HMS Pegasus by Mirabell61 - 1776-1777 - scale 1:64 - 16 gun - Finished
Hi Nils -- That's a teaser.  I ran into something like that on the Mizzen mast of my Rattlesnake, and it ended up that I had set the rake of the mast a bit too much aft.  That doesn't offer a solution, but I have to think that someone with more experience will have something for you.
Good luck,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Link to comment
Share on other sites
Really nice work Nils.  Your build is definitely an inspiration for my Pegasus as I go forward with my build.
I agree about the rigging too.  With my Badger, someone told me after building the hull that I was 2/3 of the way done.  I almost felt like the rigging was equal to, or more than, the hull work -- though I did add sails to my build.  It probably would have been shorter had I not in my clumsiness been constantly bumping into the spars and busting off blocks and lines  :rolleyes:
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Thank you Martin and Mike,
the question with the Yard moving away from the mast when braced, realy concerns me because I feel everything is in the correct Position acc. to the plan.
I know from the tallships I built before, from the geometrical design of the Yard-racks that the racks together with the Yards describe a halfcircle around the mast and so they do`nt interfere with the shrouds and backstays, and do`nt foul with the shrouds
The lower Pegasus Yards have no racks (only the adjustable truss pedant tackle), so probably the more the Yards are braced, the more ease is given to the truss pedants, regardless to the move away from the mast. Please give me a hint, if someone knows better....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Nils,
As I understand it, the first shroud was loosened for this operation.  Some ships have a set of rather large blocks instead of deadeyes to make this easier.
Link to comment
Mark,
thanks for your Input on this...,
yes it makes sense to loosten the foremost shroud when bracing and perhaps even also the second when bracing sharp, I have never seen this before, but perhaps someday there be an old painting or so showing this Detail in more Close up....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Link to comment
Build log part 64
making the main Yard.....
the plans calls for a 6 mm dowel but I find that too flimsy, so I Chose a 8 mm dowel, put on an octogonal middle section with 7,2 mm flat widths and tapered the Ends down to 3 mm.
This is the second Trial but I think it works out OK now and I shall do both (raw) lower Yards in this way
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Geoff,
thank you very much,  I`m happy if it is liked and to share this with others....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Bob,
thanks for your appreciation
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Very nice work on the yard end fitting.  I like it.
Bob
Current build:  SS_ Mariefred
Link to comment
Hi Karl,
Hi Bob,
I had some doubts with the Yard ends but I think ist allright now. I`ll leave the Fittings in brass, to give a Little contrast,  blacken the yards, and leave the stunsail booms in natural Wood to suit the blocks color of the rigging
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Very nicely done Nils.  Love your metal work!
Mike
Link to comment
Bob, Mike, and Martin,
thank you for your comments on the metal work....
basicly the parts are from the Amati photo etched plat set which I bought together with the plan. The two rings soldered to each of the mast-end tips are sliced off brass tubes 5,5 x 0,5 and 5 x 0,5
Martin, the upper plate in the pic is 0,7 mm thick the lower one is 0,5 mm thick
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
I like those photoetch quarter-irons Nils - they seem much more to scale appropriate than the Caldercraft white metal pieces.  You did a very nice job on them.
Cheers,
Jason
In the shipyard:
Link to comment
Hi and thank you Jason,
I have not used all the etched parts yet, as they are picked from the 9 Panels in total as required.
But every time I do use the one or other item I`m very pleased with the good Quality and precise fit. I do`nt know if the fellow builders doing the "HMS Fly" have These etched parts for "Pegasus" in their kit Content, but asume that they can be used there just as well
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Main- fore- and topsail yards
These Yards with their soldering work at the yardtips were the most difficult.
today I received the ordered 3,5 mm deadeyes for rigging the upper shrouds and some backstays, shall continue with that sequence next
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi Nils
Are you oversaturated with compliments yet? No? OK, truly great work and your details are getting neater and neater!
I found your question about bracing the yards quite intriguing. The missing space to brace the yards did in fact disturb me a bit but I just put it down to mistakes in my builds and ignored the fact that the kits must represent the true conditions considering their quality.
Browsing through John Harland’s Seamanship in the age of sails I find that for example the sequence of orders to wear a ship included:
Let go lee truss-tackle fall!          and
Weather truss tackle fall!
In seems your assumption is correct and the yard was allowed to move away from the mast. This however looks strange to me as it then would rest against the foremost shroud on the lee side, putting some strain onto and chafing it. But perhaps the whole rigging was much more dynamic and put to stress and wear as I can imagine when meticulously setting up one rigid rope or line after the other.
Very good question! Perhaps some other member knows more and where are the administrators anyway? ;)
Cheers
Peter
Link to comment
Hi Peter,
thanks very much for your comments regarding the Yard bracing. There was an answer from Mark, mentioning a loostening of the leeward formost shroud by means of a block tackle in the shroudline, an just this tackle can be seen, wonderful done, in one of Doris`s  recent pics on the Royal Caroline rigging on all three masts. Its too late now for me to do it this way, but l`ll adjust the truss tackles accordingly nevermind to the gap Mast / Yard.
That book you are Holding of John Harland seems to be quite informative for looking up answers to questions....
as there are hardly 18th century model squareriggers with braced sails shown, this Detail does not Show up accordingly, wether in plans, nor in modeling Performance. perhaps Chris Watton may put a remark on the Amati Plan, which in all I find quite good. I have even missed it in Lennarth Peterssons book "Rigging Period Ship Models" for bracing Details.
I often look into your rigging, when I ask myself, how did he do it? Its always good if someone is ahead of you with nice performed build
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thank you very much Omega,
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
super fitting work Nils!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Nicely done Nils,you have shown how important silver soldering is to this hobby.It is very difficult to simulate steel from wood steel from brass.
David B
Link to comment
Thank you Popeye,
Nils
David,
all These applications are done in normal soldering (soft soldering below 400 Degr. C), I trust they will sufficiently withstand rigging tensions
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Link to comment
Build log part 65
a Little update to Keep the gear moving on...
Topmast shrouds (without ratlines) set, as well as top topmast foreward stays. I`ll leave away the top backstays untill later  because they would only hinder the Access to the deck in the Moment. I`m thinking of making and  rigging the stay sails, now would be the time to have relatively good Access to the belaying points
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
seriously nice work Nils....very well done!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Nils your work on the boom ends is lovely and the drawing that you sketched is a nice piece of artwork.
Michael
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
