Frigate Diana by ObviousNewbie - FINISHED - OcCre - Scale 1:82 - Second wooden ship build
Loverly looking Frigate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Hi all, thnx for checking in. It's been a while, but I've been busy:
First the catheads: Occre's instructions show the catheads at a very shallow angle, but the plans mark a 45° angle from the heartline. This seemed to make more sense so I went with that. The instructions also showed how to construct off-boat, and then magically fit it into place. Didn't trust that too much, so went for a different approach:
Marked the angles on tape using the middle of the openings as a reference:
Then constructed the catheads off boat, making sure they fit properly, and marking the crossbeam:IMG_7779.thumb.JPG.b91acb9578fb1d440dbd8283eae054e0.JPG
After some fiddling, found the correct angles:
Next up, the limber boards, including the ornamental ends (a first for me):
Some sanding and filling later:
Also decided to add a small 2x2mm strip to the base of the bulwarks, which wasn't included in the kit. Seemed a bit unfinished like that (Terror had this), so added them:
Drilled a 6mm hole in the stern for the rudder, always a pleasure taking a power drill to your hull.. NOT 🙂
Marked the hole, and then taped the circumference in the correct position, cutting the sapelli strips first before drilling a pilot hole, and then working my way up to 6mm.
After a first coat of varnish on the limber boards, this is what she looks like today:
Next up: placing the mirror (and bending it, oh joy), and then the bow details (also a first).
Interesting times ahead 🙂
Stay safe!
"Whatever does not kill you, only makes you stranger."
Current build:
Finished builds:Calella by Occre - Greek Bireme by Amati HMS Terror by Occre - Frigate Diana by Occre
Link to comment
You are a brave man ;)
Great work
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
Hi all, thnx for checking in. Got the mirror in place after a bit of a struggle. Suffice it to say I have one nail hole to hide 🙂
Started on the bow ornaments, but after the first pieces I realised I was going to make my life very difficult painting the rubbing strakes after this section was finished. Soooo, put the ornaments aside and started painting. For one reason or another, the black varnish I used on Terror did not really like the African walnut; after two layers hardly anything took. So sanded down the layers and put on some matte black acrylic paint:
Quite happy with the result actually 🙂
Onwards now to the rest of the bow ornaments, then a double layer of matte varnish (decided I like the color scheme so I won't be using any dye on the lower hull). and then on to the deck fittings..
Current build:
Link to comment
Hi all, thnx for checking in. Small update and a question (see below).
Finalised the bow ornaments today, that only took me about a week 🙂 Started with the top sweeps:
I kept the bowsprit dry fitted as long as I could, to make sure the alignment would not go off.
Dropped the lower sweeps, but I made a mistake I only saw later, as the bend was too far away so the lines mess up a bit. Decided to continue regardless.
Then the final details:
Hull is almost finished now, just attaching the rudder.
Question: I'm about to start on the side windows (sorry, correct term escapes me), and Occre provide these as metal pieces. Gave them a double Tamiya Metal Primer treatment, but which paint to use? The store I shop with tells me not to use acrylics on metal, even when primered, only use enamels. But checking other stores for Caldercraft paint, they only exist as acrylics.. Any suggestions/experiences?
Thnx for your feedback 🙂
Current build:
Link to comment
1/72 scale Panzers in white metal  from MMS models. painted more then 25 years ago  with  Tamiya  acrylic paint.
Looks ok to me
Regards, Patrick
Link to comment
whoooow such beatiful hull, well done! your model appears awesome! 🤩
the second layer planking is simply perfect!!
well done Obvious,
Link to comment
Hi all, thnx for checking in. It's been a frustrating week at the shipyard, as the dyes and paints I ordered from Cornwall are still on their way 😞 . The Belgian Postal Service (often compared favourably to a carrier pigeon with no sense of direction), is apparently still trying to determine what to do with such a bulky volume (4 dye bottles and 3 little paint cans).
Thing is, I need the dye for the rudder, the paint for the quarter galleries. Only then can I varnish the hull, and only then can I install the deck fittings (as I don't want to turn the hull upside down for varnishing with the fittings installed).
Decided to already start on the fittings off boat and install them later. So on with the pin racks:
Then my first try at a railing:
Went for the rudder as well. Occre provides metal rudder supports which are not the best looking, so decided to make my own:
And dry fitted on the deck:
Is this how it starts? First you remake individual parts and finally you end up building a ManO'War from surplus wood and a vague plan? 🙂
Stay safe!
