USF Confederacy by cdrusn89 - FINISHED - Model Shipways - 1/64
With the sample ribs waiting for glue to dry I decided to simulate the scarf joints in the keel per the instructions. My first issue is that I normally only have Bondo filler because it is much finer than the "regular" wood fillers. The bad news is that it comes only in black or red so it will not work for areas which will be stained/varnished. So another trip to Lowe's and I got two shades of Minwax wood putty. I think the natural pine is what I will use on the keel since it will has the natural basswood color (no stain).
Here is what I got
With the putty issue resolved I decided to build a jig to get the same pattern at all four locations. I assumed that the iron bolts extended all the way through the keel so there would be heads covered with plugs on both sides - two joints thus four sets of bolt heads.
The jig is a simple piece of 1/4" X 1/16 brass plate with the eight holes (two rows of four) drilled out with the instructions suggested #70 drill bit.
Here is the jig clamped to the keel ready to drill the holes.
IMG_0502.thumb.jpeg.4c481c42973d308bf978296f5d717669.jpegIMG_0503.thumb.jpeg.51afe04a8f990d2a5c642b19750f717e.jpeg
I cleaned out the holes with a sharp pick, sanded and applied the wood putty.
Yea, it is hard to see but trust me the holes are there.
After the putty dried I sanded the area first with 220 grit then 400. And this is what the first one looks like before the WoP. Yea I know itb is upside down - the MSW site did that - my photo is right side up???
It clearly needs a wipe down with paint thinner but I will wait and do the entire keel in one pass.
Only three more to do.
Edited by cdrusn89
Thanks,
Gary
Current Build -  HMS Sphinx 1775
Prior Builds:  HMS Winchelsea
                       USF Confederacy
Link to comment
Share on other sites
Bossman - thanks, I have a ways to go to catch up with you, in progress and quality.
I got the shadow box of ribs faired and then a coat of WoP on. I have noit decided yet whether or not to cover the ribs but now I can plank over them if I wish. As installed they are quite "proud of the surface. I had to resort to 80 grit sandpaper to take it down in a reasonable time frame. Two of the ribs came "unstuck" during the process and I used medium CA to get them back min place - previously I had used Weldbond. Here is the area after fairing and one coat of WoP.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
After looking at the areas of the lower decks to be planked and reading the instructions that there are ~ 23 planks for each platform I decided to resurrect a technique I used on my Niagara (although on her I used it for the bulwark planking) of using a 1/64" thick plywood carrier sheet to hold the planking. This will allow me to plank at least the two bulkhead span off the model and then glue the entire sheet into the hull. I cut the plywood and test fit it to make sure I could get it into the desired location without bending, as bending will be  very difficult with the planking glued down.
Here is the carrier sheet during the test fit in the hull.
You may note that rather than having the bulwark extension protectors held in by friction per the instructions I pinned them as during the fairing (when you really need them) they kept falling off.
I was not terribly careful cutting the planks for the deck carrier. I will use the disk sander to trim the ragged ends and adjust the overall length and width to make it fit.
Here is the planked deck carrier after a coat of WoP.
Here it is after trimming and  installation in the hull.
While I am gluing up the other two lower decks I decided to start looking at the stern framing. In preparation for that I used the laser level to make sure I had the hull squarely on the building board and standing as close to vertical as I can measure.
After some minor adjustment I got the laser in the center of the hull former at the after end and I have the hull aligned on the laser center since I have the vertical light on the center of the forward most bulkheads- or as close as I can measure.
I hope to use the laser to help me get the stern timbers aligned correctly but I am not optimistic that it will be much help since it is hard to not get in the way of the beam while messing with the stern timbers. I am planning on reviewing several of the Confederacy build logs to see if there were any "tricks" employed by previous builders.
Thanks,
Gary
                       USF Confederacy
Link to comment
Gary, I don’t remember employing any special tricks on the stern timbers. I do remember measuring and eyeballing a lot! I used a string line. I do remember I attached the 2 middle frames first. Then made a spacer to put in between them. Once these were solid I proceeded with the rest using the template as described in the directions. Hopes this helps. Looking good!
Current build: Model Shipways “Confederacy “
Completed builds:
Mamoli “Royal Louis“
Mantua “Royal Caroline”
Scratch 1/4 scale gondola “Philadelphia”
Scratch “Hannah” from Hahn plans.
