Duchess of Kingston 1798 by glennard2523 - FINISHED - Vanguard Models - 1:64 - Royal Yacht by Glenn Shelton
1 hour ago, James H said:
That sir, is looking champion! The sanding and shaping look real good. The second layer should be quite easy now.
Many thanks James, your comments are greatly appreciated, as is your build log and advice. Credit must also go to Chris for an awesome design.
Glenn
Glenn (UK)
Link to comment
Share on other sites
Stage: Hull Construction
Build instructions: 78-81
Task: Stern Counter Patterns and Outer Side Patterns
Parts: 77 & 78 & 119 &120
Time Spent: 30 mins
Status: Complete
Build Notes: The bent lower stern counter pattern fitted like a dream and was glued in to place as was the upper stern counter pattern. The stern post assembly was also glued in to place at this stage. I did bevel the edge of the upper stern counter pattern so that I got nice join with the lower stern counter pattern. I will leave this area alone for the next couple of hours to allow time for the glue to cure.
I did remove and reposition the patterns shown in the following pattern as they were not correctly positioned.
I might need to add a touch of filler near the two outer edges, as can be seen in the photo below
Using the location strips supplied (another great idea by Chris) I dry fitted the bow and keel outer facings and this does provide a perfect rabbet for the 2nd planking.
The two outer side patterns were soaked in hot water for 30 mins and then clamped to the hull. I found having the bow outer facings to be a benefit but not essential. These patterns will be glued and clamped along with the bow and keel outer facings once the patterns have had time to fully dry out. I am impressed with the provision of pin holes to aid the correct alignment of the outer side patterns during the glue and clamp phase. This attention to detail by Chris is one for the many factors which sets his kits apart for other designers.
I plan to start the 2nd planking tomorrow morning. I will take my time to ensure I am happy with the fit of each plank before it is glued into place. I plan to edge bevel the planks to minimise the joint gaps and will probably use Chuck’s lateral planking bending method once again, especially for the planks above the water line. I do not think it is a critical for the planks fitted below the water line as they will be sanded, filled, primed and painted for a smooth seamless finish (fingers crossed).
Edited by glennard2523
Glenn (UK)
Link to comment
Build instructions: 82 - 84
Task: Stern Outer Side Patterns & Bow and Keel Outer Facings
Parts: 134, 135, 135 & 136
Time Spent: 40 mins
Status: Complete
Build Notes:
The bow end of the two outer side patterns 134 and 135 required a very minor trim. I removed approx. around 0.2mm from each bow end to ensure a good fit as the design had left some extra material to allow for build variations.
The two outer patterns lined up very well and I used the various pin holes to ensure they were correctly lined up. I used a couple of spreader clamps for the stern area, and standard clamps, elsewhere as the wood glue cured.
I then proceeded to glue to the bow and keel outer facings. I think I used enough clamps to ensure these parts were properly secured during the curing process😂. The hull is now ready for the 2nd planking.
Glenn (UK)
Link to comment
I believe that it is important to make sure everything is ship shape before undertaking the 2nd planking. Therefore I thought I would share my final preparations before I start the 2nd planking, as I did find this very beneficial and I did discover a couple of minor adjustments were necessary. Below I have detailed the following checks I undertook:
a) Now that the bow and keel outer facings had been glued in place I double checked the rabbet using a plank. I was happy that I had a good gap around the bow and along the keel.
b) Check how the planks would look along the stern post and under the lower stern counter. I discovered that the hull required a little bit more sanding (with a thin sanding stick) around the stern post / lower stern counter area before I was happy with how the planks would fit.
c) Check how the first plank will fit around the bow area and to see if there is any tapering required. I do not think the first plank will require any tapering. The true line of the plank does not follow the bottom edge of the outer pattern as shown in the photo below. I found I could " force" the plank to follow the bottom edge. However as I intend to use Chuck Passaro's plank bending method I think the "U" shaped bent plank will fit Ok.
1759020027_00962ndPlanking-firstplankcomments.thumb.jpg.d6b671f63d0b87e31b1b27274945e798.jpg
d) using a triangular length of material I made a simple jig to enable me to chamfer the plank edge.
e) Using a spare piece of planking material (from Speedy) I tested the plank bending method. Using some clamps the plank is held in a bent position. I then brushed on some water and used a hair dryer.
f) Once the plank had cooled down (only takes a minute) the bent plank was test fitted and I was pleased with how easily the plank fitted. Once secure in the rabbet the plank followed the required line, without any forcing) and staying flush with the hull. A clamp was added to hold the plank to demonstrate this in the photo below.
Glenn (UK)
Link to comment
Glenn, this is turning out to be a wonderful tutorial!  I'm at fairing stage and have already used several of your tips & suggestions.   The second planking is going to be beautiful.  Did you have to use any stealers in the aft section of the first planking?
