LOCKHEED P-38 H-5 LIGHTING, 1;48 Limited Edition by Tamiya, BobW
oneslim
1 hour ago, oneslim said:
Roger,  I think it was up.  Also he took His Wife up for a spin.
BobW
Yep, Bong was a young fighter jock, pulled several stunts during his career, like looping the Golden Gate bridge with three other pilots on June 12th '42, buzzing market street in San Francisco at a reported height of 50 ft, and a civilian complaint of flying so low over a neighborhood that his prop wash blew a lady's laundry off her clothesline.... He was grounded for those incidents and several others when his unit shipped out to Europe..... (got a royal chewing from none other than Gen Kenney himself for it)
He was eventually assigned to a unit going to Australia and the SWPA..... soon flying out of Port Moresby, they didn't have any Lightnings at that point, (early in the SWPA P-38's were very scarce) so he was assigned temporarily to another unit flying P-40's so he could get some combat experience... This is when he got his first two victories, a Zeke and an Oscar I believe, he was awarded the Silver Star for it.....
He was one heck of a pilot....
Edited by Egilman
Quote:
Link to comment
Share on other sites
Part 5
Here the front view of the center pod with the cockpit installed.
The rear view.
From the left.
And from the right.
These are the turbo-superchargers,  painted with Alclad II Lacquer Steel and Jet Exhaust.  Mixed at three to one.
The same parts with a weathering of AK Acrylic Rust Effect colors.  I know it looks rough,  but after drying for a day,  some work with a stiff brush they will look much better.
Here they are being test fit.  Bare Metal Foil has been added to the leading edges of the wings.  The area covered were the inter coolers for the turbo super-chargers.  The internal structure was corrugated with the liquid coolant flowing through.  All the early P-38's had this system.  It caused many maintenance problems with constant leaks and was easily damaged.  This system was converted to fuel storage  starting with the 'J' model.  The inter-coolers were moved to the bottom of the engine nacelles between the oil coolers giving the deep chin look.  I think they spoiled the profile of a very sleek airplane.
More to Come,
BobW
Bob Wescott
South Jersey
Link to comment
the cockpit looks good :)    I like the foil idea......will it be painted over?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
That is truly an astounding cockpit Bob. It looks to have more parts and detail than many full models!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Thanks Lou,  and Thanks for the 'LIKES'.
Popeye,  Yes, it will be painted.  The wing roots were a heavy wear area.  Not much chipping but the ground crew would be fueling, filling oil tank,  and
working on the engines.  The plan is to paint with yellow zinc primer followed by RAF dark green.  This will be weathered and then very gently sanded to
show wear rather then chipping.  The leading edges of the wings in photos show streaking wear and some chipping.  The remainder around the engine
access panels will be treated with chipping fluid on the edges and fasteners.
BobW
Edited by oneslim
Bob Wescott
South Jersey
Link to comment
Part 6
This is the oil coolers that go beneath the nacelles on each boom.
Here are the parts of the right boom.  Both halves,  the oil coolers,  and the main gear well.  The steel ball weight is in place.
This is a crop of the tail fin showing the antenna anchor made from a sewing needle that has been ground flat and CA'ed into a filed slot.
Over all shot with booms and elevator on.  These parts just 'click' together.  I have never worked on a model that fits this well.
Rear view,  this baby is self aligning.
Bottom view,  the wooden struts and pads are to protect the very delicate gear door struts.
The gear door arms can be seen in this view.
More to Come
BobW
_REW2424 (Medium) copy.psd
Edited by oneslim
Bob Wescott
South Jersey
Link to comment
Looking excellent.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Fantastic work Bob!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
you have the tail spot on........why wouldn't it align?  ;)    coming together very nice.........very detailed :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Part 7
Well,  It's been awhile since the last update.  The holidays were very busy.  And my buddy Max,  a Min Pin,  Pasted after 14 and a half years from congested heart failure.
This is a laser Headstone I had made for His Grave.  It's only 5" x 7" on black granite.  He will be missed.
Here is a shot of the canopy and the instrument canvas hood at right.  This hood was a sun shield that could be folded forward for a better view of the instrument panel.
This a starboard view with the canopy installed.
