HM Cutter Cheerful by PRS - Syren Ship Models - 1/48 Finished
On 9/29/2021 at 3:02 PM, glbarlow said:
Nice work on the shrouds, they can be tricky little things.
Thanks Glen.
They were tricky wrapping them at the mast as there was not a lot of room. I probably should have done these before doing the top mast.
Speaking of tricky. I did the backstays and they were fun to get them both even. Still have to tighten them up and once I do the forestay I think it will be time to tighten the shrouds also.
My photography isn't the best using my phone. Sorry about that. I will see if I can try to focus better.
Paul
Current Build: HMS Winchelsea 1764 1:48
Completed Build: HM Cutter Cheerful-Syren Ship Models 1/48
Completed Build:  Artesania Latina Bluenose II
Completed Build Lady Nelson
Link to comment
Share on other sites
On 9/24/2021 at 7:28 AM, PRS said:
At this stage I made myself a jig for making rope coils.
There are three different sizes.
Paul,
I like the look of these jigs.  The only thing I would  say is that 26 mm  is  a pretty big coil.  When these are made in practice one holds the rope in each hand then stretches the arms out letting the rope slide through then bring the hands together to make a loop if this makes sense.  The point is that the diameter of the loop is about half of your arm span.  On our boat our coils were around 800 mm give or take, so you can work out what this would be at scale - around 16.5
Anyway, your model is looking great.  A step above mine, I think
Regards,
John
Edited by bartley
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Schooner for Port Jackson
Link to comment
17 hours ago, bartley said:
Paul,
Regards,
John
Good to know. I was thinking of sanding the coil template down a bit to make the coils narrower at the top so will measure and correct the length.
Thanks
Paul
Link to comment
I have to forestay and sling rigged. Now to go through and tighten all the rigging before doing the ratlines.
Paul
Link to comment
Very nice work on the rigging, Paul. The rigging really brings the model to life.
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
Thanks Bob.
Finished up the ratlines. Will have to look at another log for the forestays to see how they are attached at the front and the base of the mast.
Paul
Link to comment
Looking good Paul, so near the finish line now.  That has to be the world's cleanest work mat.
Regards,
Glenn
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Thanks Glen.
My wife is a quilted and I get her hand me down mats. Evidently they get worn where they cut all the time. (and I steal her needles and also get the hand me down scissors :)
Paul
Link to comment
I have the rigging done for chapter 13. It is getting harder to photograph and I get some weird black lines from my overhead lcd light and did try some flash pics also and they didn't turn out any better.
Paul
Link to comment
She is a beauty....its looking fantastic.
The color of the wood against the red and black really looks great.
Link to comment
Thanks Chuck and everyone for the kind words.
Shaping of the yards. Not hard with the drill but have to make sure both ends are even. Then brush painted with the acrylic black.
Paul
Link to comment
Rigging the lower yard.
I used a length of piano wire to get everything lined up and wrapped to the yard.
Then ran the rope under the last wrap as so.
Once I used some diluted PVA and trimmed the ropes and wrapped the outer edge of the rope I have the yard hung in place.
This took a lot of time to do but looks nice at the end.
The more I do rigging the easier and better it gets and I am still working on my rigging skills. I do struggle with seizing blocks trying to get them to look right.
Paul
Link to comment
Like your idea of wire to make the stirrups off the model using the third hands. I'll definitely be using that technique when I have to do mine.
Will
Erycina 1882 Fishing Trawler by Vanguard Models 1:64 scale
Syren by pearwill Model Shipways 1:64 scale
On Hold:
HM Cutter Cheerful  Syren Shipmodel Scratch 1:48 scale
1776 Washington Row Galley scratch scratch from NRG plans #121  1:48 scale
Completed Build:
Charles W. Morgan by Artesania Latina circa 1988, Lowell Grand Banks Dory 1:24 scale by Model Shipways, Norwegian.Sailing Pram 1:12 scale by Model Shipways, Muscongus Bay Lobster Smack 1:24 scale by Model Shipways
Link to comment
Lower yard is rigged but not completely tightened yet. This was quite the rigging process for sure!
Paul
Link to comment
After a few days of intensive rigging I have the upper yard all done and making up some rope coils.
Was tricky to do but I kept going back and doing a little bit at a time.
Paul
Link to comment
That looks great.  Its amazing how much larger the rigged model is compared to when you were working on the hull.  That took some getting used to.
Link to comment
Thanks Chuck. Yes it is huge now and I have to be very mindful when I am working on it to not snag myself in all the rigging.
22 hours ago, glbarlow said:
Looks great, congrats on almost being done!
Thanks Glen. I am going to be happy/sad to be finished and have not completely decided on my next project.
It is a decision between the Triton cross section or the Winchelsea. Today I am leaning towards the Winnie but will be cutting my own bulkheads if I do it.
Paul
Link to comment
After adding the anchors and their rigging and the stanchions I can say that I am finished.
This was a fun build and I learned some new skills and also learned patience.
Paul
Link to comment
Beautifully done, Paul, and a great build log to boot. Congratulations!
What's next?
Bob Garcia
Current Builds:
Link to comment
Congratulations on finishing this beautiful model Paul.  I have enjoyed following your build log.
Ryland
               - Nautical Research Guild
Link to comment
Thanks for the likes and comments throughout this build log.
It really helps when people comment or offer suggestions.
Here is the final resting place and also my crew member.
Paul
Link to comment
Congratulations on completing Cheerful. It’s a wonderful model to build and you’ve done a very nice job of it.
Regards,
Glenn
Link to comment
Excellent build! Very enjoyable build log. Thanks for sharing.
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                            Iron Clad Monitor (complete)
                            Sardine Carrier which I will Name Mary Ann (complete)
                            Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
Link to comment
1 hour ago, Nunnehi (Don) said:
Truly beautiful model and a great build log Paul, I’ve really enjoyed it! I think this will have to be my next project with the idea of applying what I’ve learned from the the Winchelsea.
Don
You'd do a superb job on the Cheerful, Don, especially after seeing the work you are doing on the Winnie.
Bob Garcia
Current Builds:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