So far my only troubling area was installing the false main deck.  I dislike having to "manhandle" ply wood under high pressure up against fragile supports.  I considered cutting the deck in half after dry fitting, and chipping the ply when extracting it.  I also broke off the port side stanchion #3.  Not a big deal.
Carry on with your superb work,
Darrel
P.S.:  I've elected to not start a build log as we now have four, and I didn't want to clutter it up with another.
Link to comment
Darrel, there's no such thing as too many build logs. Everyone has slightly different approaches and it's great to browse through all the logs on the model you're working on. And logs are as much for the writer's benefit as for the readers - at least as far as I'm concerned. If I didn't record my methods I'd probably forget them between builds!
Derek
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
Link to comment
Agree with Derek and James.  Everyone brings something different to the table with their logs. If not none of us would do one after James posted his. 🤣
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Hello Darrel
Many thanks for your kind comments. With regards to the aft section I did not fit any stealers. I think the method I used on the port side worked best for me. I planked down toward the keel for 8 planks. I just trimmed the planks as necessary without any stealers bow or aft. I then started to plank from the keel toward. I then took three full planks for the bow to be complete.
I continued upward until the planking was complete. It required 14 planks at the stern
Glenn (UK)
Link to comment
Okay fellas I'm in.  I'll take photos tomorrow and begin to write about my experiences.  I truly love the ship we are all working on and dearly want to "bring it home" as close to James' creation as my meager skills will allow.
I do have another question.  Since my youth, this is the third ship model I've endeavoured.  The first two I used CA glue almost exclusively.  After the horrors of CA I now have switched to PVA, and a bit more patient attitude.  However, I plan on using CA on the bulkheads, planking pinned or clamped after correct bevel and bend, and then judiciously "brush" on PVA between the planks before the first plank sanding.   It's an experiment that I'm seeking comments from the far more experienced.   Also, as an unscientific survey where do each of you use CA verses PVA on ship model construction?
Lastly, I wish to thank all of you for the encouragement and guidance.   Modeling is similar to my former passion, golf.  It's an individual skill and effort made so much more enjoyable by the camaraderie of your mates, even when the "needle" is out.
Cheers to all,
Darrel
Link to comment
Hello Darrel
Great news on you starting a build log. I will follow with interest.
With regards to glue I tend to use wood glue whenever possible. I use a small paint brush to apply the wood glue and have a small tub of water so I can dilute / clean as necessary.
I will use ca glue usually when I need a quick bind and I'm unable to find a suitable clamping method. I will use a small drop of CA when rigging to secure knots. If I need strength I will sometimes use epoxy resin, such as when fitting the channels.
I have started the 2nd planking and I'm using wood glue. It does take more time but I prefer this method rather than ca glue which is much quicker. No matter how careful I seem to be I still end up with CA glue on my fingers which causes more problems (sticky fingers).
As can be seen in the picture below I use pins to hold the glued plank in place as I move further down the hull.
Glenn (UK)
Link to comment
I use CA for all planking and lots of other places, it just makes sense to me.  Don’t edge glue planks, it doesn’t take a lot of CA to hold them. I use white PVA glue for things I need to position before it sets, Titebond wood glue for structural strength like for the frame, epoxy for mounting to the stand and even CA medium gel for cannon to the deck. My answer for glue is whatever the job requires.
You’ll find as many preferences to the glue question as there are modelers, even the two Glenn’s don’t agree 🤣
Edited by glbarlow
Regards,
Glenn
Link to comment
I thought I would start start todays update with a photo of my shipyard. The Duchess is sitting on the deck of the Robert E Lee with Speedy and IJN Yamato in the background.
Progress on the 2nd planking is slow and steady, it is not perfect but I am pretty happy with how it is going and I think it will look good once it has been sanded smooth. I have started to tuck the stern planks under the lower stern counter as per the instructions.
Glenn (UK)
Link to comment
Link to comment
The pearwood is such a refreshing upgrade to model making, it’s a nice look.  You have a nice place to work.
Regards,
Glenn
Link to comment
Build instructions: 85
Task: Stern 2nd Planking
Parts: N.A
Time Spent: 14 hours
Status: in progress, port side complete
Build Notes:
I have continued with the 2nd planking of the starboard side which is now complete and ready for sanding and filling. As per the instructions I have been working from the bulwarks down toward the keel tapering the planks at the bow as necessary. I was also doing my best to tuck the stern planks under the lower stern counter pattern as I went along and I think out has turned out OK, noting this area will be covered up when the lower stern rail (207) is fitted later on in the build. Eventually I reached a point when next plank could not be tapered to terminate at the bow rabbet.
 1663378339_1052ndPlankingsterninprogress.thumb.jpg.a83e6e8ee1e58d160f81c5ca8a34dd92.jpg
As with the 1st planking, I decided to fit a full plank from the bow and allowed it to follow it natural path. At the widest point I set the infill gap to exactly 6 plank widths. With this middle central plank in place I then added two further planks above it.
