Scud by TBlack - FINISHED - a gaff rigged sloop
I've been making a little progress, albeit fits and starts. The difficult part of the companionway hatch is behind me, and the rudder need staining. But the challenging parts, I think, are done. Although, in the bow is a winch which requires a gear and pawl. I know that the gear feature has been done many times, so I'll just copy if I can remember where they are on this site (?).
Link to comment
Share on other sites
Next comes the building of the stovepipe. Supposed to look like this:
First step: buy a brass screw:
Second step, cut down the top:
Third step, cut off the threads:
Fourth step, drill out the center:
Fifth step, create vents:
sixth step, make a pattern for the top
seventh step, fold and solder:
eighth step, attach to pipe:
Finally, paint flat black, and install.
Link to comment
Hey brother, you forgot to post the attached to boat photo, 10th step. The stove pipe turned out sweet, great job.
Link to comment
Nice progress Tom!
Maybe there is not much details and hardware to add,  but what you add really looks spiffy and up to the task.
The skylight is very probable if this was a pleasure craft. 🙂
Keep it up!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Link to comment
When I started this project I thought the hull was sacrosanct (don't alter!). Now I'm sorry I didn't take a scalpel to it. Nevertheless, I'm working around its imperfections. Today I decided it needed a cap rail, so installed one. I think it makes the boat more "finished".
Tom
Link to comment
Keith,
No, just that he bought it in Kennebunkport years ago. And just to be clear, yes, I’m making this boat better
than it deserves. In return I get to try out techniques without worrying that it will harm Uncle Jon’s enjoyment.
For example, I’ve cut two gears, using my rotary table for the first time, and cut two bushings for the anchor winch moderately successfully. And, you haven’t seen it yet, there is a bracket to hold the boom to the mast which is in 7 parts all needing soldering. So, I’m gaining confidence that one day I will be at your level of accomplishment.
Tom
PS If you’d like to take over as prime contact for our uncle, I can give you his email.
Link to comment
Coming along very nicely Tom, much more elegant than I expected noting the humble beginnings.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Thanks, Keith A. I can't help myself. If I'm going to work on something it has to be as good as I can give. BTW, you have been my mentor in many ways
over the years. If my efforts pass your inspection, I'm good to go!
Tom
PS. See this guy, my grandson, next to me? He just had his 11th birthday today 4/19. I need to change my photo.
Edited by TBlack
Link to comment
Sorry. I just stumbled over this log right now and wish I'd had the opportunity to comment before you'd gone as far down the road as you have. In the off chance that you weren't aware, I'll offer the following. Your Scud model hull may be of much greater interest as an antique than the comments in the thread indicate. (Re: the Antiques Roadshow rule: "If you hadn't refinished it, I'd estimate auction value at $25,000." "So what's it worth since I had it refinished?" "About $1,500.")
While the lead ballast keel indicates the hull was carved for a sailing model, and so the keel profile can't be expected to depict the prototype, in a folk-artsy sort of way, the hull appears to be a pond model of Nathaniel G. Herreshoff's 1903 Bar Harbor 31 class cutter, Scud, which, amazingly, is still sailing today and terrorizing the Med classic racing circuit following a total restoration. See: https://www.magzter.com/stories/Boating-Sailing/Classic-Boat/SCUD-MISSILE
Designer: Nathanael Greene Herreshoff
Type of Boat: Bar Harbor 31 Class
Rig: Gaff Cutter
Year Built: 1903
Built By: The Herreshoff Manufacturing Cpmpany, Bristol, Rhode Island, USA
LOA m / ft: 18.59m/61'
LOD m / ft: 14.93m / 48'10"
LWL m / ft: 9.37m / 30' 9"
Beam m / ft: 3.18m / 10' 5"
Draft m / ft: 2.21m / 7' 3"
Yard No: 603
Sail Stats sail area: 1425sq.ft
Construction: Double-planked yellow pine, inside planking cypress, and diagonally strapped with bronze and oak frames. HMCo hull: 603
NGH's records on the Bar Harbor 31's and any records on Scud, will be found in the Hart Maritime Collection at MIT, which, happily, has been digitized and is accessible online: https://mitmuseum.mit.edu/hart-nautical-collections-list and https://collections.mitmuseum.org/collection/haffenreffer-herreshoff-collection/
Scud in foreground:
Scud
https://classicyachtinfo.com/yachts/scud/
SCUD MISSILE
March issue of Classic Boat out now! - Classic Boat Magazine
1903 Herreshoff Bar Harbor 31, Rockport Maine - boats.com
More photos and full construction plan: https://www.yachtworld.com/boats/1903/herreshoff-bar-harbor-31-3079607/
Also extensively covered by WoodenBoat Magazinehttp://www.herreshoff.info/Docs/AuxDocs/1982_03_WoodenBoat_045_p68-74_Bray_BH31_Portrait.pdf
http://www.herreshoff.info/Docs/AuxDocs/2000_09_WoodenBoat_156_p144_Scud_Save_a_Classic.pdf
Edited by Bob Cleek
Link to comment
Bob,
Wonderful set of photos, and you obviously know the Bar Harbor 31. But my hull doesn't really fit the Herreshoff  design. I had originally thought the boat would make a nice example of a New York 40, and I could have made the deck and rigging to match, but then the heavy hull didn't fit the rest of it. With the full keel I'm thinking the hull fits a Grand Banks fishing schooner. Unfortunately, the owner wants a gaff rigged sloop.
Tom
Link to comment
As you may recall, I've been doing this project at the behest of my Uncle Jon. He died last night (age 90). I was able to send him photos (enclosed) of my progress:
bush1.jpg.94dc75cd9dc9019e8f2088dee9534f80.jpgbush3.JPG.3ddf1c1c09d25624376120c2e8c517df.JPG
I'll finish this project, and hopefully get to deliver it to his home in Maine this summer.
Tom
Link to comment
Tom, I am deeply sorry to hear of Uncle Jon's passing. My condolences to you and your family.
Edited by Keith Black
Link to comment
Tom, At a certain age I find it best to avoid photographs and throw out mirrors. I still think I am a teenager and don't want the illusion shattered.
Sorry to hear about Uncle Jon but take comfort from the pleasure he will have derived from seeing your workmanship.
Best regards
Keith
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
21 hours ago, KeithAug said:
Tom,  I still think I am a teenager and don't want the illusion shattered.
Best regards
Keith
I'm told that I act like a teenager and look much younger than my 77 years. Here's a up-date:
overall.JPG.ab0e53cbadd695cb0b1ef202d23e2b68.JPG1822662633_portbow.JPG.4f86679d9c055bd48f7f7e055b64cbc5.JPG664041570_portqtr.JPG.88cb6f0572c60ab552522c7c25105743.JPG
The boom crutch is just there for the photo. And Keith A. the bow chock was made using your method. Thanks for the guidance!
Tom
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
