De Havilland Mosquito by Javlin - FINISHED - HK Models - 1/32
Javlin
First of all the Nationality of the crate will be Brit the radio compartment and some of the IP are totally different I will have pics of the crate I intend to do at a later date it's colorful red/white striped tail .OC and EG I do not know if you fellas have any ideas on the cable/wire in these crates?I have four books now and it's all black/white I am thinking white and yellow just a guess.I have a bit more to do on the stand for the transmitter and some more wires coming out of the side of the transmitter behind the seat and PRU seats were cut in half.I added a switch panel down the lower L/side of the seat with two PE toggles and some punch stock which the PE came from the B-25 kit looks the part.I figures out the that piece on the side of the IP leg it goes flat no map shoot had to look at Kermit Weeks PRU video same riveting and all.;) Kevin
Link to comment
Share on other sites
Nice seeing you back with this.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
33 minutes ago, Javlin said:
I have been working on it OC but it has been like 1hr clips any idea on the wiring colors?;) Kevin
Just asked someone who should know  - just waiting for a reply back  as I am not too sure.
OC.
Current builds
Completed works.
Link to comment
Wiring color? I think you mean conduit colors...
There would not be any exposed wiring anywhere... Conduit colors are one of three, but generally they are the same as the bulkhead they are mounted to.....
You would do better researching the type of conduits used in the specific application.... They used both solid and flexible, solid in it's native color would be a cadmium silver, flexible would be either steel, aluminium or brass... most generally they were aluminium..... For their look, solid was smooth like copper pipe, flexible would look like old BX building conduit......
Silver, Black or whatever interior color was on the bulkhead...
Quote:
Link to comment
Thanks brother, you  said it better than I could,    I was going to cheat and go and ask someone involved in bringing a mossie back to life  as I wasn't sure of the answer.
OC.
Current builds
Completed works.
Link to comment
I got that report from a fella in Canada working on the restoration of a crate up there.thks for the input guys! ;) Kevin
Also EG he mentioned the pale yellow which I see represented on the right side of the fuse so another color on my part in that area is coming.He also mentioned the transmitter stand was a possibility.;)
Edited by Javlin
Link to comment
My pleasure Kevin, glad to be of help....
Pale Yellow is a color variation of Zinc Chromate which was the metal preservative used on the interior of aircraft of the period... If it had field maintenance you could easily see some on the interior of aircraft and early in the war you could see entire aircraft interiors painted in it, but not often..... Generally they were zinc chromate green... It became ubiquitous in aircraft, of the period, (especially US aircraft) British aircraft were either Green or Yellow depending on availability.... Eventually, wooden aircraft were being painted in an alkyd oil paint called Interior Green..... There is a difference, Interior Green was a semi gloss, Zinc Chromate green was dead flat.... ZC Green was a shade or two lighter than Interior Green as well.....
Portions of the interior being partially Yellow Zinc Chromate is period correct.......
Edited by Egilman
Quote:
Link to comment
EG Yellow Zinc is the color I am going with the L/side cables.I got some paint laid and being that the pilot sat on his parachute I cut the seat up removed the unwanted cushions and made her bar.I still need to hit the the fire ext with a little more copper the right color and add cushions to the arm rest and green.;) kevin
Link to comment
Looking great Kevin, wish I do mine that well...
Quote:
Link to comment
one one could enhance that seat quite abit
Looks like it came directly out of the maintenance manual, can't get much more detailed than that....
Quote:
Link to comment
The copit is basically finished I did make the frames for the back of the seat on the radio operator.I just took some .020" square stryene put needle nose to the stryene and channel locks to the needle nose and got a flat spot then cut the angles to the back of the seat worked well.I am not reaL fond of the pilots belts but think the radio seat looks a little more animated.The bomb sight was the last thing I did tonight it was testing the patience. ;) Kevin
Link to comment
Looking excellent.
OC.
Current builds
Completed works.
Link to comment
Very nice detail Kevin 😉
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
very nice cockpit........quite a bit of detail.  really looks good :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
cool video.......pretty ingenious! ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Not alot to show just sub-assemblies I also have the engines painted black only ATTM.The straps on the tanks black/silver?This is one tight fitting kit so much almost scares you and you have to look at the instructions more than twice been lucky to back out more than once.Have you ever heard the story of the Dragon instructions for the Scharnhorst..............?
Link to comment
Was like that on my Mossie build  - kind of get one chance of snap fitting  some of the assemblies to the main fuse.
OC.
Current builds
Completed works.
Link to comment
I like the work you are doing on this Mossie.
Waiting to see more,
Dan.
Current build : Mayflower - AL 1:64
Completed non-ship builds : Spitfire MK I - 1:48Arado 196B - 1:32, Sea Fury - 1:48F-15C Eagle - 1:48Hawker Tempest Mk.V - 1:48F104S Starfighter - 1:48
Link to comment
Thks Dan.I have it on good advice from the fella in Canada working on the restoration of a Mossie up there straps area grey-green so they were completed last night and the wing finished and fitted to the fuse just not glued up yet.The engines ......how far do I go?;) Kevin
Link to comment
super progress........ :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
  • 2 years later...
I have finally got some paint laid boys and I think it looks pretty close to PRU Blue not exact but their seemed to be some variances even back in the day.The first pic wasa Soviet blue but said not quite to much baby blue so looked at some more color chips and pics.The second pic is the same blue with about 25% intermediate blue needed a little grey introduced.The last pic is off the net and we do not if the color has been saturated or not.:hsmack:
Link to comment
All the decals have been applied and the final gloss coat taken care of.The hatch is one of the last pieces I need to apply along with a whip antenna no aerial wire on this one.I did lose one of the hinges for the hatch in the copit with just enough frigg'in glue to make it stick somewhere plane was inverted.:wallbash:
Link to comment
Time to hit the cabinet with this one fellas.I will never ATTM use a liquid mask (suggestions anyone) it was a bear to get off the ALL the glass were it was applied.I had to use alcohol to remove and then polish everything with Mequiars added another 2/3 hrs of work.I like her was an enjoyable kit over all much like the B-25.The next one to hit the desk is another off the SOD a 1/32 Trumpter P-47 D  Montex Mask.
Edited by Javlin
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
