Norwegian Sailing Pram by GGibson - FINISHED - Model Shipways - 1:12
First of all, thanks to those that welcomed me in my New Member Introductions post.  The warm welcomes are appreciated.  Well, after almost two weeks of waiting on the shipping, my ships have come in!  The two ships I ordered, the Norwegian Sailing Pram and the Muscongus Bay Lobster Smack, arrived on Friday.
I have begun working on the Norwegian Sailing Pram first, of course, as this will be my first build in the ship modeling world.  Hope I do as well as SkiBee and JohnN, as I read their build logs and will be referring back to those logs as I encounter my own "bumps in the road".
I appreciate any feedback and advice as I sail forward...  Thanks...
Edited by GGibson
Gregg
Current Projects:                                                     Completed Projects:        Waiting for Shipyard Clearance:
Bluenose 1921 1:64 - Model Shipways                   Norwegian Sailing Pram 1:12 - Model Shipways                    Yacht America Schooner 1851 1:64 - Model Shipways
        Muscongus Bay Lobster Smack 1:24 - Model Shipways        RMS Titanic 1:300 - OcCre  (Couldn't help myself when it was on sale)
        H.M. Schooner Ballahoo 1:64 - Caldercraft                             USS Constitution  1:76 - Model Shipways
Link to comment
Share on other sites
So, I jumped right into the build after receiving the ship on Friday.  Took inventory of everything in the box, laid out the tools it appears I will need, at least early on, and prepared a whole bunch of sanding sticks, as it appears I will be using those a lot in doing the necessary beveling, sanding, etc.
On Saturday, I worked on the bow and stern transoms, getting them sanded and beveled, and attaching the knees.  Had a bit of difficulty drilling the #55 hole in the bow transom and knee with the pin vise, but think it came out ok.  I need to read up on what that hole will ultimately be used for to see if I need to clean it up any or redo it.  The pictures below are of the building board and closeups of the two transoms.  Hope I have beveled them both accurately!
02-BuildBoard.jpg.9201f811489b9694d9be7999183a517b.jpg04-BowTransom.jpg.38b333fbf2737d0a0c2bb1e3f4750c51.jpg03-SternTransom.jpg.88780d7891a194021774381a8a70a145.jpg
I did glue the bow transom support onto the building board as suggested.  The stern support is a bit wobbly, and saw in one of the other build logs that he glued the stern support, as well, to provide more stability.  I guess we'll see how it goes as I begin the planking.
The plank bending will now be my real first test of success/challenges.  I do have an electric plank bender tool, but it really appears that the bends in these planks on this Pram are not so extreme that it would require the tool.  Sounds like the others have simply soaked the planks and formed them around the building board molds using rubber bands?  Wish me the best on the plank bending!  I'll update as I progress, and appreciate the input!
Gregg
Link to comment
Looking good thus far! I'm at the painting stage of this one myself, and for the planks I just soaked them in warm water for a while, and then bent them manually against a curved surface until I got about the right curvature to them. I let them dry before adding to the model. Worked pretty well.
Hard to tell from your pictures if you will need to, but I had to trim the center tab on the formers, as they were way too wide on mine to get the proper distance between the bottom planks. I found out that the numbers 2.5 and 4 actually had to mean that the tabs should be 2.5/10 " and 4/10" respectively. In my kit, they were a lot wider than this, and this caused a bit of confusion for a while on how the planks could possibly fit both ends of the pram. After narrowing the tabs, stuff started making a lot more sense.
Good luck on the planking! :)
Link to comment
Thanks for the encouragement and advice, Arild!  Much appreciated!  Although, as a novice builder, I'm confused on your tab measurement references.  I measured the tabs on the top of the two molds... 5/8" on the 2.5, 7/8" on the 4.  the two bottom planks look like they'll set on either side of the tabs fine, with the keel plank laying on top of them with a proper overlap and the tabs. Are you saying once they are bent, I may have issues unless I reduce the tab widths?  Those are pretty significant reductions... 1/8" on the 2.5, not quite 1/2" on the 4.  Am I understanding wrong?
Looking around the house for an adequate curved surface to use as a guide for the bend.  Thanks again for the input, Arlid.
Gregg
Link to comment
Sorry if I confused you. Let's blame it on me not being able to wrap my head around imperial measurements. My tabs ended up at 6 and 10 mm respectively. You do the math :D (Actual, not scale, width.)
