Thank you Martin,
your Kind words are much appreciated. Think now I can move on to QD ans focsile deck
Thank you David,
enjoy the further sequences as they come
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much B.E.
Nils
Current builds
-Lightship Elbe 1
Completed
thank you very much Geoff,
slowly the hull is moving towards completion, but there are still some build sequences to go
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Omega1234,
that is a very nice recognation, and I shall Keep sequence shots coming in as the work proceeds
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 46
yesterday I started with the QD ballustrade and its rails and supports, further some of the belaying Pins and Frames for the hammock netting (in height of the Crew`s neck and head )
checking out the height for a horizontal resting of the spare mast-parts, so that the crew has enough space underneath
The focsile deck gallowbeam (rest surface for spare mast parts) is only 4mm from deck allowing a horizontal lay-on, this causing the mid deck gallow Support to be 36,5 mm from deck with its rest surface
Little knobs at the rail ends
belaying Pins and hammock net frames
protection for head area
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Looks amazing as always Nils, Just Beautiful work
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Nils I am amazed by how fast you get these parts made and it always looks so clean and tidy.
Michael
Pete,
Thanks to you as a regular visitor to this log and for your Kind appreciations
Nils
Michael,
there are many Little sequencial to be built parts, so provided there is time to do, its just one or two days for doing These. I guess ist just like you did those many litte small parts for your Pilot cutter one by one
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils, Beatiful work is Beautiful Work
Best Regards,
Pet
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you David
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful, simply beautiful.
Bob
Current build:  SS_ Mariefred
Thank you Bob
Nils
Current builds
-Lightship Elbe 1
Completed
thank you Omega,
now is the time for fitting out, that is really fun, compared with the time consuming gun rigging. I have the QD permanently glued on now...
Nils
Current builds
-Lightship Elbe 1
Completed
been out of the loop for a bit..........quite amazed at what I've caught up to see! this ship is simply amazing.....there is so much packed into her! very.....very well done Nils!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Very appreciative and encouraging words Popeye,
thank you very much...
Nils
Current builds
-Lightship Elbe 1
Completed
Further fitting out by the shipyard....
I think I should wait with mounting part permanently around the closer mast areas until the rigging beging done, asume I shall need operating space to mount the blocks an pulleys of the running rigging.
I know and remember that well from the tallship builds
stairs (ladders), entering platforms, and chain pumps
chain pump discharge boxes with drainplugs, chain secured. The box discharge openings are closed with vertical slide panels
gallows before the main mast
chain pump crank Levers and bearing supports (all in dry fit)
the hulls upper siderails in this area still Need finetuning. The step from QD to platform is about one footlength high
I did`nt make up my mind yet if there will be a rudder-deckhousing fitted or not. At least the ruddershaft shall be shortend a bit. The tiller will be rigged as the Amati plan shows...
Build log part 47 to follow...
Nils
Current builds
-Lightship Elbe 1
Completed
I am Impressed Nils, This some of the best detail work that I have seen , You have done an incredibly beautiful job on your Pegasus
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Pete,
a very nice appreciation of yours indeed..
Nils
Current builds
-Lightship Elbe 1
Completed
Thank very much Geoff and Omega,
to both of you for your appreciated nice words
Nils
Current builds
-Lightship Elbe 1
Completed
WOW 2
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Hi Nenad,
I have`nt seen that to a sqare potence before, but a nice term, thank you ...
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 47
view to the interior
sternplate supports
fitted two more outboard steps at the top, now 7 steps per side
fitted the focsile deck with all its "underneath", the catheads glued in place, removeable chimney of the galley oven mounted
Overall deck view
fitted one additional post to both the ballustrade side rails
starboard anchor cable tied to the Messenger, portside cable put on the bit
the QD stair, when used, fouls a bit with the capstan spars on the gun deck, but I take that in account, and whoever does`nt see it won`nt bother anyhow
supports to the 4 foremast rigging posts
Nils
Current builds
-Lightship Elbe 1
Completed
Apologies Nils for not being around much of late and having to play catchup again :rolleyes: Your model is looking outstanding.I love and admire your decisions not to follow the 'norm' and produce something that is indeed your own style.I apologise if you have mentioned it already,but have you applied any clear finish to the brass parts to avoid future oxidization?
Kind Regards
Nigel
Currently working on Royal Caroline
Hi Nigel,
thanks for dropping in, yes I use a clear acrylic lacuer spray, but spray smal amounts into a small plastic cap and then use a small paint brush for application to the brass parts
Nils
Current builds
-Lightship Elbe 1
Completed
Love the activity of those deck shots Nils, they give a real impression of how crowded life must have been on one of those incredibly small vessels.
Don't think there is anything inconsistent about the Upper capstan and the ladderway. When used they would simply have covered the ladderway with a grating and the crew would have simply stepped over those impediments when working the capstan. The iron stanchions around the hatch were removeable for this purpose.
Cheers,
B.E.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
