28 foot American cutter by druxey - FINISHED - 1:48 scale
People confusing him with his older brother.
Alan O'Neill
Link to comment
Share on other sites
Moving on, the details at the bow have been completed. I noticed on the photographs of the actual boat that the flanges on the inner sides of the hawse pipes were larger than those on the outer sides. A protective  metal strap extends down the face of the stem as well.
I'm now working on the wash strakes. First the stub timberheads were sanded to uniform height. Short lengths of plank are being added and then reinforcing pieces of mini in-rail. There are pieces of timber with a gap between tholes 1 and 2 on the prototype. I have no idea what their purpose was, but copied them here.
Edited by druxey
Link to comment
Looks as if some sort of cross-piece would slot into the gaps of the re-enforcements of the washstrake. Perhaps for the slide-mount of a light boat-gun. Not sure, whether the Italian navy of the time would have something like this, but the contempory Prussian navy did. This guns could be mounted on three-wheeled carriages for use in landing operations.
Link to comment
I keep having to remind myself this is 1:48.  Simply beautiful.
Maury
Link to comment
The wash strakes are now complete with their reinforcing pieces of in-rail. The in-rail is trapezoidal in section. I cut strips wider than the finished rail, beveled the outer edges, glued the pieces in, then trimmed the inner edge with a sharp blade and sanded. It is surprising how solid the structure of the model is. I'm in the process of fitting the last two knees at the stern, uniting in-rail with the transom. Again the knee is fitted and glued in over-size and the inner face shaped once it is secured.
Although there are still quite  few details to make, it is time to start considering how to mount and display the model. I'm favoring a similar base to that of other open boats that I have made, featuring burl veneer. However, a final decision is still pending.
(The pencil included for scale has been requested!)
Link to comment
Had you considered mounting her suspended from davits?
Alan O'Neill
Link to comment
One runs out of superlatives to lavish on this model. David, outstanding job!
Link to comment
Link to comment
Sweeps? Yes, there will be. Davits? No - then I'd have to build the ship the davits are attached to. "Ain't got no time for that!"  Thanks for the kind comments and for looking in again, everyone.
Link to comment
Models like this from you Druxey is why we turn to you for advice and inspiration. simply outstanding workmanship raised to the level of fine art!
Michael
Link to comment
Thank you again, everyone, for following along and for your kind comments.
The seat back held several challenges. It curves, is tilted and has to fit properly. The shape was determined using card patterns. A two-layer veneer of Castello was laid up on a one quart paint can. This, 4" in diameter, was exactly the correct radius - sometimes the gods smile upon us. I noted two supporting battens on the rear of the seat back, just visible in one of Eberhard's photos. As it turned out, constructing the back was the easy part. Much more challenging were the two 'horns'; the supporting timbers on the fore side of the seat. Compound curved surfaces and compound angled scores were needed. It took a very long full morning to successfully complete these. These completed the internal woodwork on the cutter.
Next will be finishing the exterior: rudder, rubbing strake, tholes and decorative roundels at the bow.
Link to comment
Really looking nice Druxey.  What a beautiful model.   Will you be painting any parts or will you leave it all natural wood?
Link to comment
Now on to the tholes. These look to be either bronze castings or of lignum vitae on the actual boat. For contrast, I'm using pear wood. The photo shows three stages in making these. It is much easier to shape them in situ than hold them in a hand vise. One done, eleven to go!
Link to comment
This is an inspiring build. No paint...just beautiful wood crafted at its best...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
Link to comment
Thanks for looking in, everyone.
The tholes were completed and the rub strake installed. The rub strake profile was rounded using a molding scraper and lengths then cut off using a slitting blade in the saw.
The last challenge was the roundels at the bow. The lettering was too small to paint by hand, so I created the roundels in PhotoShop at 600 dpi and printed multiple copies. The rope ring was beige thread. I formed the rings by wrapping thread around a drill bit shank, stiffening them with white glue. When dry, the rings were sliced off and glued to the roundels. The roundels were then cut free of the paper and the cut edges match painted.
The rudder is next, as this completed the boat itself.
Link to comment
Beautiful work Druxey!
Michael
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
