Panzerkampfwagen V Panther Ausf.A - Tamiya-1:35 by Edwardkenway - FINISHED
at least I caught this one early......  I'd tell ya what I use for an airbrush,  but you have one on the way.......mine can be bought for around $30.00.  gray isn't an incorrect color per say either......looking at images of panther tanks,  there were some that had the panzer gray,  but they were early variants.  chalk it up to a rogue unit ;)   I'm certain you'll have fun with these kits!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Share on other sites
It's only a month away so I can occupy myself with either Winnie or my Cutter  and getting all the small parts brush painted😉
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Good news.
I knew I had a gray panther somewhere 👍
(this is a G version and not an A).
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
1 hour ago, Backer said:
Good news.
Thankyou Patrick, although the box of mine says it's  an A version the model looks more like the G because mine does not have the armour plates on the flanks.
Current builds;
Completed:
Link to comment
You are definitely building an A version.
The hull of the G version was different and simplified to increase production.
If you want to know the differences, no problem.
Regards, Patrick
Link to comment
Thank you Patrick🙂
After a very hectic Christmas holiday with our UK restrictions, I've not been able to get on with any of my ongoing projects 😕
But I am hoping to get back to this as now I have been given an airbrush for my bday and I've decided to use this tank to practice on.
That said I have already had a go on some scrap ply and a styrene sheet I had picked up long ago, but i still expect thing to go awry.😏
Also I will be sharing my time with Winnie, so thanks for hanging in here.
Oh I know it's a bit late but.....
Happy  New Year  to all, let's hope for it going a bit smoother ;)
Current builds;
Completed:
Link to comment
to you and yours as well Ed!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Well managed a hour or so on painting, although half of that was cleaning the airbrush.
I am quite pleased with the very first attempt on an actual model, even if I say so myself ☺20210106_181035.thumb.jpg.4edc4c9b8fa483792970c72fc76d4c33.jpg
I used tamiya desert sand and a first pass of the camo pattern in khaki. 20210106_181053.thumb.jpg.7623f7939e5d1528e79861934057314d.jpg
I personally think the green needs to be darker.
More soon, thanks for looking in and the likes🙂
PS fees good to be back at the bench after  the last two weeks.
Cheers
Current builds;
Completed:
Link to comment
Cheers
Are you still doing the Three tone version mate?
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Nice job on the airbrushing. But on my tablet the color appears more rust color than green or desert sand?  Unless Tamiya desert sand is more reddish than I would expect. The green camo appears more like a shadow, needs a tad more paint. But overall an xcellent first go at it.
Link to comment
So what do you think of your airbrush after the first use Edward? Do you think you are going to like the change? Can't comment on the color as I know nothing about German tanks, but the covering and texture look good from here.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
I was thinking the same as Lou,  it looks nice and smooth.
OC.
Current builds
Completed works.
Link to comment
Thanks Jack, hmm I see what you mean, it is more yellow in real life, honest, I think it may be my lighting in the room.
The green definitely needs more definition, I may use a bit of olive drab in it.
OC.
Thank you both.
I like it as it is quicker to cover an area and with practice I can only get better (I hope).
I think it will be extra useful when I get round to the Corsair.
Current builds;
Completed:
Link to comment
Idea for your camo  lines   -  Blue Tack   like I used on my Mossie.
OC.
Current builds
Completed works.
Link to comment
Jack it was the lighting as you can see in the  2 following photos
Current builds;
Completed:
Link to comment
Practice, (eventually) makes perfect....
Looks good from here my friend, Desert Yellow, good color for a Panther....
Quote:
Link to comment
Yep ! Agree. The color temp of the light effects how it looks in photo, tho I thought digital would auto correct. Very much a problem in film photography,  daylight versus tungsten
Link to comment
Your top pic in #45 looks spot on. The green (?) is faint, though. The paint finish is nicely done.
Ken
Started: MS Bounty Longboat,
Link to comment
Thanks Ken
Yes the green is supposed to be khaki,  I'm going to redo with a khaki/olive mix.
Thank you brother, the new toy is pretty nifty, I'm going have fun practicing, makes a good reason for increasing the collection 😁
Current builds;
Completed:
Link to comment
Cold has put a stop to my work so I've done a tiny bit,20210107_093627.thumb.jpg.fd1e0e5ceb7f661d1a059fbd8d6f7c11.jpg
tried a khaki  and OD mix, much better imo20210107_110639.thumb.jpg.43d309d84dc00d1de341c21c490cc341.jpg
colour looks better without the lighting on it.
Also painted the running gears tyres after dusting the wheels with khaki.
Thanks for the likes and popping in.
Cheers 😉👍
Current builds;
Completed:
Link to comment
now that's more like it!  ;)    you'll get better,  the more you use it!   look'in good
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Looking super  - that camo looks fine from my angle.
OC.
Current builds
Completed works.
Link to comment
Looks much better
Are you also going to add brown to the cammo?
Regards, Patrick
Link to comment
I've seen some that were two color when all they had was green to paint with, but usually they were three color..... Sand Yellow, Forest Brown & Tree Green... (at least that is what I call them) I found that Military Brown, Olive Green over a sandy Yellow gives a good rendition of the scheme especially when washed with dark dark brown..... (won't pass the rivet counters or rusty bucket people though)
Edited by Egilman
Quote:
Link to comment
I'll have to get some brown paint, it's now on my paints to buy list😉
Thanks for the input, much appreciated
Edited by Edwardkenway
Current builds;
Completed:
Link to comment
The nice thing about German camouflage between 1943-45 is that there is plenty of room for free interpretation.
If you don't want to use a brown color, that's fine too.
The only "general rule" for most German vehicles (Panthers also) is :
Sand color as a basis.
Green and or brown as additional colors.
No green and no brown, but only sandcolor is also allowed.
And when it snows and you have white paint and a brush. Then... a whitewash
Have fun
Regards, Patrick
Link to comment
Especially in the summer... no set pattern either.... very similar to the french WWI three color camo they put on the FT-17s except the bloches were fewer and bigger....
I always thought painting camo on german tanks was the easiest of the bunch behind US tanks....
Quote:
Link to comment
One of the reasons I went German😂 easier camo painting.
Don't know what I'm going to do 'when' I get to the IJN aircraft 🤫
Current builds;
Completed:
Link to comment
That's why I stuck to American, British and German when I airbrushed my collection of WWII armor. 😉🤫
Your painting is progressing nicely Edward.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