If the tabs in your kit looks fine, they probably are. When I followed the instructions, which says that the planks should sit next to each other in the front, the gap in the rear end of the model was so great that the keel plank fit inside the gap with room to spare on both ends. And as the bottom planks cannot be bent sideways, I figured the tabs were off. I found no other explanation, and trimming them narrower solved the issue for me.
If you're not having this difficulty, please ignore!
I actually curved my planks around the smoke stack of my wood burning stove. A much smaller radius than the planks needed, but it offered heat which helped the process, and I just slowly worked in the curve in the plank until it was just about right and left it to dry.
Btw, have you checked your kit for completeness? I was worried mine would have issues, as every one who I've seen build this kit, has found parts missing or broken. In mine, it turned out that only the inwhales material was off. Rather than two square strips of wood, one was correct, and the other rectangular. Luckily I had some spare material which fit. Being new to wooden kits, the idea that kits seems to often miss or have the wrong parts, is a new experience, as I've rarely seen this in my many years of plastic modelling.
Arild :)
Edited by Arild Moland
Link to comment
Thanks for the clarification, Arild.  Makes sense when doing the mathematics conversion.  I think I'm good.  And, yes, I read other logs and viewed videos that mentioned inventory.  As far as I can tell, everything is there and in good condition.  I am moving forward!  An update on the bottom planks and keel plank will be posted next.
Again, appreciate all of the input!
Gregg
Link to comment
Progressing slowly but surely (I think!)... Have secured and glued the bottom planks and the keel plank.  Is there such a thing as using too many clamps?!?
210118a-GlueKeelPlank.jpg.9205d40f7e96d6f57a1b5fd777853b00.jpg210118b-KeelPlankComplete.jpg.4b4c5299d67270da491cecf6aa3ea532.jpg
The instruction book mentions a tendency for the planks to bow and lift up off of the molds, which is what mine has done, as well.  Going to wet the inner sides and band down overnight, as suggested, to see if that brings down the structure to its proper location.  Anyone else have issues/concerns with this?  Easily resolved?
On to more planking!  Thanks for following, reading, and critiquing!
Gregg
Link to comment
Good plan to re-wet and re-clamp. Unfortunately wet bent wood has a tendency to rebound a bit from as clamps are released. You might try wetting the planks, clamping them in place and use a hot hair dryer on them immediately to set the shape. Some use a heat gun but too easy to scorch the wood. Clamp or rubber band the the middle forms first and do the ends last.
Link to comment
I'm actually amazed that I have already gotten this far, and appearing to do "fairly well".  The past couple of days, I have finished the planking and placed the skeg and bilge keels.
210121a-PlankingComplete.jpg.2969fd69bb8c392094c0277eae53884c.jpg210122a-Skeg-BilgeKeels_Complete.jpg.a10d548da9c8b09f0f1a817baf5cc5e4.jpg210122b-PlankingComplete-TopView.jpg.90cf6ef89ee3d14cabb1c41326c9e0f3.jpg
The instruction book mentions that there will be some some small divots and gaps in the planks and, yes, I have some!  The book mentions two remedies... a mixture of sawdust, glue and water, or a little auto body filler.  What have you found to work best in filling those little boo-boos?
By the way, my thanks to Turangi for your suggestion on using the hot hair dryer to set the planks closer to the molds.  Had to wet/dry/band a few times, but it worked well.  Appreciate the insight!
Now on to the top side!  Building the daggar board case now and continuing to move forward.  Appreciate all the critique/recommendations anyone has to offer.  Hope everyone has a great weekend!  And... go Chiefs!
Gregg
Link to comment
A quick update on status. I have completed everything up to the point that they suggest painting the interior/exterior hull.  Here are pictures from both ends. Obviously, I have just set the seats and thwarts in the boat for the picture, they will come out before painting, as will the raised dagger board..
210125a-PrePaint.jpg.d256d67de9aea8020427181f4ec92aae.jpg210125b-PrePaint_SternView.jpg.29d3b819bce1d212f0e89113807b95d2.jpg
Before painting, I do need to still fill in some noticeable gaps in some of the planking.  I went to a local auto supply store and purchased a small tube of spot putty and hardener.  I will try that process for this boat.  Perhaps in future models (I sound optimistic, don't I?), I may find a better method for filling in those gaps.  Any suggestions are, of course, welcome.