Link to comment
Bossman,
    Thanks, I had not thought of the spacer. I assume you built the spacer to keep the 2 middle frames the correct distance apart - correct? You used the string line to get the tops of the timbers where they needed to be?
     I was thinking of building some kind of framework to span across the stern high enough to accommodate the inner (tallest) timbers and then moving it down and forward  to accommodate the next two, etc. I have looked at the drawings and it is not obvious that there is an acceptable drawing which shows the stern timber location in all three dimensions. The port/stbd and vertical is shown in the template but I can't seem to find something that shows the fore/aft locations. The best I can come up with is Plate 2 of the Harold Hahn plans which show the stern timbers. It would allow you to measure how far back the tops of the timbers are but you would have to measure from some common point (base of stern post perhaps and allow for the fact that the stern post is not yet on the model hull).
     I have the T-track along the sides of the build board so moving the framework should be easy enough. I just need to know where to put it along the track and how high so I can clamp the timber tops to the framework while the glue dries.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
Gary, that is correct. It’s coming back to me now. My center line was marked on the top of the spacer between the two frames. This is what I measured from. Using the template and measuring also was how I placed them. They cane out real close as I had no issues with the windows.
Completed builds:
Link to comment
Thanks Bossman.
So I decided to start the stern timbers with the inner (CC) set since it appears from all the drawings that they are truly vertical with the bulkhead former.
Here is how I did it in case this could be useful to a future Confederacy builder.
I built a new jig for the T-track that was wide enough to span the entire stern timber - from Bulkhead 8B to the farthest extent of the stern timbers
Then I measured the provided lintels (S53 and L53) which both measure .50 inches confirming my belief that the "CC" timbers are vertical. I used the thickness sander to create a spacer .50" wide to fit between the two "CC" stern timbers.
IMG_0523.thumb.jpeg.57fa313091e7ebc3768318c07074421a.jpegIMG_0522.thumb.jpeg.6021dec47157c2ca0f14412a7d6a89f0.jpeg
Next I needed to mark the jig with where the top of the "CC" timbers should be so I laid the jig on the drawing and marked the top of the "CC" stern timbers.
I secured the jig in the T-Track, inserted the stbd "CC" stern timber in the slot in bulkhead 8B and adjusted the tilt so the top met the mark on the jig.
I checked everything again and then took it apart, added glue and reassembled.
When the glue was dry I moved the jig to the port side and repeated the process and included my spacer between the two "CC" stern timbers.
I used a square to make sure the tops of the two "CC" timbers were aligned (not really trusting that the two T-tracks are exactly on the same level) then glued everything up and waiting overnight to make sure the glue was truly set.
Now for the somewhat more difficult BB and AA timbers which are NOT truly vertical. By my measurement the BB timbers are 15mm apart from the CC at the bottom and 10mm at the top. I better get busy making at least two spacers, maybe three (10, 12.5 and 15mm).
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
After some careful thought and a long look at the stern with the two stern timbers installed, I decided that doing things with spacers was probably not going to work - trying to replicate something in three dimensions when all you have to go is a 2-D representation is asking for problems. Per the instructions the provided template is what matters (well actually the supplied window frames but...) so I decided to install the other four stern timbers as close as possible to what is shown in the template.
With that in mind I clamped the template to the two existing stern timbers and using a series of pointed shims got the other stern timbers lined up with the template (more or less - there is only so much you can do about where the outboard end is in the port/stbd direction). When I got one as close as I could to matching the template I used thin CA to fix the timber in place.
So here are all six timbers as they fall on the template.
Now the trick is to use the other pieces of the stern (especially the sills and lintels) to line up with the template.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
Stern timbers and associated pieces are complete - on to the sills and lintels.
You have to be very careful doing the fairing. in fact I probably would recommend waiting to do the fairing until the sills and lintels are in place. Without them it would be more than easy to break sometime while fairing.
Here s what my stern looks like now.
Thanks,
Gary
                       USF Confederacy
Link to comment
With the stern timbers and other pieces secure I taped the template to the stern as directed in the instructions.
I broke out the laser level to make sure I had the template on straight.
Sorry - I did not notice to poor focus until I was writing up this entry - too late to do over. I think I got it on straight.
