HMS Granado cross section- 1:48- by Canute
The box showed up fairly quickly via FedEx. Inventoried the parts and read over Tom's instructions (well, looked at the pictures😁). I'll be slow diving into this, waiting for my eye surgeries in March. But, I'll be here following along with the rest of the mates. ;)
Ken
Started: MS Bounty Longboat,
Link to comment
Share on other sites
I think you purposely decided to go for eye surgery so you could watch the rest of us try and build this first.
That's extreme! 😆
Link to comment
Somebody must be the lead rabbit; just not me. ;):D
I'll do what I can, like marking the various part sheets and such. I'm working under a rather bright light to read any fine print. I have 3 weeks to the first op.
Ken
Link to comment
looking forward to this, good luck
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Kevin, James, et al.. Thank you all. The inactivity is making me nuts. The Admiral listens to my whining, but she has enough other things to deal with. I'm marking up the part sheets today, so I can feel like I'm participating in the build.
Ken
Link to comment
James, I am an absolute tyro for building up these individual frames so pardon my basic questions. You glued up the As and Bs separately, with the chocks fitted? Then faired each A to B?
I'm starting to lay out the parts on #6, but am hesitant to do much truing with blurry eyesight. My first op is next Monday, so I'm raring to go.
Ken
Link to comment
I built up each individual frame with chocks, as per plan, then roughly bevelled up to the laser engraving marks on each (external and internal bevel).
Each A and B was then glued together and sat into jig on keel (no glue) where I'm currently sanding the interior to smooth it out more. When that's done, I'll remove the double frames and give a proper sanded internal finish and fit 'nails' to the chocks. Then I'll add poly to the side faces of each, then glue to keel and start to fit out the interior.
Well...that's my plan. I've never done a POF before.
Link to comment
