1:2 T-800 'Terminator' endoskeleton - Agora Models
James H
STAGE 79: PARTS LEFT SECOND (MIDDLE) FINGER AND ARM
Another finger to build and fit to the hand! One tip...I find it's easier to slide the neoprene tube into the joint from behind, and THEN push the main metal pin through it to expand the neoprene whilst in situ. CA is used to glue a plastic cap to the opposite side.
The elbow joint is now completed and fitted to the left upper arm, completing that assembly.
Link to comment
Share on other sites
Link to comment
Pack 9
Here we are on the 75% mark on this build, and you really need space to store this when this pack is complete. The aim of this pack is to construct the complete left arm, hand, and and also a good chunk of the lower left leg. There is an amount of repetition here to the right arm, hand and leg, so as this build will primarily be for a magazine, I've done this pack as an abridged build.
STAGE 81: COMPONENTS FOR THE FOREARM AND THIRD FINGER OF THE LEFT HAND
The finger for this is assembled in the same way as the others, and still adding the neoprene tube to the joint BEFORE inserting the pin. It really is the only way to work this. Finger joints are all nice and stiff, with no floppiness. The forearm shafts are also assembled to the arm as they were on the right hand side.
Link to comment
STAGE 85: EXTEND THE LOWER LEFT ARM, AND CONNECT IT TO THE HAND
To connect the hand to the forearm, pistons are needed for the forearm shafts. These will engage the ball joints on the back of the hand. These are now assembled and fitted as before, and the spring/tendon connectors are added to the hand. Those springs are then connected as per the opposite hand. Arm complete!
Link to comment
STAGE 86: ASSEMBLE THE SHOULDER, AFFIX THE LEFT ARM TO THE BODY
A hip joint is included here, but that is reserved for the next stage. Fitting the arm to the body is very simple. The arm slots into position and a ratchet disc is glued into the shoulder joint connector. An Allen key is used to tighten everything up, and this is then used to slacken joints off later to pose the T-800. For now, I'll keep the pose fairly neutral.
Link to comment
STAGE 88: ASSEMBLING THE LEFT HIP JOINT
As with the right hip, the inner joint case is slipped into the hip, followed by the ball joint. On top of that sits the outer plastic joint case. The thigh is sat up to the T-800 so the ball joint engages with the hip. This is then screwed into position. The outer cap is then screwed into place with four screws. At this stage the hip will STILL be loose. This is normal.
Link to comment
James,
Great pictues as usual.
I've heard Sarah Connor is heading towards your house to stop the Terminator build being fully completed. Get your house security system upgraded ASAP, but don't buy a Smart SkyNet brand!
Richard
Link to comment
1 hour ago, Rik Thistle said:
James,
Richard
It's a real nice build. I know it's only a bolt/screw together job (with some CA in places), but it sure gives me something to do in between planking tasks etc. 🤣
Link to comment
super progress James!  how tall did you say he was again?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Six foot Two   I think.😜
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Well you’ll have a ready supply of Mercury if you need it.
edited It was the T1000 of Gary Sinise not this one better terminate myself.
Edited by Slowhand
Wrong terminator
Slowhand,
Current build - Polacca scratch build from Amati plan
previous builds
San Martin - Occre
H.MS Resolution - Corel
Half Moon - Corel
Dragon keel boat - Billings
Link to comment
  • 2 months later...
Well, we are now onto Pack 10.
At this stage, the model is extremely heavy and not so easy to manoeuvre for photographing! I'm also more wary of just lifting this thing by the chest cage and now grip by the pelvis too so I don't put any unnecessary strain on the model. Everything seen in this pack is just a reproduction of building the previous lower leg and foot, so these pics just show the key assemblies.
STAGE 91: ASSEMBLE A MUSCLE FOR THE LEFT THIGH
Muscle piston! All glued parts use CA gel. If there was a lot of chrome plate, I first rubbed each joint with some fine abrasive paper to provide a better key for the glue.
STAGE 92: KNEE, MUSCLE, AND FOOT: MAKE PROGRESS ON THE LEFT LEG
These are the three assemblies built for this stage; knuckle joints for the foot connection, muscle piston, and a knee joint with a ratchet wheel glued into position.
It really isn't easy flipping the T-800 over, but it needed doing! The thigh muscles are now screwed into position.
STAGE 93: BUILD OUT THE FOOT, AND CONSTRUCT ANOTHER MUSCLE
A nice, simple one. Another muscle piston, and screwing the foot section to the previously build foot assembly.
STAGE 94: AFFIX THE LEFT THIGH MUSCLE WITH NEWLY-CONSTRUCTED TENDONS
The other muscle piston is now fitted to the thigh, then connected to the other muscle and screwed through the thigh frame.
The ankle ball joint is now fitted to the foot underside.
STAGE 95: ASSEMBLE AND AFFIX A KNEE JOINT
If only a knee replacement was so simple! The knee joint is fitted with the ratchet discs and muscle piston.
This is then dropped into position and the knee end caps pushed into position and tightened with a hex screw. This can be adjusted to pose the T-800 when complete.
...and a little more work on the foot with the piston connectors and ankle joint.
Link to comment
STAGE 96: ADD THE LEFT KNEE CAP AND ASSEMBLE A TOE
The two kneecap parts are glued together and then the part glued to the leg.
And the construction of the toes also begins.
STAGE 97: BUILD PART OF THE LOWER LEG, AND A SECOND TOE
The lower led is now started, and another toe built.
STAGE 98: CONSTRUCT THE THIRD TOE, AND EXPAND THE LOWER LEG ASSEMBLY
More work on the lower leg with the attachment of muscle pistons, and another toe is born.
STAGE 99: BUILD A FOURTH FOOT PART AND ASSEMBLE THE LOWER LEFT LEG
The outer shin is now attached to the lower led....and another toe in the series is built.
STAGE 100: ASSEMBLE THE LEFT FOOT AND ATTACH THE LOWER LEFT LEG
After building the last toe, then can all be fitted to the foot. It's vital to check the toe orientation and position from the instructions or it'll just look weird. I know as I did it upside down the first time. First, the lower toe joints are secured to the lowest point on the front of the foot, then the upper rods fasten to the connection above this.
The lower let is now fastened to the T-800 with a single screw. As there is a ratchet disc on this, it can also be posed at the end.
Until Pack 11....that's it. 😃
Link to comment
25 minutes ago, James H said:
3ft tall (half scale) and weighs about 13lbs
Yikes  That is huge.
Link to comment
This is awesome!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
look'in good James :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