Current build:
Link to comment
Yep 😅
Regards, Patrick
Link to comment
Very nice work for sure!
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Link to comment
Hi all, quick update: frustration continues 😞
The shipment from the UK finally arrived, so dyed the rudder and attached it. Found a new way to handle the rivets, and the nightmare I had with riveting Terror's rudder was no more (hint: better tooling, aka fine tweezers).
Started working on the quarter galleries over a week ago, and still in prep phase. The pieces just don't line up as described in the plans or the pictures.
Normally the bottom metal piece should align with the top of the rubbing strake, but that doesn't work. Checked the other build logs, and indeed this seems to be an issue as some other modellers built it as shown in the previous picture.
Also, I'm sure I'm doing something wrong with the metal itself, after two coats of metal primer, neither enamel or acrylic paint stuck. Eventually got so desperate I started using poster paint to get some results, but that just looked horrific.
Called a good friend who specialises in car modelling, got some advice on Vallejo paints and primers. Managed to get my hands on some primer, gold and blue. Then scrubbed ALL the players of paint off and started anew, this tim with some better results:
But then, as I put the two pieces next to each other:
IMG_7952.thumb.JPG.53e8e4f0f37eae54b16bb7b8f5f1a6a3.JPGIMG_7953.thumb.JPG.76edeaf09114b0914c890dd501a76eb1.JPG
Correct me if I'm wrong, but these pieces should be the same size, no? And of course I only saw this after painting... (Left piece only has one layer of gold paint, right one has two).
Central pin rack was also a challenge, as it's semi circular and pre shaped on a thin piece of plywood, which of course split and cracked a soon as I put my drill to it. Second lesson: next time, get belaying pins that are the correct size, not the ones provided.
Got all my courage and my spare wood together, and tried to construct it myself. Here's my version and the official one:
Sorry for the rant, I've been staring at these quarter galleries too long. All deck fittings are finalised, so as soon as the galleries go on and hull varnishing is done, I've got a lot of installation to do. Meanwhile though... Not sure anymore how to handle the galleries, I seriously underestimated the complexity of them.
Any tips would be welcome, thnx!
Current build:
Link to comment
Hi all, thnx for checking in. another milestone passed earlier this week, although not quite how i imagined it: finalised and varnished the hull:
If you read my previous entry, I bit the bullet and went for the install of the quarter galleries as is. I got some sound advice from Keith, studied it, but frankly I didn't have enough confidence in my abilities to pursue a scratch build of this magnitude. Hope you don't take offence, Keith, I value your input and respect your work tremendously, I just didn't feel up to it.
A closer look, with some painting details still to be optimised:
Bought the Admiral some flowers, so I had some clear plastic to use as glass for the windows 🙂  Didn't paint the inside, but put a piece of an old floppy disc behind the plastic.
On to the deck fittings, still a work in progress:
You'll notice the blue tape over the mast holes, which were put there AFTER I lost one of the structures behind the rudder... Another scratchbuild then on starboard side.
As all the deck fittings have been assembled off boat, took some time to look at the next step, and a first time for me: the guns. Mastini's book has some very valuable info on this, but what surprised me most was the different approach in Occre's plans: the smaller guns on the top deck have a breeching rope, while the heavier guns on the lower deck do not.  In fact, according to the plan, they don't have any ropes attached at all! Must make for some interesting sailing in rough seas 🙂
I'm not knowledgeable enough to go for historic accuracy, but I decided that the heavy guns needed a breeching rope as well. Going full option with side and train tackles seemed undoable in the lower recesses of the deck, but something I'd like to try in the future.
Still, that left me with the question on how to attach the breeching ropes to the lower bulwarks, as I can't reach with my drill. Decided to add 2 small blocks to the eyebolts and glue these in place, I can just about reach with my long tweezers:
Blocks in the picture above still need to be painted in the same colour as the bulwarks, but you get the idea. Got the info from other topics here the breeching rope should be 3 times the length of the barrel, hope that's correct...
Also, is anyone using this particular product for blackening eyebolts and such:
Does this type of product also exist for blackening white metal?  Occre provides cleats in this metal and they obviously don't respond to this liquid.