With the template in place I started adding the lintels. One of the problems I encountered was trying to hold the lintel in place while simultaneously adjusting the position. I could not use a clamp (after L3) because I do not have any that are sufficiently weak to not distort the stern timbers beyond their template position. So I resorted to that old standby - masking tape.
Here I have L1, L2 and L3 in position. I used the laser level to help get them straight (aka - not tilted higher/lower at the fore and aft ends of the lintel).
I lined the lintels up with the marks I made on the stern timbers (per instructions) and the laser shows that L1 is just a little bit lower than L2. I cannot see any difference between L2 and L3 but it is hard (for me) to see any difference on the template either.
After I got the lintels installed (more or correctly I hope) I moved on to the sills. For these I cut a new template (I scanned the one from the instructions in and printed several making sure to set the scaling to 100%) along the top of the sills and mounted that on the stern using some clamps to hold it up to the lintels and with the stern timbers correctly located. This was pretty easy as everything is held pretty much in place by the glued in lintels.
I added the sills one at a time starting at the outside. here you see S1 and S4 and S5 in place.
The other clamps are holding the stern filler pieces in place while the glue dries.
Here is a shot with all ten lintel/sills in place.
The clamp is holding the S3 in place while the glue dries. The shape eyed should notice that I had to add a spacer to the stbd side of S3. Hopefully this is tolerance build-up. The spacer is less than a 1/32" wide. and the stern timbers seem to be in the right places. Maybe I was overly aggressive taking the laser char off (LOL).
I will fair this area tomorrow after I am sure the glue is set.
Thanks,
Gary
                       USF Confederacy
Link to comment
I struggled with the ports on the transom.
First I cut a section out of the template and attempted to mark the stern timbers with that - before I reread the instructions which mentions the laser etched marks on the stern timbers. If I had proceeded I would have had ports considerably further up than transom and slanted somewhat. Another example of using a 2-D representation on a 3-D surface (IMHO).
Here is what the template looked like on the hull.
Once I located the marks on the timbers it was pretty straightforward to get the sills (at top of picture as the hull is now upside down on the build board).
I purposely kept the sills proud of the stern timbers to make fairing a little easier. Only sand until I start to take wood off the stern timbers.
The multi-colored marks are from my "other" attempts at locating the sills.
Now on to the lintels and the port sides. Much fun.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
I completed and faired the four ports on the transom without further drama. I used thin CA to secure the lintels, sills and sides as an expedient since getting clamps in place was going to be a challenge and these are not really structural - all this will be hidden behind planks and closed port doors. I also faired the stern quarter fillers per the instructions. Probably more work here as we get closer to planking the area.
I had rubber cemented a copy of the stern drawing to a file folder and cut out the windows (which I saved for later use). Here is the stern template clamped onto the completed stern framing.
IMG_0570.thumb.jpeg.c8e50bd0fe34a7d0c878d5bec883d1e2.jpegIMG_0571.thumb.jpeg.5690b1938f8be8e783a27d45a77b8d7a.jpegIMG_0572.thumb.jpeg.3008224ededc8c53d8bfd227b0477d16.jpeg
Thanks,
Gary
                       USF Confederacy
Link to comment
Since I had the balsa on hand I decided to use that to fashion the filler pieces at the stern post.
It took more work than I anticipated but I managed to get both done before the football games on Sunday.
Next up is the false decking which will be "after football".
Here are the stern fillers in place. I suspect that some more "fiddling" will be required once I get down to actually planking this area.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
I followed the directions and installed the false deck. I did the stbd side first (instructions say to start on the port side - reason not specified). No significant difficulties (at least that have reared their ugly heads so far).
I had to take all the bulkhead extension "protectors" off to get the false deck installed as it took several attempts at adjusting the false deck notches to get a satisfactory fit along the center where the mast and hatch cut-outs need to match.
Here are two shots of the hull with the false deck installed (before I returned the extension protectors to their positions).
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
The next step per the instructions is to add the planking to the beakhead deck and bulkheads.
In preparation for this step I build a test strip for the various woods that I can choose from for the deck and bulkheads. I used Alaskan yellow cedar (with caulk simulation) for the lower decks so that is one of the options. The others are the kit supplied basswood, boxwood which I have from some previous model and poplar which came with the timbering kit from The Lumberyard.
