the associated posts of the old log, but I do have photos.  I am using the book and plans from Swan Books' Frigates of the Royal Navy series: HMS Euryalus (36) 1803 by Allan Yedlinsky with the plans by Wayne Kempson, and my wood is from Jeff Hayes at the Hobby Mill.  Below is my first and last picture from my old log.  More to follow.
Regards,
Clay
Edited by cfn1803
Current build:  HMS EURYALUS (36) 1803  1: 48 scale
Link to comment
Share on other sites
Link to comment
Great to see that you are back up and running Clay.
Michael
Link to comment
Clay,
Good to see you returned from the den of the computer gods. :D   I'm looking forward to seeing some more of your excellent build.
 La Belle Poule 1765 - French Frigate from ANCRE plans                             Triton Cross-Section
        USS Constellaton (kit bashed to 1854 Sloop of War  _(Gallery) Build Log
        Wasa (Gallery)
        HMS Sphinx 1775 - Vanguard Models - 1:64
Link to comment
Thanks Mark and Rob,
Here is a bit of a look back/review of my build.  As I mentioned before, I am building a fully framed model per Allan and Wayne's Euryalus book and plans.  I also obtained copies of the original builder's draughts from the NMM.  Additional references that I have relied upon during my build are the Fully Framed Model, HMN Swan Class Sloops 1767-1780 series by David Antscherl and Greg Herbert and Ed Tosti's book The Naiad Frigate (38) 1797, all from Swan Books.  These books along with the many excellent build logs of MSW have helped me take on this project.
The model is constructed in the up right manner, with out any building stages or hull fixtures.  The Hull framing and structural components are Swiss Pear wood, milled to the proper sided dimensions by Jeff Hayes at The Hobby Mill.  Templates are copied/printed from the plans provided in the book and are pasted to the sided stock with an elmer's glue stick (easily applied, easy to clean off after the "saw pit" sessions).
Link to comment
After carefully insuring the proper assembly of the stem and knee of the head as well as the after deadwood and stern post against the plan, I endeavored to build and assemble the hawse pieces....
My building board was a 3/4 inch thick particle board sealed and painted white, on which was glued the hull framing guide.  The board was then screwed into my work bench to keep it structurally ridged.
Edited by cfn1803
Link to comment
As I assemble and "hang" the frames, I fair the inside framing as I go.  I am saving the fairing of the outside of the hull until after I finish the framing of the hull.  I am also gluing in the filling pieces between the frames as I go.
It is very important to securely bolt the keel down to the building board to minimize the warping of the keel as the drying of the glue may cause the stern and bow sections to bow up from the board.
Link to comment
Thanks Ron!
Here are a couple of shots of the builders draughts from the NMM.  As you can see they are now reproduced in color and can provide some interesting insight into some of the differences between the various ships of the Apollo/Euryalus class of the 36 gun frigate.  Various modifications were added using different color inks coded to different ships of the class (difficult to see here).  This is why it is always a good idea to include the actual draughts in your research.
Link to comment
Welcome back! I was following your build on the old site but have not had time lately to peruse the new site but will put your build on my watch list. I would love to build this ship and I do have the book now so I can follow you page for page!
Good Job!
Guy
The Learner
Cheers, Guy
The Learner
Current Member NRG,SMA
Current Build: HMS Triton 1:48 on line
Link to comment
Thank you gentlemen.
Greg, I am leaving the top timbers a bit long so I can cut the ports and the sheer in a "seaman like manner".
Regards,
Clay
Link to comment
Clay,
Further to your note on having a copy of the original drafts there are often quite a few notes and sketches with references, dates, etc. as you have no doubt found.  Wayne incorporated them as much as possible on the Euryalus drawings.  One of the copies of the orginal drawings that we had, a cross section, shows changes made to some of the later vessels in the class and signed by Seppings.   With NMM now electronically sending, the colors do indeed give further information and make it easier to interpret some of the lines.   Wish they did not charge an arm and a leg for such a scan and send.  I would have thought it would be less expensive than the paper copies but I guess not.
Your build is looking really great and a joy to follow.
Allan
Current Builds - HMS Litchfield 1695 - Scratch 1:64 HMS Boston 1762 -Scratch 1:196
Link to comment
  • 3 months later...
Nice work.  This or the Naiad is a future project goal of mine.  Your log will be great reference.
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
  • 6 months later...
  • 2 months later...
Clay, thanks for doing such a nice job logging you build. I am starting a steel navy project, the C class cruiser HMS Caroline. I would love to get info from NMM. How difficult was the process In obtain them? Thanks Randy
Link to comment
Regards,
Clay
Hi Clay. Do the plans tell you how much timber stock and sizes you need?
Gary.
Past build: Hms Arethusa. Leander class frigate 1965
Current build: Revell 1/72 HMCS Snowberry radio conversion.
Planned build(s):
Dusek Viking Knarr 1/72
HMS York D98 scratch build 1/72
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