As always, thnx for the help and the feedback. Stay safe!
Current build:
Link to comment
Happy New Year everyone! Wishing you all good health and happy modelling, preferably without being confined to your home...
Big update as I had two weeks off, filled with setting up the house for Christmas and continuing on Di.
First, the gunport went up. Decided to keep the copper look that's out of the box, mainly because I like it (same for the cannons, which are a weathered brass colour). Some fine filing needed to be done, and I had to discover the best way of glueing them
After that, deck ornaments, filed while waiting for the different layers of paint on the quarter galleries dried (see previous post):
Installing the channels then. As this was my first experience with this type, reinforced them with 1mm brass wire which fit into the hull (more drilling in the hull, yay..)
Then the guns, something completely new. measured up the correct place to drill the hoes for the side cannons and installed them:
Then the tricky bit, installing the guns on the gun deck. Happy to say my little trick worked:
After that, the top deck guns were placed, and I'm currently working on finalising the gun deck:
A lot of work, lots of new experiences, but she's starting to look the part:
Take care and stay safe!
Current build:
Link to comment
Hi all, quick update: finished the gun deck:
Added railings, supports, etc. Top tip: do NOT install the outer railings before finishing off all other work on the hull. Wen the ornaments and guns are installed, this is almost the only way to safely hold on to her.
Started on the deadeyes next, got myself a 1m dowel to make sure I'd get the angles for the stays correct:
On second thought, I might have overdone this a bit 🙂 But the result looks good:
Next up, access ladders and the mirror..
Current build:
Link to comment
Hi all, thnx for checking in. It's been a while, lots of (remote) working and trainings, house DIY, but we managed to progress a bit.
Access steps were relatively easy, used an inordinate amount of tape to ensure alignment:IMG_8075.thumb.jpeg.2847ad8fedde8d8c62f899e0ec05ec56.jpeg
After that, work on the mirror started, a first for me, as Terror was nowhere near as ornate as Di's. Ended up taking a bit of creative license and continuing the gold/blue pattern on the galleries:
Added a small strip on top of the windows to line them up more nicely. I realise this is not according to plan, but looks wise I think it works. Detailed painting took me the better part of weeks though, with virtual prototypes being made and edited in Photoshop.
After that, I had a look at the lifeboats. The ones provided by Occre are metal, with not a lot of detail. Found an alternative in the shop, here's the two versions side by side:
Still not sure about which one to use, although I like the detailing of the new version.
After that, the bowsprit was finished:
Had to get back into the whole rigging groove 🙂
After that, the foremast was up. For the platform (also a first), the plans were extended a bit so I could get the angles correct:
And the result:
After the varnish dried, dry fitted the mast elements together, and this is what she looks like today:
Work is going slower, but I find myself trying and experimenting more, and learning a lot along the way. Mastini's book, always helpful, had a very good technique to make the wooldings, something I wanted to improve upon after Terror.
Stay safe!
Current build:
Link to comment
Hi all, apologies for the delay in updating, but a couple of days after posting the last update, I was taken to hospital with a critical pancreas condition. It took me a while to fully recuperate, but last weekend was the first time I could sit up and stay focussed enough to pick up the work on Diana.
Nothing too much though, working on the yardarms of the foremast:
Hopefully my condition will improve so I can get more work done, for now it's still a bit of an exercise...
Stay healthy and safe.
Current build:
Link to comment
glad to see you back with your very nice build
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Nice work, and get well soon
Regards, Patrick
Link to comment
Hi all, many thanks for your kind words. Fully recovered now, so I was able to continue to work on Di, job permitting. Small update and a question:
Finished the yardarms for the foremast. A lot of new things learned here, and again, patience is a big asset when you're building. But then again, the focus on a block positioning can be quite soothing 🙂
Finished the main mast as well:
Question: what is the best way to connect the yardarms to the masts? I've been fiddling with this on Terror, with varying results, but I'd like to improve on this, so I 'd be happy to learn how you tackle this job. Been experimenting with clove hitches, but that doesn't seem to work (or I'm doing it wrong).
As always, thnx for the help!
Stay safe!
Current build:
Link to comment
2 hours ago, ObviousNewbie said:
clove hitches
Nice work,
But i dont think that clove hitches are the right way.
And how it should be done correctly, i still have to figure that out myself 😳
Regards, Patrick
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