I put a four plank wide same of each on a simulation of the bulkhead spacing and then drilled #75 holes for the simulated treenails.  I made two sets of
holes and filled one set with Minwax Natural Pine wood putty and the other set with Minwax Golden Oak putty. After drying I sanded each set with 220 grit paper and applied two coats of Wipe-on-Poly to see how the various woods and putty would look.
Here is what they look like - the Golden Oak putty is on the right.
At least for the beakhead I will use the cedar and Natural Pine putty for the deck and for the bulkheads the boxwood and Natural Pine putty. At least for these woods the Golden Oak is too dark. Maybe on the hull where I am going to use Swiss Pear the Golden Oak will look better but that is another test strip coming up.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
Gary, your use of mock-ups and comparisons like the one above is really educational for the rest of us. Your results show what prior planning and thought can accomplish. Keep up the good work!
Tim
Current build: Continental Navy Frigate ALFRED (build log)
Past builds:     Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
Link to comment
Thanks for the kind words Tim.
Sometimes I believe I tend to "Overthink" things.
Thanks,
Gary
                       USF Confederacy
Link to comment
I have completed the beakhead deck and treenails but have not yet added any WoP. 174599548_IMG_05822.thumb.jpeg.d0ff7349fe77869060b88383985d1137.jpeg
Sorry about the shadow I can't seem to find the correct place to put the lights.
And I have planked the beakhead bulkhead (boxwood) on both sides but have yet to add the treenails. i will probably only add the treenails on the outside. The inner bulkhead will be hard to see with the bulkwarks and at least half the forecastle deck planked. Not sure it is worth the effort and it will be considerably harder to drill the holes with the bulkhead extensions "running interference".
After looking at this picture I can see a few places where some additional trimming is required. I thought I had all that done. Maybe it is time to dry fit a door or two to make sure they will fit. Easier to modify the openings now before the treenails and WoP.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
While the filler is drying in the treenails on the beakhead bulkhead I ran the batten for the gunport sills on the port side.
After making some minor adjustments based on the Mark 1 Mod 0 eyeball (which is noit as good as it used to be) I thought I might try using some line to locate deviations in the "smooth" run. If I ran a piece of line (Syren .018 dark brown in this case) on the underside of the batten (since in generally curves upward) if the line deviated from the batten across two bulkheads could mean that the batten is too high somewhere in this area.
It seemed to work okay as I found a spot (unremarkedly where the junction in the batten was located) and I adjusted the junction to reduce the gap.
It was more obvious in real life than  in the pictures.
IMG_0584.thumb.jpeg.6f81547eb91bc869fa7c364c0400c34e.jpegIMG_0585.thumb.jpeg.fb70cc7f25d783b089f7a3f6a3a144fa.jpeg
Thanks,
Gary
                       USF Confederacy
Link to comment
Another note for those who come later -
While it is obvious to me now how the sills/lintels are provided it was not a few hours ago.
There are two 3/32" carrier sheets that contain the laser cut sills and lintels (among other things) - sheets L and N
The instructions show one of the sheets but I think they have relaid out the laser cut sheets since the instructions were done so I had a hard time finding a carrier sheet that looked like the one in the instructions.
Anyway here are the two sheets and an explanation of where the various pieces go on the model.
Thanks,
Gary
                       USF Confederacy
Link to comment
Added the port sills on both sides (per instructions).
Once I figured out which sills went where (see above post) it was relatively simple. I used the disc sander to take most (but not all) of the "extra" length off the precut sills.
After I had one side done I cut a "template" narrow enough to fit between the bulkhead extensions, long enough to fit across the hull, and the required 3/16" thick to use as a gauge of the "flatness" (across the deck) of the sills and later to set the height of the lintels.
Here is a close up of two of the sills  - I used thin CA to glue them in place. I am going tom paint the gun ports red so am not too worried about getting glue on the sills.IMG_0591.thumb.jpeg.40a2b6e9268952e0d4679414451c3655.jpeg
Thanks,
Gary
                       USF Confederacy
Link to comment
Continuing with the port sills and lintels.
Gun deck is complete and sills for the quarterdeck are in place.
