HMS Hood 1941 by CDW - FINISHED - I Love Kit - 1:700 Scale - PLASTIC
The 4 inch secondary guns. The oddball on the far right is the casualty of a lost gun barrel, hence was forced to use the stock kit ones where I drilled out the barrel ends to make them somewhat more presentable. Who knows, maybe I’ll get lucky and find the missing barrel later.
898A0563-3734-4A0A-90D9-4CDCA2AF581D.thumb.jpeg.be0532307c30cd365a5d8e8da28e3977.jpeg2CDCEFD0-178D-4590-9E48-57E16D412948.thumb.jpeg.ce054cd274aa889b505c847030c9e090.jpeg
Next up are more superstructure assemblies.
F9BBD7AE-2120-4DD6-8873-032D07AF9D46.thumb.jpeg.4cf2256a0ebe45c31f064348a3f3eefd.jpeg25011219-B3B5-4715-AE26-6332101CBCAE.thumb.jpeg.7df82f8a8ede33e5553703c686b4f1fb.jpeg
Link to comment
Share on other sites
Wow the stock kit barrels are so short and stubby in comparison.   I wonder if there is a substitute you could fashion that would be more consistent with the upgraded barrels. Maybe some thin dowel?  Scott
Currently building:
HM Yacht Chatham - 1:64 - Caldercraft
Link to comment
I found it! After recharging my flashlight battery over night, I looked again this morning and found it. Hoorah!
laying next to a small pin, you can appreciate how small this is, about half the diameter of the pin.
Link to comment
A precaution:-
When I built The Meng 1/700 Bismark as a trial run for the Flyhawk deluxe kit, I spent more time on the floor with an LED torch looking for microscopic parts that had gone AWOL than I did building the kit! I now use an apron when working on small parts in the same way as a goldsmith does to save all precious metal filings that would otherwise end up on the floor. Simply put on the apron and tape the bottom hem to the edge of the desk. That way any small parts will be caught in the fold rather than falling unhindered to the floor.
Edited by RogerF
Added correction
Link to comment
21 minutes ago, RogerF said:
A precaution:-
Now that’s a great idea! Thanks for sharing it with me as I will put it to use.
Link to comment
Just now, RogerF said:
My pleasure, hope it works for you.
I'm enjoying your build but many if not most of the plastic parts look like resin rather than plastic, is that so? I'm sure in my kit there are no resin parts just plastic, photo-etch and of course the wooden decks.
No resin, everything is plastic, machined brass, photo etch brass, or stainless steel photo etch.
Link to comment
Fantastic PE work Craig.  And glad you were able to find the lost barrel.  I've spent hours on the floor looking for parts like that as well.  My problem is I often times work on my kitchen island, and the floors in the kitchen are a medium brown oak, so brass doesn't show very well :(
The apron is a great idea.  I've also heard some put a white sheet on the ground to make the dropped parts easier to spot (maybe you were the one to suggest the sheet).
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Excellent work mate  - so difficult at this stage  - I think when I get my Flyhawk  I will just leave it in the box.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
That is looking superb Craig.
OC.
Current builds
Completed works.
Link to comment
Put the upper and lower hull together along with the main deck pieces, then began adding the superstructure sides when I realized I may be getting ahead of myself. Not sure the wooden deck appliqué fits along side or underneath the sides. If underneath, will need to remove the side I added. No construction sequence is given so it’s hit or miss.
000DF446-D247-459F-9F7D-50E97FA5D038.thumb.jpeg.78d643fb9ecc7923f8664d0fe5ffa7ca.jpeg8332CAC8-1D9F-4ED3-B59A-7FA44957E069.thumb.jpeg.c9e1258c6839666c75a3da69f2c029bd.jpeg520B56F5-A3D2-4CF3-886E-0791581303D3.thumb.jpeg.8549c0de83a03942ecfeed11f6b49ad2.jpeg
Link to comment
I know it's been said the HMS Hood was (dark?) gray below the waterline, but it's odd I could not find a single full hull photo of the ship with the lower hull depicted as gray. Everything I see is hull red below the waterline. Seems to me if I paint my hull gray or dark gray below the waterline, I am going to own the one unique ship who is depicted as such.
Link to comment
I'd say go with your gut feeling and research, Craig.   I hope you can sort the deck out before you cross the line of no return.
Link to comment
I'll do a bit more searching before I decide on the hull, meanwhile the superstructure side is coming off and will lay the wood deck first. It would have been nice if the sides could go on first and then would not need to mask the wooden deck before painting the superstructure.
Link to comment
I know what you mean with the lower hull colour, there are so few colour pictures  showing the lower hull,  the  only places I found  refernece  to it was on the  main Hood  website, they show some  underwater  shots of  her resting place  and they say it shows  the anti fouling Grey  but its very hard to make it out,  I did wonder why they would make her different from the rest of the RN fleet, when all the rest use anti fouling Red.
OC.
Current builds
Completed works.
Link to comment
Sides came off and the wooden deck was applied before gluing the superstructure sides in place. Will have to mask off the deck before painting the superstructure. In the end it’s much ado about little because another deck covers most all of the wood deck beneath. The second deck is resting in place without glue, just sizing it all up.
64E7CCB2-9CBC-47EA-9673-228AA87630CC.thumb.jpeg.0ef3f67e2113764aa08adc9450d25659.jpegF38C349B-0BAB-438A-B21A-542FE949FA6A.thumb.jpeg.b0ca6648d93cd9e161c8880b277ff9be.jpeg079D3844-6F42-4278-9C24-3F9DA639B02B.thumb.jpeg.68d437397da503c97bb6132c01014a27.jpegFE6E77B0-4299-4679-BFBC-310C1A42B3C7.thumb.jpeg.a2ba5ec97858916ba1a740e846be9945.jpeg
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
