HMS Zulu 1942 & HMS Eskimo 1944 by RGL - FINISHED - Trumpeter - 1/350 - PLASTIC
they look awesome Greg...........you've turned this into a dual build!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Share on other sites
Nah  - he is building two Denis😁   I will get my coat.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
A very nice job on the hull bottoms Greg; you have this technique nailed now.
cheers
Pat
Link to comment
5 hours ago, RGL said:
the pink is the best finish
Famous Ships and Boats in History:D
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
The plans have the focsle area with a checker plate and non slip strips. The kit has horribly raised bits and no non slip strips. When I bought the Pontos Marat upgrade to get the torpedo booms for the Borodino, it had lots of little steel strips which I’ve used here. The bits where the chain goes into the hull are little resin upgrades I got on a IJN set but I’ll have to add flywheels later.
Greg
Link to comment
Greg, those are the 'naval pipes' (one each side) fitted with a bonnet (bent part) and a hand wheel operated guillotine (cable stopper/brake) .  On deck will have been a blake slip for letting go the cable and a screw slip for use as a 'preventer' (I think I can see the screw slip on deck).  The blake slip would have been fitted to engage with the cable on it forward sweep on the fore side of the capstan with the bottle screw slip further out near the hawse pipe/hole.
cheers
Pat
Edited by BANYAN
Link to comment
Looking smart Greg.
OC.
Current builds
Completed works.
Link to comment
Looking very  sharp mate.
OC.
Current builds
Completed works.
Link to comment
can't get any better than those!  the detailing is awesome!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
