Wasa by Bill97 - FINISHED - Airfix - 1/144
Completed all the shrouds and ratlines. Michael I went ahead and added the ratlines to the top shrouds. I thought it helped them stand out just a little more than without. Also have all the yards attached. A little thread trimming here and there and then on to the standing rigging.
Link to comment
Share on other sites
That is the plan Michael. The Airfix model does not provide anchor points for putting the yards otherwise. I am thinking of maybe furrowing the sails but not sure yet. At this scale the top sails are pretty small. Not much bigger than an old time matchbook.
Link to comment
Link to comment
Michael on my previous builds of larger scale like the 1/96 USS Constitution and 1/96 Cutty Sark the instructions showed mounting points for the yards if with sails and lower points on the masts for without sails. There are clearly molded places on the mast for the two options. On my 1/144 Wasa there is only the one molded place on each of the masts for each yard. That is where I currently have them securely attached and somewhat initially rigged. If I was to try to lower them I would have to just randomly pick a spot where I think the yards would look correct on the masts for furrowed or without sails. I would also risk damaging the yards and mast trying to remove them now. So I guess to be accurate I am going to have to go with full sails or decide to be inaccurate and have furrowed sails on raised yards. Decisions decisions.
Link to comment
OK guys. It has been a while since my last Wasa post. I completed the standing rigging and the pre sails running rigging. I took some executive privilege in my rigging. The kit instructions for rigging was very limited with only a small amount indicated. I somewhat agreed with the limited amount because at this small 1/144 scale a lot of ropes (thread) criss crossing throughout could have become very crowded and distracted from the beautiful ship. I combined the instructions with rigging plans I have from other period builds I have to come up with my rigging plan. I used a dark brown (coke) thread in 3 different sizes for the standing rigging as well as the shrouds and ratlines. I used a tan thread (it looks almost white on pictures) in different sizes for the completed running rigging. I know my rigging falls short of being accurate but it makes for a pleasing model of the Wasa to be viewed by the untrained eye. I decided I do not enjoy rigging ships of this scale as much as larger ones. The masts and yards are much to fragile. I struggled getting the lines to be a little taught and not sagging because of there not being much resistance. So now on to making my sails. My plan is to furrow the lower sail on the foremast and mainmast. Then complete the remaining running rigging.
Link to comment
What a beautifully crafted model. Congratulations!...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
Link to comment
Looking great Bill, at this scale even the simplified rigging is a challenge that you've handled quite well sir👍. I plan to do a full rig job on mine when the time comes, but do worry about accomplishing this at this scale.
Michael D
Link to comment
OK rigging completed up to the point of adding sails and then finishing the running rigging. Placed her in the custom made case while she awaits me to complete making the sails.
If you have followed any of my other builds you have seen my process for making sails. I continued using that process on the Wasa. I use the plastic sails that came with the kit as molds for my cloth sails. First I measure the distance between the lines on the sails and transfer that to plain white paper filling the entire sheet with the lines. Then I measure and layout the pattern for each sail on the paper matching the lines on the plastic sails to the lines on the paper. I then cut a section of antique cloth I have and line it the same way I did the paper. After making the paper patterns I cut them out and place them on the cloth matching the lines and outline them with pencil. Once I have the patterns on the cloth my wife hand stitches the lines to add the sewn canvas texture to the sails. Then I cut them out and using a mixture of diluted white glue I stretch them out over the plastic sails and paint them with the glue. Once they dry I will pop them off the plastic and have perfect billowed sails. I will then hit them with a little airbrush and have a final product much better than OOB plastic sails.
Link to comment
Hung sails on foremast and completed the foremast rigging. Opted to furl the bottom sail to make viewing the deck a little easier. Going to do the same with the bottom sail on the mainmast. Also hung the two sails on the bowsprit (?).  Will complete the rigging on it and start the sails on the mainmast next time I can spend some time. I really like the way it is coming along. I am actually surprised at how nice of a model it is at this smaller scale.
Link to comment
MY WASA IS FINISHED!!!!  I have completed the beautiful ship Wasa. Thanks to all my new friends on MSW for all your help, suggestions, recommendations, and encouragement. This was my first build at this smaller and more fragile scale. Also a build that required me to improvise and employ skills and techniques learned in previous builds. The rigging is not perfect and not completely accurate but I am happy with the outcome. Looks very good in the case I made for it. Thanks again everyone. Now on to my most ambitious build yet. The Heller 1/100 HMS Victory!
Link to comment
Very nice work.
Congrats :champagne-popping-smiley-emotic
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
Nicely done!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
