F4F-4 built as FM-1 Wildcat by Landlubber Mike - FINISHED - Tamiya - 1/48
Ok an FM-1 Wildcat, mid war, off an escort carrier in the Atlantic.... you would be hit or miss on the interior painting.... Prewar, the bulkheads were white or very light grey and the hangar deck was dark deck grey.... They remained that way up to late '42 when the orders came down to remove all flammable materials below decks not consistent with operational needs...
And another thing to note, that order was specifically directed to the Pacific fleet, not the Atlantic fleet, (at least not initially) Admiral King didn't make it a fleet wide order till the middle of '43... so if you were building a plane on a Pac. Flt ship I would say yes, bare metal would be appropriate, but your markings indicate an Atlantic fleet squadron flying from an escort carrier on convoy duty.... (late '42 early '43 based upon the aircraft markings) Deck grey would be appropriate and the most likely scenario.... Your images show both believe it or not... and the color shot shows a deck grey floor, light grey bulkheads, light grey overhead.... The aircraft is also in the same color scheme, (pattern) as yours is with similar markings... Prewar aircraft grey period, ('38-'41) it would in general be a typical hanger deck prewar.... (and for the Atlantic Fleet throughout the early war period)
Just my opinion brother.... she's looking beautiful....
Edited by Egilman
Quote:
Link to comment
Share on other sites
Thank you for the information!  Makes a lot of sense.  Still not sure about putting it on a diorama or just leaving it as is, but this has been a real learning experience for sure - WW2 aircraft, colors, flight decks versus hangar decks, etc.  Not to mention, learning how to really chop up a kit and add resin details.  Maybe making a base that is a dark gray base with sorta big squares etched out like in this picture would get me there.  Then I can add a mechanic or two and lay the panels down and have a nice little scene.  I started looking at hot wire cutters to be able to cut styrofoam to make plane and ship dioramas, so maybe I should just go with the flow.
I've been thinking about what to pull off the shelf next, and I'm leaning towards staying with US WWII aircraft and going with the Accurate Miniatures TBF-1C kit.  I've got a few goodies for that kit and could build it similarly to this one with the exposed engine bay, wings folded, etc.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Thanks Kevin, really appreciate the kind words.  I have this set that maybe could fit the bill…
Mike
Link to comment
That deck crew should be perfect, Mike.
Link to comment
she's look'in good Mike......a dio looking base is what I do with tail heavy aircraft {bombers mostly}.   good to see you working on her again :)
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
  • 1 year later...
This one has been close to the finish line for quite some time as I got a bit bored with it and moved on to other projects.  Just about done though now, just have to add the wings and finish the diorama.
Warning - even though the kit instructions say you can model it with the canopy open, the sliding piece just does not fit.  I came to find out that others had a similar issue, with one person cracking the part to get it to fit.  Thankfully, the eBay auction seller included a Taurus canopy, and I was able to replace the kit part.  The Taurus canopy was a bit loose though, so when i pressed it to the fuselage, a bit of glue spread further than I was hoping.  🤬  Oh well, not much I can do.
I almost threw the whole thing out when clear coating it - I ended up getting spiderwebbing in a few places when using one of the Mr. Color clear products.  Even got it when trying out the rattle can version.  I think it just pooled too heavily.  My spray booth has these really bright LEDs, and sometimes I can't tell how much of a coat is being applied with certain colors and with the clear products.  Live and learn.  The good news is that was able to lightly sand off the clear coat, reapply a bit of dark wash, and re-apply the clear coat with no issue.  Whew!
I did spend a bunch of time trying to figure out how to put it in a diorama on a carrier hangar deck, as there aren't many pictures out there of what the flooring at least looks like.  I did get a diorama base finished though, and at this point, just have to finish painting some of the mechanics to go along with it.
Thanks for looking in!
