Granado 1742 by DocBlake - FINISHED - 1:32 Scale - Bomb Vessel Cross-Section
Thanks, Grant!
I glued the six shell racks to the lower support beams.  The placement needs to be precise because two more layers of structure sit on top of the shell racks before the mortar pit floor.  The plans call for the racks to be pinned in place.  I thought this would be too difficult to do precisely so I used a couple of home made jigs to align the shell racks while the epoxy I used dried.  They're not going anywhere!
Edited by DocBlake
Link to comment
Share on other sites
Work on the shell room continues.  I made the upper support beams out of boxwood and the blocking timbers between them of pear.  They're glued into place, but not poly'ed yet.  Once that's done, I will individually fit each of the 6 mortar pit beams into their notches on the clamps.
Link to comment
This shell room will be beautiful. Always a pleasure to follow the evolution of this model. 😄
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • Santa Maria boat - Korabel (Ukraine) - 1:24
Link to comment
Thanks, Jean-Paul!
The next step is to cut out the mortar pit beams.  These support the pit deck itself, and in turn, rest on the upper support beams of the shell room.  There are notches (really shallow dadoes) for both on each beam.
I milled up some 3/8" thick swiss pear and glued the beam templates to the wood with rubber cement.  They were then cut out using the scroll saw.  The mortar pit boundary timbers fit in the dadoes on the upper surface of each beam (red arrows).  It's important that these line up exactly so I cut the beams a little long and snuck up on the final length using the disk sander.  There should be no side-to-side play in the beams when fitted properly.  Then I cut the dadoes on the under surfaces of the beams (green arrows) after marking each one individually so the fit on the upper support beams is precise.  The beams have poly but are not yet glued in place.
Link to comment
A little bit late to the party but I am all caught up and will be following along from here if there is room for one more. As always Doc great subject and masterful execution, a real pleasure to watch.
Best Regards
Link to comment
Link to comment
Thanks, guys!
After gluing the mortar pit support beams in place I began work on the mortar pit itself. The first parts to make were the boundary timbers that define the outboard boundary of the pit deck. These are swiss pear timbers with a rabbet ploughed into them to accept the secondary planking layer.
There a two layers of planking. The primary or lower layer is thick: about 9 scale inches. The secondary layer, which lays on top, is thinner and has a recess cut in it for the rotating platform the mortar sits on.
Holly can get mold growth which can stain it a bluish gray color if there is too long a delay between cutting the logs and kiln drying. I had a piece with that stain in it. Rather than chucking into the fire wood pile, I used it for the lower planking, since only the ends of the planks can be seen and they don't show the staining. The photos show the lower or primary mortar pit planking and the boundary timbers. Note the discoloration of the holly.
Edited by DocBlake
Link to comment
I built the secondary mortar pit deck off the model by edge gluing the planking together.  I then located  where the center of the circular cutout would be and drilled a hole.  I transferred this location to the primary deck by putting the deck back in place and marking the primary deck with a nail through the hole.
I whipped up a little jig to hold the secondary deck in place while I drilled out the circular recess with a Forstner bit.  The secondary deck was glued in place.
Edited by DocBlake
Link to comment
Dave, I don’t know how I missed this one but I’m pulling up my hay bale to sit on! Beautiful work.
Current build: Model Shipways “Confederacy “
Completed builds:
Mamoli “Royal Louis“
Mantua “Royal Caroline”
Scratch 1/4 scale gondola “Philadelphia”
Scratch “Hannah” from Hahn plans.
Link to comment
Thanks!
  I'm working on cutting the mortises into the upper deck clamp today.  Meanwhile, I laid out and installed the treenails in the mortar pit deck.  I used a #61 bit and birch toothpicks!
Edited by DocBlake
Link to comment
I cut and notched the 4 planks that make up the upper deck clamps.  After bending them to the slight aft narrowing they were glued in place and treenails added.  Then I cut out the eight mortar pit support knees and pinned and glued them in place.
Edited by DocBlake
Link to comment
I  started work on the upper deck by rubber cementing the deck beam profile templates to a sheet of 3/8" swiss pear. I used the scroll saw to cut out the beams, and sanded them smooth. Each beam is 12 scale inches square in profile!
I cut the beams slightly long and used the disk sander to sneak up on the final width. I'd like them to fit with no side- to-side play, but the fact was that due to the tumblehome of the top timbers, I had to make the final beam length a little short so they could fit into their notches on the clamps. Any side-to-side play will be taken care of by using removable shims at each end at glue up. The photos show the beams resting in place. Partial beams #4 are not yet fitted.
Edited by DocBlake
Link to comment
What a great job! This cross section is really beautiful!
Jean-Paul
Current builds :
Finished build :
Next on list :
Link to comment
Thanks,  Jean-Paul,  and thanks to all for the "likes"!
 A friend and collaborator, Joseph, is doing 3-D drawings of the plans and we are making changes to simplify construction for those less experienced.  This includes eliminating the rise in the frames moving aft as well as eliminating the narrowing of the hull moving aft.  He also drew up the deck such that all the beams, carlings, ledges and lodging knees were the same thickness (pictured). I decided to use stopped dadoes on the beams to seat the carlings.  Thus the carlings would be thinner than the beams.  I'll keep the ledges and knees the same thickness as the carlings, though, to simplify construction.  I think it will look fines.
Rather than use a razor saw, chisels and a hobby knife to cut the dadoes for the carlings, I looked for an easier way.  what I did was cut the dadoes all the way through the beams at a depth of 1/16".  I then milled some 1/16" pear stock to the width I needed to give me  stopped dadoes.  These were glued in place and sanded smooth.  Very easy!
Edited by DocBlake
Link to comment
I finished all the blind mortises for the carlings using the technique I described earlier.  It really went pretty quick and doesn't look bad.  There is poly on all the deck beams, and I'm ready to start assembling the deck. Sorry for the blurry photos!
Link to comment
Thanks, guys for the "likes"!
Here is where I am. I've got all the deck beams notched and have started installing them from aft forward. Because the beams sit in notches in the deck clamps, they can't move. Fitting the hanging and lodging knees is really finicky if you want a tight fit. I'll add the carlings and ledges and finish the deck up to the forward end of the mortar pit. That's where the hardest part of the deck starts: fitting the beam arms. I cut them generously and left them a bit thick. They are so long that I have to account for the deck camber.
Link to comment
Beautiful work!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Link to comment
Thanks, guys!
I installed all the hanging knees, lodging knees and carlings from the aft end of the section to the forward edge of the mortar pit.  I'll add the ledges to finish this part of the deck before adding the beam arms and the rest of the deck framing.
Link to comment
Link to comment
Link to comment
I cut the pillar under deck beam #2 to length.  Here it is, dry fitted.  I plan to pin it to the keelson and the deck beam.  The piece of holly near the footwaling is just a measuring stick I used to locate the pillar on the keelson
Link to comment
Very nice! I like the „painting with wood“ and your clean and crisp work.
HM Brig Badger 1/48 from Caldercraft plans
Le Coureur 1/48 by CAF
Completed Build:
Armed Virginia Sloop 1/48 by Model Shipways / Gallery
HM Cutter Sherbourne 1/64 by Caldercraft / Gallery
Link to comment
Link to comment
Looking great Doc!
cheers
Pat
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