I noticed that the bulkhead extensions on two of the bulkheads (6 and 7) did not seem to align correctly with those on either side. Not sure what happened (maybe the gun deck sills and lintels forced them out of position somehow). So before I glued the quarterdeck sills in place I adjusted the extension protectors to try and get them closer to the correct position (as best I can tell). Hopefully when the quarterdeck sills and lintels are in place they will be "good enough".
Upper rail on quarterdeck is next. Then the "real" fun - the templates to locate the port sides and dealing with 70 something little pieces that have to be "perfectly vertical" per the instructions.
Thanks,
Gary
                       USF Confederacy
Link to comment
Gary, you have probably figured this out. After marking your gunport locations, use a jig the same way you did for the lintels and you have the “perfectly vertical” by the tail.
Completed builds:
Link to comment
Thanks Bossman.
I have just gotten the templates cut out and need to get the stbd quarterdeck lintel installed and faired before I deal with the gun port sides.
A spacer/template for the gun port sides would certainly make sense. I'll see what I can come up with.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
I have been so involved getting all the various pieces as correct as seems possible (for me) that I have neglected to get many pictures.
So here is the port side with all the gun port pieces in place, the sweep port backings in place (but not yet sanded flush) and the hance pieces clamped in place while the glue sets.
There will be plenty of sanding once the stbd side is in a similar condition.
To help with the sanding of the sweep ports I used a colored pencil to mark the bulkheads. I had already sanded off the laser char in the previous rounds of fairing and was afraid I might get carried away so hopefully the red will tell me when I have the sweep ports even the rest of the hull "pieces". The two shims under the rail where the hance pieces are is to hold the railing up while hance pieces are clamped in place. Don't ask how I know that I would need them.
Thanks,
Gary
                       USF Confederacy
Link to comment
Subject to a final, final inspection I believe I am probably ready to start the hull planking. At least that is the next chapter in the instruction manual.
So "in honor" of this accomplishment I broke out the "big" camera (Canon EOS 60D) and shot a dozen or so pictures to document what the model looked like at this point in case that might be useful to someone in the future.
Before I get to the pictures a word on the hance pieces. As indicated in the instructions each hance piece is made up, of two laser cut pieces 3/16" thick. That is about twice as thick as required since they sit on top of the 3/16" wide "rail" that runs across the tops of the bulkhead extensions along the spar deck. Using nearly doubly wide pieces is (IMHO) provides for the slight angle where the hance pieces meet the fore and quarter decks. I should have reduced the thickness of the combined hance pieces before gluing them. It took a considerable amount of sanding (all manual) to get the hance pieces to match up with the surrounding structure all the while trying to not break something. Although the model is considerably stronger than previously I still had to use one hand to sand and one to support whatever was being sanded.
Here is one of the hance pieces after "thinning" and you can see there is not much left of the second half. And there was some taken off the inboard side as well.
Here are the rest of the photos.
Thanks,
Gary
                       USF Confederacy
Link to comment
So clearly in the above pictures I had neglected to outline the sweep ports.
I thought I would try a somewhat different approach to that described in the instructions. I cut out a piece of Swiss Pear 3/32" thick  the size of the sweep port (7/16" square as best I could measure) and drilled a #75 hole as near to the center as I could manage and inserted a #75 pin.
I cut out the template as described in the instructions and taped it to the side over the sweep port area.
Then using a steel ruler and sharp pencil I drew an "X" across the corners of the opening and used an awl mark where the lines crossed.
Sorry about the picture being upside down. Apparently if you take it with the lens toward the bottom of the camera (iPhone 11 Pro) is takes it like this and rotating the photo in the iMac "Photos" program does not change the orientation.
The I used my trusty cordless screw driver to drill a #75 hole in the awl mark.
Then insert the pin with the block into the hole and align it with the "flow" of the sweep port wood, now tap the pin with a small hammer to hold it.
Trace around the block and pull the pin out.
Now repeat for each sweep port. I did the ballast port "the old fashioned way - per the instructions. We will see how things turn out when it comes to planking this area which seems to be somewhere in the far future.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
I got all the sweep ports (and ballast port) on the stbd side done then decided to get this side "finished" for painting before working on the port side.
One thing I noticed which building the gun ports is that in the two places where a bulkhead extension has to be removed the bottom of the gun port is now really in three pieces, the sill on each side of the cut off (and trimmed) bulkhead extension. Although this area will not be all that visible (at least at the bridle port) I thought it might be worth the effort to "patch" in a thin piece to cover the bottom of the bridle port and the quarter deck port at bulkhead 6.