Mike
Link to comment
3 hours ago, Javlin said:
I like the demarcation on this build morso than the Buffalo as far as scale effect goes.Should look sharp when done!:imNotWorthy:
Thanks Kevin!  Funny thing is on this one, I painted the lines fairly sharp, then tried to dial it back a bit and have softer edges as that is what this Atlantic camo scheme called for.  I ended up using thinned Gull Gray paint applied via a sponge to try and get the effect.  Did the best I could 😐
On the Buffalo, I could find nothing indicating whether the lines were sharp or soft.  I decided to go with soft, given how the green and olive complemented each other.  I used the blue tack method to separate the side and overhead camo from the sky-blue-gray under camo, but did the side and overhead camo (the green and olive) freehand.  I have a 0.18mm airbrush which helped a lot.
Mike
Link to comment
You did great brother looks the part to me.... Sometimes dry stippling a sponge is the best way....
Quote:
Link to comment
Finally finished with this one.  Probably a bit steep on the difficulty level given that it is my fifth plastic plane model, but I'm quite happy with how it came out.  Given that the engine and other panels were removed, I tried to model it as maintenance work on a hangar deck of an aircraft carrier.  Couldn't find good color pictures of what the deck looked like, but some of the pictures showed what appeared to be larger squares that were dark gray and/or metallic in color, so I went that route.
Just wanted to thank everyone for the help on this build, I really appreciate it.  Thanks!  Here are the pictures.
Mike
Link to comment
Mike, the way you display your models takes them from amazing to incredible. Beautiful work!
Regards……..Paul
Completed Builds   Glad Tidings Model Shipways. -   Nordland Boat. Billings Boats . -  HM Cutter Cheerful-1806  Syren Model Ship Company.
Link to comment
Wow! Very, very nice Mike.  The display with the maintenance crew is perfect 👌
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Thanks guys!  Really appreciate it!
Thanks Paul!  It's been interesting trying to learn this diorama stuff - a little more complicated than it appears.  To me though, having figures and/or a scene around the model helps to show scale, and especially, helps bring it to life.  Best of all, it's fun, and allows you bring a little creativity to the project.
Edited by Landlubber Mike
Mike
Link to comment
Fantastic model and display, Mike!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
Very Very close to pre-war deck grey brother.... In real life it would be gloss with embedded grit for traction, you've got the scale representation down my friend....
I love it!
Simple, but stunningly beautiful mike....
Another masterpiece model....
Well done...
Quote:
Link to comment
Thanks Bob, really appreciate it!
I love it!
Well done...
Elmer, thanks very much for the kind words.  And really, I truly appreciate all your insight and help on this build and others.  You've really been an invaluable resource, so thank you.  Hope I can repay all your help some day.
On the deck grey, I had to guess from black and white pictures so I'm glad I wasn't too far off.  I started with black primer, then sprayed a thinned coat of a dark grey over it, leaving some of the black to show.  Then I sprayed a very thinned layer of a dark metallic (I think it was something like gunmetal gray) to get a little bit of a metallic finish to it.  It was a comedy of errors and took me three tries to get it the base right.  I had the color ok, but the first time I tried using white glue to adhere the plastic card to the wooden base, and a week later the base was all rippled and bubbling up.  Second time I think I accidentally spilled CA on it, so had to toss the attempt.  Third time seemed to finally work, but I came very close to throwing it and the model out the window!
Mike
Link to comment
Well done, Mike. Your scenario works well. 👍
Ken
Started: MS Bounty Longboat,
Link to comment
Thanks Ken and Alan!
Mike
Link to comment
It was my pleasure, remember research is my second hobby....
Pay it forward brother, that's what I'm doing for those that helped me....
thank you...
Quote:
Link to comment
Very nice display and great model. With all panels open and the crew around you show a story behind it.
well done,
Dan
Current build : Mayflower - AL 1:64
Completed non-ship builds : Spitfire MK I - 1:48Arado 196B - 1:32, Sea Fury - 1:48F-15C Eagle - 1:48Hawker Tempest Mk.V - 1:48F104S Starfighter - 1:48
Link to comment
5 hours ago, Hsae said:
Great work, Mike!
Hermann
Thanks Dan and Hermann, really appreciate it!
Mike
Link to comment
Thanks Craig, really appreciate it!  There weren't too many progress posts as this sat on the shelf for long stretches.  But glad I finally finished it - pretty pleased with how it came out.
Mike
Link to comment
Thanks Kevin, took a while, but I finally got it over the finish line.  Kept getting stuck and/or bored :)
Mike
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