Taking a week off to visit family (including two grand-daughters), so will begin the hull painting process when I return after the 1st of February.  Thanks again for your following, reading, advice, and critique.
Gregg
Link to comment
GGibson, you have done an excellent job on this model.  I built it a few months ago and had a number of problems that you have seem to overcome with ease.  Keep up the great work.
By the way, I kept a log on this model.
Norwegian Sailing Pram by SkiBee - Model Shipways - Scale 1:12
Phantom New York Pilot Boat - Model Shipways - 1:96                        Muscongus Bay Lobster Smack - Model Shipways - 1:24
        18th Century Long Boat - Model Shipways - 1:48
        Norwegian Sailing Pram - Model Shipways - 1:12
        Lowell Grand Banks Dory - Model Shipways - 1:24
Link to comment
Your model looks great! I am glad the hair dryer worked out. I use Elmer's Wood Filler to fill any problem areas, it is used straight from the container with no two part mixing. It applies easily, is easy to sand and blends smoothly into the existing structure. It has a tendency to dry a bit in the container but a bit of water and mixing sets it right.
Link to comment
Thanks for the comments, SkiBee and turangi!  And also appreciate the "likes" by others following my progress!  Took a week off and visited my son and family in South Florida, but now back in COLD Kansas City (just in time to root for the Chiefs in the Super Bowl).  OK, back to my Norwegian Sailing Pram...
Filled the gaps using turangi's suggestion of Elmer's Wood Filler.  Great idea, as I was at first going to use a 2-part auto body filler.  This was MUCH easier, and seemed to fill and sand down pretty well.  Will definitely use it for future models, as well. (Listen to me looking forward to more projects!)
Painted the exterior and interior, using the prototype colors shown in the instructions... warm white color for the outside and copper red for the inside surfaces.  I also used the warm white color for the thwarts and stern sheets.  In retrospect, in looking at both SkiBee's and JohnN's build logs, I wish I would have done the seats in some type of wood stain instead of the white color.  The stain really looks sharp.  Dang it...
210205a-Painted.jpg.ec0f5796007dcb0b3d3d90b54be1511e.jpg210205b-Painted_FloorBoards-Thwarts.jpg.534bde1a85dfde0f7d1a726138193522.jpg
So, now on to the tiller assembly,  I've read the instructions multiple times already, and still not 100% sure what I am to do.  Time to again look at others' build logs to understand this assembly process better.  I may be asking more questions VERY soon...  Appreciate all the advice, comments and critique.
Gregg
Link to comment
It definitely has become more challenging as I move to the top side of the boat!   First challenge was the tiller assembly.  Had a bit of trouble understanding the instructions, Ultimately, I glued the side pieces on the wrong sides of the tiller, so the hole in the tiller for the extension is on the side and not the top.  Not sure how that is going to work, so for now, I have not put the extension on and will simply install the tiller on the rudder without the extension piece.  We'll see how it looks.  Also, when I put the pin in and tapped both ends to make a rivet, I tapped a bit too hard and the pin bent a bit.  I can still hook the pin around the rudder.  Should have watched that better.
The eyebolt in the bow and installation of the stay plate against the bow transom worked out ok.  Not sure how I was going to get the bolt/nail through the inwale and plate, so I simply secured the back stays with superglue and have not (yet) placed a bolt there (mainly for visual appearance at this time).
The rudder gudgeons and pintles were definitely tricky.  Cut the tubes and wrapped them around the 4-hole straps, as it really didn't look like the 2-hole straps were big enough.  Whether it was an error in packing or not, I had 2 sheets of photo-etched parts, so I had some latitude on the straps I could use.
As I was taking the picture of the rudder, I realized I have not placed the bolts/nails on the rudder straps, so I'll do that before final assembly.
I'm going to stain the display stand and dowels, so will work on that next.  Also, beginning to work on the mast now, as well.  Will try my hand at shaping the two square sections into a nice round mast.  If that fails, I'll shape the dowel provided.  I've glued the two parts and will begin shaping.
An interesting observation on the spar shaping jig... the picture on page 28 of the instructions shows 5 jig supports, along with the end block and the bench hook.  But, my laser-cut sheet only has 4 jig supports.  I'll try to make due with what I have!
As always, appreciate your time in reading, commenting and critiquing.
