1/32 Yak 3 Special Hobby "Onward to Berlin" Finished
I started this build last night not much Russkie in the collection either this will be my 2nd SH kit to which I have a few limited run kits in the collection waiting to be built.I will be using for the first time the Quinta Studios copit it adds some nice details.I may play with the wheel wells have seen some Nice enhancements done by on builder.The Qunita people say to paint first then overlay the decal that started last night with the grey to which the instructions say to use a light gull grey I opted for neutral grey a tad darker.
Edited by Javlin
Link to comment
Share on other sites
Sweet! The Yak-3 is another airplane that I have a soft spot for, having built the Normandie-Niemen version in 1/72 scale from Heller as a kid. A few years ago (more like a decade) I built the 1/33 scale card version from Orlik.
EDIT: Just discovered one can still get the Heller kit on eBay.
Have fun with your project!
When you have to shoot, shoot. Don't talk.
- Tuco
Current builds: Brigantine Phoenix, Hawker Hurricane
Link to comment
I am not the best photographer maybe some outdoor pics later.........now others it seems have a steadier hand than I but were the wires feed in the back I cut off the stubbs ,drilled .020",inserted hollow rod and then the wire.I like the Quinta kit for the big slides but had a nob break while fiddling with the IP the thin pieces break fairly easy or maybe just fat fingers:unsure:
Link to comment
Very nice and sharp work on the cockpit.
Best regards,
Dan.
Current build : Mayflower - AL 1:64
Completed non-ship builds : Spitfire MK I - 1:48Arado 196B - 1:32, Sea Fury - 1:48F-15C Eagle - 1:48Hawker Tempest Mk.V - 1:48F104S Starfighter - 1:48
Link to comment
your off to a good start........the instrument panel looks really good :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Best regards,
Dan.
Thanks Dan they Quinta slides like anything have there good and bad points.
The big slides Denis from Quinta are a great improvement it's the small handles and T-handles can break easily the dial already have the clear lens applied I p/u mine from these guys  https://www.hobbynutmodels.com/collections/3d-print-detail
Link to comment
I figured it's time for an update.The kit presents it's problems like most limited run kit first off the tail-planes have a terrible step on top on one side and the bottom of the other.I put .010 round styrene in the grove and filled outward about 1/4" and commenced to sanding had to make two passes after the silver showed the line still present at the edge about 20 mins a side.The next was the top cowl the moulding is either thick on the l/side or the male part of the fuselage is fat I worked both got some relief just not 100% maybe 85/90%.The wheel wells may I say were a "B" are made of 6 pieces all together to which you have to line them up to the bottom half of the wing and hope it lines up with the upper moulding I was close but no cigar but it happened with choice words and coercion.The fit between the fuse is OK should work but some wood clamps from the other side will probably come into play.Do I hate the kit by no means not it will be presentable as a nice build just not a shake n bake that's all.Now some pics of the good bad and ugly.;) Kevin
PS: went to Covington LA yesterday for a model contest a first for me in 15/20 years about a 1 1/4 hr drive not far had a great time Wife was in Alexandria LA with some friends.So Kevin walked out for $210 Trumpters 1/32 P-47N,P-51D,P-40B,Me 262w/extras and a 1/72 Hase Emily bigger than most of the 1/32 minus the jug.When I walk out of a hobby store like I did in Mobile and do not buy anything because I have more in the stash than they have on the shelf me says time start shopping elsewhere.
Link to comment
Belts and footstraps are in and I have got to say the Quinta in this area is a Treat! The cage is glued in non need to afix the rear rad screen glue the fuse to the wings and then the last two panels for the pit are last.I will then be off to tracking down pics of the LG.;)
Link to comment
Link to comment
I remember getting any Eastern Bloc info on their a/c was very tough. Why the French and Italian equipment was so rare, I wish we knew.
Ken
Started: MS Bounty Longboat,
Link to comment
9 hours ago, CDW said:
I love the WW2 Russian fighters. For whatever reasons, I never recall seeing many photos or reading about Russian WW2 aircraft until more recent times. Growing up in the 50's and 60's, all we ever saw were American, British, Japanese, and German aircraft. Never French, Italian, Russian, Polish, etc.
Thks Craig.I have a couple of the Russkies  in the stash in 1/48 but like you mentioned have been adding those other Nationalities but the "American Beauty" will be coming such a pretty P-51D.
Link to comment
Well got some white on the spinner as a backdrop for the red and went on the hunt for seams found some in the tail ,behind the pit and the left wing all quick.I am thinking of going closed canopy on this something about the shape lends itself to that direction? That's all for a couple day methinks back to the treadmill tomorrow bright and early.;)
Link to comment
Nice work on the cockpit and the closed model looks cleanly done.
Waiting for seeing more,
best regards,
Dan.
Link to comment
Are the white sprays to check the junctions?
Link to comment
Yep, it's easier to see an irregular surface once it has been painted....
Quote:
Link to comment
nice progress :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I have got some paint and she has been glossed.The color of the blue was a bit to conjure up not many manufactures make it and the chip was darker than RLM78 but this dark?<_< I for the second time used blue tac and did not care for the results it came out light in some areas and fine in others and then it left a grease line in some of the light grey.So,I had to go back and freehand every dk grey line and then retouch the lt.grey lines were the grease mark remained so then I just free-handed the blue.I should of just free-handed the whole plane like usual would of saved me about and hour the Badger Renegade airbrush is quite capable and up to the job.The freehand was done @25psi and the mixture consistency of whole milk.
Link to comment
It looks rather spiffy in its camouflage. Very good job.
Regards,
Dan
Link to comment
Those decals really bring it to life.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
1 hour ago, CDW said:
Great model, love the progress. Do you have any info on the pilot of the plane that carried these markings? They had some very good pilots from what I have read with victory counts that rivaled the German aces in many cases.
There may be some in the instructions Craig I like doing stuff for eye appeal now I was thinking that the silver stars may mean something in production line series?Theirs been one guy and his name eludes me now who served WWII,Korea and Vietnam was a colonel of a FG that I would like to do a plane from each conflict he flew in his markings.Boles?
Robin Olds
Edited by Javlin
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
