Lady Isabella by Mario Pires - FINISHED - Vanguard Models - Scottish Sailing Zulu
I have recently came back in to this hobby again, after a long absence. Finally I could set up a small area on the storage room. There is no heating though so I have been waiting for the last few months to start....  And speaking of that after several months of reviewing options, the Zulu Lady Isabella from Vanguard Models caught my eye. Such an elegant boat, I am planning to make build it with the optional sails and with the red/black/white color scheme.  I am not sure if other patterns were common, I could not find pictures of Zulus still sailing.
Here is the workspace
Link to comment
Share on other sites
A lot of old sailing workboat designs found second lives as pleasure craft, so I'm sure that taking liberty with the kit's rig and color scheme is not unprecedented.
When you have to shoot, shoot. Don't talk.
- Tuco
Current builds: Brigantine Phoenix, Hawker Hurricane
Link to comment
I have this model on the shelf so I'll be following along. It's a wonderful model. Good luck!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
Mario,
There are excellant Vanguard Zulu builds on this website, with some of those builds having many extras added by the builders. You will not be disappointed in your choice of Lady Isabella...looking forward to your 'build'.
regards,
Richard
Link to comment
I will certainly have a look at other possibilities for the color scheme !  For now I am eager to start. The kit is wonderful, the manual is very detailed and the step by step instructions are super clear. I made the right choice.  I also got another kit from Vanguard Models, the Flirt which I hope to build in the future, but it seemed prudent to start with a smaller kit....
The first step is the superstructure.  I only had some issues with the small pegs, but all fits very well. I assembled it first  for a dry fit:
here from the top
After certifying it was all ok, I then assembled it again and then glued it.
Tomorrow I plan to start working on the keel structure.  Did not do much today, but it was a great feeling 🙂
Link to comment
Made some progress on the hull construction.  The bevelled inserts (parts 16-19) were a bit difficult to slide in, and I had to remove a bit of the glue overflow that had accumulated when I glued the bulkheads in order to make it fit.A.thumb.jpg.fffb6a016fe0df84c7695acaaca0e843.jpg
Here is the structure before adding the main sub deck.
I noticed the sub deck was marked with the number 26 not sure why as it is listed as part 33FT. I had some trouble in installing it as I was afraid of bending it, but it did snap into place, though one of the bulkhead tabs snapped out. These will be removed later anyway. Will post a picture tomorrow as I only did a dry fit of it this evening.
Edited by Mario Pires
Link to comment
The hull is almost ready for planking.  I will still need to do a few checks before starting that. It will be my first planking ever, and I look forward for it.
1550649963_closeup.thumb.jpg.bd46b65ea99383642750c7d0e7190e41.jpgIMG_8524.thumb.jpg.00bb92fbc551bf7554efdc5a70762285.jpgIMG_8525.thumb.jpg.af82c938dbde27d87c90905b1128abfb.jpg
While I make a pause to breathe before planking,  I have been looking at the possible color patterns for this model. I came across the beautiful Fifie The Swan, launched in 1900,  restored and re-launched in 1996, at a venerable age of 96,  as a training ship. It has a beautiful  bright green/white/red pattern which caught my eye.
I am also toying with the idea of not having all of the sails hoisted, but so far I have not found clear pictures of a Zulu with the sails down and its respective rigging.  Any recommendation on a book is welcomed. I saw some praise on Sailing Drifters from Edgar J. March, , but have not decided yet.
Link to comment
In the meantime I finished the first and second planking. I am glad I choose the Zulu to start with and not a bigger model, as I did a few too many mistakes along the way. Still I am happy with the final result. This was my first ever exercise in planking, and I learned a lot while doing this. These are some photos of the first planking,  I will post photos of the finished sanded 2nd planking tomorrow.
Link to comment
In the meantime I have been struggling with the paint job. First because shops have been closed is not easy to find the right paints online, specially because I was looking for spray cans and could not find the right color tone for oxide red here in Switzerland. I did find this one but was not acrylic and I did not want to work with solvent based paints.
After a lot of searching I found the range of paints Liquitech in an online art materials shop.