Gregg
Link to comment
Thanks, Bob.  Actually, it dawned on me after I posted the update and commented on the 4 jig supports that I have the Lobster Smack boat waiting in the wings after I complete this boat.  Duh... Took one of the jig supports from that kit.
I am interested in hearing how others did their masts.  That task is next at hand.
Gregg
Link to comment
Well, I stained the model display stand using Minwax Red Mahogany stain.  Probably a little darker than I wanted the stand, but it will look nice once the boat is all completed.  You'll notice I went ahead and glued the oarlock plates to the pads, drilled and pinned now, rather than waiting to do any of that work after the boat was attached to the stand.  For now, I have simply inserted the oarlocks into their sockets.  In an actual boat, you would obviously want the oarlocks to swivel back and forth, but for this model, the oars will be laying in the boat, so wondering if the oarlocks should simply be glued so they don't fall out somehow.  With all that said, I then glued the boat to the stand and am now working on the mast and all of its fittings.
Used a little hand planer to bevel the corners and sanded the square mast as round as I felt I could safely, especially after reading SkiBee's account of his mast breaking from being too thin.  However, it does appear I still beveled and sanded the bottom of the mast a bit too small, and may have some issues securing the mast into the mast step when it gets to that point of the build.  I will have to wrap something around the base to "thicken" it back up in order to fit snuggly.  We shall see...
I have now attached the halyard cleat, the downhaul eye, the chafing pad and the fore stay cleat to the mast.  To simulate the chafing pad, I simply took a piece of paper, used a brown craft pencil rather than paint, cut out the pad to the proper size, and glued to the mast as instructed.
I'm a bit confused on the purpose of the halyard sheave that is cut into the top of the mast.  Perhaps I haven't read enough ahead to understand, but the pictures of the completed mast, both in the instructions and in SkiBee's and JohnN's build logs, don't really show me what we'll do with the sheave.  EDIT:  Nevermind, I see in Part 56 on page 37 of the instructions, it explains that the sail assembly appears to be threaded through this sheave.
So, I'll work on the halyard sheave and the back stay straps and complete the mast work.  Any advice on what works best to "dig out" the sheave without splitting the already thin mast?!?
Appreciate those who are reading and commenting!
Gregg
Link to comment
I'm not sure at all about the purpose of the sheave, except maybe to help prevent abrasion of the rope when raising the sail? Is so, why does it not appear on both sides of the mast?  The rope appears to pass through the sheave once only, so it seems to me that the lower hole did not have to be all the way through the mast. I put mine on the wrong side of the mast, and am debating whether to try and correct with filler.
I also ended up with the "alternative" eye just below the back stay straps, which appears only on the Page 5 plan. I don't think it will have a use. If the eye is indeed an alternative to the sheave, why would it not be shown in the same place as the sheave?
Link to comment
I have been quiet for a few days.  In working on the sail, and the lashing and lacing, I somehow misplaced a remaining chunk of 0.3 mm line, and couldn't find it for the life of me.  Probably got snagged on clothing and dropped off somewhere else in the house, nowhere to be found.  So... had to order some more 0.3 mm line from Model Shipways to finish the lacing on the sail.  That additional line finally arrived yesterday, so the shipyard is back operational again!
Honestly, after much worry and consternation on how the sail was going to end up looking after all the cutting, gluing, masking, lashing and lacing, the sail came out fairly well.  I made the four corner reinforcing triangles much bigger than they needed to be, but I guess they look ok despite their size.
So, today I finished the lashing, tying the gaff and the boom to the sail.  I also finished today making the traveler and attaching the traveler line to the two transom knees.
210302b-SailCompletion.jpg.b1482b356ee9c1d8584137ee9f006b84.jpg210302c-Sail_Gaff1.jpg.d04a6a51c516465733a7e7ba5e666731.jpg210302d-Sail_Gaff_HalyardLine.jpg.f9e677bb7bd0ffaa766fa112465d9968.jpg210302e-Boom_DownhaulLine.jpg.e77f4d8a9f6dfdfb97250d2a8e33a947.jpg210302a-TravelerLine_Tiller.jpg.51004dae14b4ab819c48ecb6c2bdffc6.jpg
So now it's on to installing the mast, the fore stay and the back stays, and hoisting the sail!  I've got some concern about getting the mast fixed solidly, as I beveled the mast a bit smaller than the diameter of the hole in the mast step, so may need to use some filler and/or glue to set the mast properly.  Hope it goes well.  Wow, I am almost done...
