HIJMS MIKASA 1902 by Jeff59 - HobbyBoss - 1/200 - PLASTIC
Hello to all modelling fans, hope you had a You had a nice Xmas and all the best for 2022. I think I got locked in the modelling room and told to stay out of the way 😂, result I actually progressed with the Mikasa. Finned adding almost all the etch down the port side, then came up with some daft ideas on detailing the stern walkway. Once finished it was then going to masking of the lower hull, done it right this time, fed up with scraping overspray off 😂 Shall put some photos up to show this stage of build.
Link to comment
Share on other sites
The small beads are the discovery of Jaqueline, my lovely wife who help me find this for the top rail on stern walk, Don’t know if this is right for period but hope it looks okay, easy to remove if not liked. Believe it or not for decoration of female finger nails. 😂 the bag has thousands in it, so get plenty shots. 🤪.
Link to comment
Started masking of hull, the paint has had about six months to dry so shouldn’t peel off on removal of tape. 🤞 Next was the painting of hull, did try various shades to try for some shading effects, but didn’t work this time because I don’t know what I’m doing, did say lm a novice with air brush, first shot, learn by mistakes, I hope. Time to put on the etch camouflage. 😳
Link to comment
Finally removing the masking to see if it looks okay, just some minor bits needing touched up also got the forward and aft decks fixed down, so no going back now. Feel at last I have turned a corner. The forward bridge structure got some minor corrections in the port hole positions, the ones on the front didn’t match the side port holes in height, so filled and repositioned them using actual ship as reference.
Link to comment
On 1/5/2022 at 10:57 PM, Boydie said:
First time reading your build log. Amazing job so far, along with your Arizona.
Thanks Boydie, still got a lot to do but trying to keep it progressing, regarding the Arizona was one of builds that I decided not to paint the photo Etch to highlight all the work involved in building a ship, think the only thing I will do with her is paint the lower hull and possibly the main gun barrels, just to make it look slightly more complete.  The Mikasa shall be the first model I will have finished in over thirty years 😳 here’s hoping, thanks for liking it. 🤛
Link to comment
  • 5 weeks later...
Hello again, it’s time to try and show some progress, just seems to be taking forever, even to me. Shall start with the port and starboard superstructure on main deck, the way the build works on the model you have to complete this , and the 12 pounder guns before you can progress to fitting the bridge structures.
Link to comment
This rather heavy approach to sorting the portholes in the doors on the side works, you don’t see this from the outside anyway, plus I scraped away some of the plastic moulding on the outside, it was a little too heavy for me, just have to be careful and don’t take too much off, all works from the outside. 👍 also done that tedious job of filling up the attachment points for the plastic kit shielding, done the usual plastic stock with liquid cement, then when dry, trim and scrape it all away, plus remove some surface details for ladder rungs. Fitted some of photo etch, but not it all yet.
Link to comment
On the 12 pounder guns, can’t achieve what CDW did with these, taking me hours to do one gun, the first part forming or rolling the etch to fit around the breach end of gun is a patience game for sure, found the best way for me so far is to form it around a small drill held in a bit  with just the shank protruding.
Link to comment
Looking great Jeff.  Building guns from PE is a real pain for sure.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