I then turned my attention to the keel rabbet and decided to fit the first three planks. I must admit it was a bit fiddly trying to get the first plank in position but once it had been cut, shaped and bent it ended up being a really good fit. I found it unnecessarily difficult to trim the plank to the right length to sit flush with the stern post therefore after the 2nd keel plank was fitted I decided it would be easier to remove the stern post and to refit once the all the planks had been fitted and been trimmed It also means that it will be easier to sand the planks, if required, so that they sit flush with the stern post . See the pictures below.
I then filled in the gap in the middle of the hull. This turned out to be a straightforward enjoyable task
Finally, working from the keel upwards I filled in the low gap. As planks were terminating at the stern post. I was ensuring any gaps left for infill steelers were an exact plank width. I decided it was not that important how neat the planking looked below the water line as it was going to be sanded, filled and primed so that it became a smooth even surface for the final coat(s) of white paint.
Glenn (UK)
Link to comment
Just a quick update. I took a couple off days of the build over the weekend to sort some other stuff out so I actually stated the 2nd planking on the port side on Monday (I have already completed the starboard side).
I decided to use a two prong attack planking both down toward the keel and also up toward the bulwarks. This seems to be working very nicely and it has speeded up the progress (given I am using wood glue). I am matching the bow planking terminations with the starboard side (almost). Given the progress I have made over the last two days I expect to complete the 2nd planking in the next couple of days.
Glenn (UK)
Link to comment
Build instructions: 85 & 86
Parts: N/A
Time Spent: 24 hours
Status: Complete
Build Notes:
I have finally completed the 2nd planking. It did not turn out to be neat and tidy as Jim’s pre-production model, but it is not too bad. The rabbet was a great help with the planking.
 I marked the position of the waterline using my Amati tool and then, using some 1mm tape followed the marked line and then double checked the waterline position using Amati tool and plan drawing.
 I plan to apply filler (Ronseal RSLMPWFN100G 100g Multi-Purpose Natural Wood Filler) below the water line and sand to get a flat even surface. Once I am happy that the lower hull is smooth I can proceed with the next phase of the build which is to remove the temporary beams, pre bend the Inner Bulwark Patterns (193, 194), fit the Fore and Aft Deck Patterns and fit all of the Inner Bulwark Patterns (193, 194 & 195).
Glenn (UK)
Link to comment
Moving along very nicely Glenn!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Build instructions: 87 - 91
Parts: N/A
Time Spent: 3 hours
Status: Complete
Build Notes:
I applied filler below the water line and then proceeded to sand it back, just leaving filler in the depressions. It looks nice and smooth for the most part, but it will need a little bit more work once I have applied the primer coats to the entire hull below the waterline.
I then removed the temporary beams and I also twisted off the MDF bulkhead tabs above the decks. Using my craft knife, sanding stick and sandpaper I was able to remove the wood remnants. The inner bulwarks needed a little bit of sanding to remove some glue remnants from the bulkhead tab areas.
I then decided to test fit both the fore and aft decks. They both fitted perfectly but I did note that one hole location in the Upper/Poop ply deck did need to be opened up a little, as mentioned in the instructions.
The two Inner Bulwark Patterns (193, 194) were soaked in hot water for about 25 mins and then were clamped in place and will be left to dry overnight. I will, if they need, trim them once they have fully dried out. I also checked the fitting of the rear Inner Bulwark Patterns (195) with the aft deck in place and they seemed to be a good fit.
Once the decks and Inner Bulwark Patterns have been glued in place I will move on to painting the outer bulwark patterns blue and red.
Glenn (UK)
Link to comment
The fore and aft decks have now been glued in place. I dry fitted the inner bulwarks in place to ensure the deck stayed in place as the glue gripped and cured. I also used the Oval Side Port Locator plugs to test the alignment, as can be seen in the photo below.
I checked the fit of the inner bulwark patterns which need a minimal amount of sanding at both ends. My build seems to have a slight misalignment issue on the port side around the midships and towards the stern as I found it necessary to sand the bottom edge of the fore inner bulwark in order for it to align up with the final 2 (stern) gun port openings. I also noted a similar issue with the aft post side inner bulwark. I also checked and ensured I could push a brass pin through the small holes around the gun ports and window frames.
The bulwarks were then glued into place. The Oval Side Port Locator plugs were used to ensure the fore inner bulwarks were correctly positioned. I used plenty of clamps to hold the patterns in place. Once the glue has fully cured there will be a tiny bit of sanding required to ensure the top edges of the inner, middle and outer bulwarks are all flush with each other.
In discussion with Jim Hatch I have opted to apply a polyethene varnish to the decks and inner & outer bulwarks. It may take a couple of days before I receive the delivery of this varnish, which was not available in my local DIY stores (Screwfix and B&Q).
Glenn (UK)
Link to comment
I found that Homebase stocks the Ronseal poly varnish, in gloss, satin and matt, Wickes also do a satin poly varnish but only in 2.5ltr tins.
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