Appreciate your comments, concerns and recommendations.
Gregg
Link to comment
Not being a sail boat expert but an engineer; a sheave is just a pulley.  They can be hooked up exterior of the mast or imbedded in the mast or spar.
unnamed.jpg.86823da00579aebd80e458da063f8a02.jpgimages.jpg.79e2b5b55882364f2a158f5f15983838.jpgIMGA0801.thumb.jpg.e94b65e50520a27f795624f0f65ab6cd.jpg
On my pram, I painted the inside of my sheave cut brass to simulate a pulley and put nail heads on the side to simulate the pulley axel.
Link to comment
On Thursday, I worked diligently on the fore stay and back stay lines.  I was definitely worried about getting them secure and taut, and having the mast set steady in the mast step.  Actually, though, it worked out fairly well.  For the fore stay line, I secured one end of the line with one of the provided clips and then, as the instructions indicated, gauged where the loop needed to be made so it wrapped around the mast at the cleat.  Surprisingly, it came out ok!  I then secured the back stay lines and, again, as the instructions suggested, adjusted the tension on each of the back stay lines and used clips to hold them in place while I glued and tied.
210304a-BackStayClips.jpg.20c347073784442a39131eaaf22b3bb3.jpg210304b-BackStayClips.jpg.55962195ce641f3335f27448779ee7ba.jpg
For the gluing and tying process, I used the suggestion of tying some 0.3mm line around the 0.7mm lines in spacing intervals and then painted diluted glue to the lines to secure.  Seemed to be ok, but I'm not totally pleased with some of the look.  As I get better at the tying and knotting, hopefully the aesthetics will improve. Once I had the stay lines in place, the mast seemed pretty solid, but I placed a few drops of super glue at the base and mast step, which I think will help with keeping everything secure.
With the stays now in place, it's time to hoist the sail! So close to being finished!
Gregg
Link to comment
Well, I'm excited to get this boat finished, so early Friday I jumped back into the shipyard!  The clips on the back stay lines did a great job of securing the lines while the glue dried overnight.  I clipped the excess 0.3mm tie lines to clean up the lines as much as I could to look good.  I then threaded the halyard line through the sheave and tied it to the cleat.  I agree with SkiBee's comment about the appearance of what amounts to a pulley system for the sheave.   I did the same with the downhaul line.  One issue/problem I see now is that, in order for the sail and the boom to be high enough to clear the tiller/tiller extension, the gooseneck end of the boom hits the mast at a higher point than where I placed the chafing pad on the mast.
I finished running the line through the block on the traveler.  I had way too much traveler line going to/from each of the transom knees, so I shorten it a bit after I completed installing the main sheet.  Still not crazy about how that came out, either, but it's ok.  It appears I am now done and my first model build, the Norwegian Sailing Pram, is now complete!
210305a-SailingPram-Completed.jpg.1978d07ce68ca4d4d4125b96edb2e11d.jpg210305b-SailingPram-Completed.jpg.026b1d99bf12e533a231d3147227a0f0.jpg
So, lessons learned?  Definitely the two P's...  patience and perseverance.  Don't rush things in modeling, and try not to get frustrated.  As I move forward in this hobby, I hope my painting skills improve.  Close inspections show a few rough spots.  Another thing I realized at some point that I missed involved the rowlock pads.  Rather than installing the two sets of pads (for the four oars), I only did one set and, therefore, only used two of the provided oarlocks.
All in all, though, it came out well.  Now, on to the Muscongus Bay Lobster Smak.  Thanks to all of you who followed this log and provided insight and encouragement.  I'll need that on the next project, as well!
Gregg
Link to comment
Congratulations on finishing your Pram.  It really looks nice.
Ryland
               - Nautical Research Guild
Link to comment
Looks good, Gregg! You just clued me in on a mistake which I also made. I only have two rowlock pads also. The instructions do not call out 4 pads, just that they be installed at 1'-6" aft of the forward thwart frames and does not mention doing the same at the amidship frames. But the pictures of the completed boat do show them. I have already applied primer, I suppose I could sand it off and glue in another set, or maybe just stick them on with CA glue, or not add them at all. Decisions. . .
Congratulations!
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