Here is a shot of the antenna lead-in which passes through the rear canopy.
This shot shows the amour glass to the front.  Micro Mask is on the rear canopy.
The pilot's seat has been installed.
More to come,
BobW
Bob Wescott
South Jersey
Link to comment
Sorry to hear about Max, Bob.  Losing a member of the family is always hard.    As for the model, looking good.
Link to comment
Very nice work, Bob.
Dan.
Current build : Mayflower - AL 1:64
Completed non-ship builds : Spitfire MK I - 1:48Arado 196B - 1:32, Sea Fury - 1:48F-15C Eagle - 1:48Hawker Tempest Mk.V - 1:48F104S Starfighter - 1:48
Link to comment
Tough loss their, Bob. But he'll be waiting for you, one day.
Aircraft is looking very good.
Ken
Started: MS Bounty Longboat,
Link to comment
sorry to hear about Max.......I have one on the other side of the Rainbow Bridge too....... :(  condolences.......
good to see your making progress.......
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Same as what the other guys have said.
OC.
Current builds
Completed works.
Link to comment
Hard to respond to your post Bob. Sad to hear about Max, but then you follow up in the same post about your beautiful P-38 So I am saddened about the first part and impressed by the second.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Sad news about your buddy.
Model looking great!
Hard to like the post though.
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Part 8
This is a small update, been busy with with doctors.  Our annual check ups all are due for both of us in the New Year.
Here is a shot of the gear  legs.  They are brass for Eduard.  Soaked in a vinegar bath, then primed with Alclad II black gloss.  This was followed with polished aluminum on the recoil leg and dualminum on the strut leg.
These are the wheel and tire combos, made of resin from Eduard.  Sprayed with AK rubber black and then brushed with AK airfield dust.
This overall shot shows a coat of Alclad II airframe aluminum and a top coat of clear gloss.  This will be a base for chipping.
More to Come
BobW
Bob Wescott
South Jersey
Link to comment
Hi Bob: I'm also sorry about Max. Our pets are family, and I know how hard it is for you.
Your P-38 is looking great. I really like that your using Alcad as the base for weathering and using the foil at the wing base is especially interesting. I had not heard of either of those technique before. It also seems like a good way to practice with Alcad before doing a natural metal finish airplane.
Dave
Link to comment
Thank You Dave for Your kind thoughts.  Everyone thanks for the 'LIKES".
The Bare metal foil is for wing roots where there was heavy wear from the ground crew walking.  The plan is to use a very fine sandpaper and carefully go down through the paint to show the metal.  Where the Alclad II is coated,  a chipping fluid will be applied and a toothpick used to 'chip' the bolt heads and panel lines.
BobW
Bob Wescott
South Jersey
Link to comment
You do some Nice work Bob and I really like the Idea on the antenna attachment stored/filed.My eyes are starting to have a problem even in 1/32 up close hence the reason 1/48 are relegated to OOB anymore.Looking forward to the foil and paint think I have the an idea of what's going on sure the evolution will provide the details.:imNotWorthy: Kevin
Edited by Javlin
Link to comment
  • 2 months later...
Part 9
It's been quite a long time since the lat update.  I have worked on "Pudgy III" whenever I could grab an hour or two.  Life has just been getting in the way.
Here is a shot of the lay out for painting the tail markings.  Tommy McGuire was Squadron Exec at this time period.  These markings were in red with white border.  They consisted of red with white border top and bottom of the rudders and the bands on the booms.  The zinc chromate yellow was my attempt to show paint worn off down to the primer.  This was a failure,  the top coat bonded to the primer,  and I was reluctant to use solvent.
Another view.
Here she is with the base coat of RAF Dark Green.  Six parts of this color to which one part flat white and two parts of yellow were added to 'fade' the RAF Dark Green.
This is a mask that creates a blotted pattern.  RAF Dark Green straight was used.
Starboard wing blotched.  It shows much better in person.
Port wing.
A shot with a gloss coat of Lacquer in prep for decals.  Also a 'Panel Liner' for green camo was used first.
Bottom with a "Panel Liner' for grey.
This is the color pattern I was trying to match.
More to Come
BobW
Bob Wescott
South Jersey
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