464343569_LIQUITEXProfessionalSprayPaint-Sprhfarbe.jpg.600fad2580d973e5603e8a511a48892c.jpg
But I could only find white matt in a revell brand
While I waited for the package I finally received the book Sailing Drifters.
This is truly a book about courage, and a story that should be told. Is quite amazing.
Link to comment
I decided to paint the Zulu in its Black/white/red scheme. I wander what is the right sequence for masking and painting but I just followed the manual and painted the hull red with the Liquitex spray can. This paint is quite nice, it flows easily and has no strong odour.  I did 6 coatings..... sanded in between..... but still could not achieve the smooth surface I saw in other logs..... When trying to use wood filler I found it adhered very poorly to the surface, and so did not really worked.
I wander what is the best technique here, but of course making a better planking job than mine would help. I did feel the hull was polished and smooth but there were still irregularities in the surface due to planks not fully even. 😉
IMG_8637.thumb.jpg.3983fd041fe34eeed9e14a46ece80054.jpgIMG_8639.thumb.jpg.e3bbd45edd3c7888ca4b3fff0d625971.jpg
After this I tried to add the white band but this was really not okay. First I found the Revell spray paint had a very strong chemical smell, and it did not flow as well as the Liquitex. It also dried considerably slower, and tended to creep in in the masking. At the end I decided today to recoat once more the red bottom, and will paint tomorrow the black upper part FIRST before spraying the white - I also in the meantime got a Liquitex Satin white, so this hopefully should go better. Above you see the pictures of the hull painted red before I had applied the white paint.
Below is also the rudder. More to it tomorrow ....
Link to comment
Mario, after the paint, your planking doesn’t look too bad. I am building a Fifie and have trouble planking it. i blame the poor fairing of the frames. But, in reality, these boats were built by poor people and I’m sure their planking wasn’t that smooth. So, keep up the good work and I’ll be following your progress.
Ras
Current builds:
Stern Paddle Wheeler ZULU-1916-1/48 scale
Previous builds:
Freccia Celeste-1927 350cc racing motorcycle-1:9 scale-Protar kit
Boeing B17F- 1/72 scale- Hasegawa kit
HMS Mimi-scale 1/24-Fast Motor Launch
Amapá 1907-1/64 scale-Brazilian Customs Cruiser
Scottish Motor Fifie. 1/32 scale. Amati kit
Patricia. Steam powered R/C launch. 1/12 scale. Krick Kit
African Queen. Steam powered  R/C launch. 1/24 scale. Billings ki
Emma C. Berry. Sailing fishing smack. 1/32 scale. Model Shipways kit.
Link to comment
  • 4 months later...
Hello Mario, have you been able to make any more progress on your boat?
Bob Garcia
Current Builds:
Link to comment
  • 4 months later...
I am planning the rigging now.  The kit plans are not detailed enough for someone like me, as this is my first model, but I have been looking at pictures of other logs, and searching on youtube for inspiration. I will not dye the sails, I like the colour they are now.
Link to comment
Started the rigging. As the Zulu is my first model it is taking me time to understand what and how to do. Saw a few videos in youtube from a fellow building the Santissima Tridinad on how to make a knot around a block, and many others on different rigging techniques. The Zulu rigging is ver simple, but still quite a challenge to me.
Link to comment
  • 5 months later...
I finished the model, bringing it to a level I was not really certain I could, but it ended up to be a fantastic engaging project. I have learned quite a lot. As mentioned earlier my first attempt of building a model was with an Artesania Latina model ship (the Zuiderzee Dutch Botter) - this was back in the early 80's, and I could simply not do it. Zulu has been my second foray in this hobby.  I believe this Vanguard kit gives a great deal of confidence to entry level modelers, and I must say without a quality kit like this I could not have done the job.
Of all the steps in the process of building this model,  rigging was the one that I had the most difficulty. And this model has a simple rigging. There are a lot of helpful videos on how to do things, but what I can say is that I have a great deal of admiration for people that can pass lines through microscopic blocks....
I have a few ideas for a next project, still with a Vanguard model. I have Flirt and the Royal Yacht. I don't have Saucy Jack but looks a nice model.
Link to comment
  • The title was changed to Lady Isabella by Mario Pires - FINISHED - Vanguard Models - Scottish Sailing Zulu
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