I thinned down a spare piece of cedar to a bit less than 1/64" and tried to get the port opening flat and enough thinner so that the additional, piece will not look horribly out of line with the other ports - although I suspect this will have more to do with how the planking job goes. It is hard (for me) to envision how the outside of the hull is going to look without even a little planking to guide my imagination. Anyway here is what the bridle port looks like with the new piece installed but not yet trimmed.
This is the quarterdeck port also before trimming.
In addition to these "additions" I have decided to try to seal the area around and inside of the ports so the paint will have a better surface to grip and (maybe) the paint job will look more like what is shown in the instructions. For starters I cut down some of my 220 grit sanding "sticks" so that they are the same width (and others the same height) as the gun ports. Here I am cleaning up the area inside the gun ports.
473101757_IMG_06172.thumb.jpeg.bf2d795b7bdcc69de142904bc6274f13.jpeg2027435747_IMG_06162.thumb.jpeg.3ebb8f3455e638df8e4f5a578cea8253.jpeg
Next I applied a sanding sealer.
And here is what one of the ports looks like with the sealer applied.
The discoloration on the top right of the port is where I added a piece of 1/32" basswood to bring the port side out to meet the lintel. I did this on several of the ports where I did not get the port side proud of the lintel. Hopefully the sealer and paint will make this "disappear" or at least be less noticeable with the port lid in place. It seems I might have gotten a little carried away with the clean-up sanding. Maybe another place for an insert.
Next step (I think) is to sand again, this time with 400 grit (and maybe another coat of sealer/400 grit) and then paint - Badger Windjammer Red - same as the gun carriages.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
Completed the starboard side gun port first coat painting - moving to the port side preparation then will get both sides, first coat on port, second omn starboard.
One "issue" at the bridle port, the bottom of the bulkhead extension (that was cut out) extends well inboard of the sill (see last picture). In addition, the portion of the bulkhead extension above the sill is considerably thicker than appears to be necessary. The bulkhead "thinning" is not supposed to be done until after the outboard bulkhead planking is completed, presumably when the bulkheads have the maximum support. It seems there will be a good deal of material (plywood in  this case) that needs to be removed. power tools (Dremel drum sander comes to mind) may be necessary.
Thanks,
Gary
                       USF Confederacy
Link to comment
I clearly jumped the gun on painting the gun ports.
The next step (in the instructions if I had bothered to look ahead one page) was to install the sheaves and the supporting structure which requires more hull fairing, right next to the gun ports I just painted. At least it was only the first coat so it was not a total debacle.
However, before I can install the sheaves (three sets on each side) I need to decide if I want the sheaves to be in basswood or some other wood. I still "think" I am going to plank the bulwarks (at least the outside - still thinking about the inside (ceiling?) ) with Swiss Pear. Unless I want the sheaves to "stand out" I need to fabricate them from Swiss Pear.
So that is what I spent the morning (before football) doing.
I had a piece of 3/16 X 5/16 Swiss pear that would allow me to get two sheaves from a single length. Sheaves that are guaranteed  to match up since the holes were drilled on each one at the same time.
So I laid out a sheave on the Swiss pear - as you can see from the picture below my first attempt did not work out. I used a #65 drill for the end holes - it seemed about the size of the slots in the laser cut piece. I found that unless the drill bit is gripped in the chuck with just enough bit exposed to drill through the wood that the bit tends to wander and is in a slightly different place on the back side. I am sure we have all experienced this with small diameter bits - I was just a little shocked that it happened with a #65.
Anyway, once I got the sheave laid out and the holes drilled I used a small, sharp circular needle file to create the groove that represents the actual sheave. I also used this file to create the "curve" as the sheave "disappears" inside the "case". I did this on both sides of the piece of stock.
Here you can see one side with the laser cut piece for comparison.
After laying out and "carving" the other two sheaves I cut the billet in half, sanded each piece down to 1/16" thick and separated and sanded the sheaves to the required dimensions. Here are the pieces for the starboard side along with the laser cut equivalents.
Now I just need to "do it all again" for the port side.
Thanks,
Gary
                       USF Confederacy
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
